Electric motor whine
Discussion in 'Gen 2 Prius Technical Discussion' started by jalynn2, May 27, 2007.
  1. jalynn2
    jalynn2 Junior Member
    Downingtown, PA
    I bought my 07 Prius in February of this year. For the past month or so I often drive with the driver's window open. When I do, I can hear a high-pitched whine from the electric motor when starting out and when using regenerative braking. It is not very loud (I cannot hear it with the window closed), but is loud enough to be annoying. Is this normal? I'm almost due for my 1st oil change, so I'll ask the dealer to check it. But I wanted to hear your experience here first.
    Thanks,
    Joe
  2. darelldd
    6,059
    389
    Northern CA
    The good news is that the "Electic cars are dangerous since they're so quiet" crowd should be happy to hear this. The bad news is that the only annoying-to-me sound that the Prius makes is when the gas engine starts, and I can hear (and feel) IT!
    Give me the EV whine over the ICE rumble any day.
  3. Tideland Prius
    16,611
    <div class='quotetop'>QUOTE(jalynn2 @ May 27 2007, 07:12 PM) [snapback]450829[/snapback]</div>
    Yep, perfectly normal. Note that the harder to brake, the louder it gets. It's a very good way to see how much you're regenerating. If it suddenly becomes soft, you probably braked too hard and you're using the friction brakes.
  4. Mr.Vanvandenburg
    1,358
    586
    2020 Prius Prime
    Mine is louder than that. My take on the braking, which has been discussed to the hilt before, is that the generator is engaged only partially on coasting, and fully when braking, or maybe even progressive change. It seems that they designed coasting to be about like a normal car to avoid any consumer misunderstanding or some other reason.
    I think the friction brakes apply just like a normal car as soon as pedal is touched, but the extra full regen makes it much less work for them. I wish they would have had full regen on coasting as well, or a switch to change it back and forth.
  5. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    <div class='quotetop'>QUOTE(Mr.Vanvandenburg @ May 28 2007, 08:53 AM) [snapback]450978[/snapback]</div>
    Friction brakes only apply after a specific threshold (depending on speed, charge current, braking force required, etc.) - otherwise it's pure regen on light braking.
    You can get full regen while coasting by using B mode. However doing so without at least lightly tapping the brake pedal could be dangerous in traffic as you slow without obvious indication to the cars behind you. Also, B mode tends to keep the ICE running at a stop longer than D. I find myself switching between the two if I want more regen when coming to a stop.
    There could be 2 whines you're hearing.
    A very high pitched squeal that's constant are the capacitors at work in the inverter. The more juice flowing, the more you'll hear it. I can hear RX400h's, Highlander Hybrids, and other Prius in a parking lot thanks to those ;-)
    The other whine which gets higher pitched with speed, and higher intensity with load (acceleration or regeneration) is the electric motor itself.
  6. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    Friction braking starts at about 9 MPH normally. They will activate on panic stops. Regen increases with pedal pressure.
  7. Mr.Vanvandenburg
    1,358
    586
    2020 Prius Prime
    Before I disagree, I want to say I view these forums as places for discussion, and disagreement should be viewed as impersonal. If I am wrong, fine, if right also fine, it isn't important to me who is right or wrong, just to learn.
    The brakes work like normal brakes, all the time, I'm pretty certain. I am pretty sure this would be a safety requirement in any case. One of my reasons to believe this is in the manual where it states don't rest your foot on the brake to prevent premature wear. So even the slightest pressure works the brakes, according to the factory. Even just from driving I can tell this. At a stop it is necessary to press the brakes to avoid creeping, and before the system is even started the brakes must be applied. They do apply at these times. It seems the pedal is connected to the pads and shoes by the electric booster and hydraulic system, similar to any car except they use a vacuum booster. In light braking I can often hear the pads scraping the rotors. I am open to learn more, maybe this is all wrong, but don't think so.
    Using "B" would only waste energy, as why use the ICE air compression as a brake, when what is desired is for the generator to do that as much as possible? I thought B was mainly for descending steep hills, since there is no "lo" or "2" gear, or ICE engagement otherwise.
  8. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
  9. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    I think mine sounds just a bit like a jet engine, when I'm gliding downhill... I like it :D
  10. Tideland Prius
    16,611
    <div class='quotetop'>QUOTE(Mr.Vanvandenburg @ May 28 2007, 12:22 PM) [snapback]451071[/snapback]</div>
    That's because you've described low speed situations.
    Pressing the brakes to avoid creeping is correct. The brake pads are activated and chances are, you're creeping below 8mph.
    When you're stopped (or parked), pressing the brake pedal activates the brake pads.
    Pressing both brake pedal and accelerator also activates the brake pads.
    Now you're thinking. What about emergency situations then? You mention safety as a concern. If needed, the electric motors are bypassed and it goes straight to friction brakes. Rest assured, Toyota has you covered.
    If you don't believe us that the brake pads are NOT activated, when you go for your 10,000 mile routine service, ask them to check your brake pads and tell us how much life there is left.
    If the brake system was working like a rnomal car, you should have the same amount of life left (give or take) as your previous car.
  11. wiiprii
    wiiprii New Member
    148
    The Prius brakes are different from any other car. In other cars I am always careful to not keep the brakes depressed for more than a second or two when going down a steep hill, in order to not heat up the brakes too much. In the Prius, I can keep the brakes lightly depressed all the way down the hill, and charge the battery that way. The pads aren't being used, only the regen system, so it's perfectly safe. The pads only come in to play if I slam on the brakes, which I try not to do unless in a panic stop situation, which has happened to me once recently on the freeway, where I had to slow from 55mph down to 35mph in an instant because of traffic in front of me. Fortunately there was no car in the next lane, where I went to avoid hitting the car in front of me.
    Dave
  12. Mr.Vanvandenburg
    1,358
    586
    2020 Prius Prime
    It does not say when the brakes are pressed the hydraulics are not activated. It says there is regen braking when the accelerator pedal is released, and additional hydraulic braking when the brake is depressed. Brake pedal pressed=hydraulic action to whatever degree. Similar, but different due to generator resistance, to any other car. It is totally false that friction brakes only are used below nine mph, that is very tough to believe, that one. I think they are always used to some degree but less than a normal car.
    As to "B' I refer to p.146 of the owner's manual. It (Toyota, not me) states "B" is for additional ENGINE braking, and may reduce economy, (it states, not me.) Rotating the engine is just like driving an air compressor, a waste of energy. Sounds logical to me.
    This site is Toyota?
  13. Tideland Prius
    16,611
    <div class='quotetop'>QUOTE(Mr.Vanvandenburg @ May 28 2007, 03:03 PM) [snapback]451131[/snapback]</div>
    Unless you can prove otherwise, this is how we are told it acts. My brake pad life also confirms what we've been told. I drive nearly 100% in the city and at the 16,000km mark, I had 90% life left in the front pads and 95% in the rear. You can't tell me that the pads were activated it all the time (lightly or not) and still managed to be nearly brand new after 16,000kms.
    How 'bout this. Try this experiment.
    1. Make sure no one's behind you. It's probably best to try it on a residential street
    2. Accelerate to a good speed (whatever you feel like. 20km/h sounds reasonable)
    3. Brake like you normally would
    4. Shift to N while braking. If all goes according to plan, you should feel a jerk as the regenerative braking is "cancelled" and the brake pads grab the rotors and brake. (This is why I said brake normally and not lightly in case you might argue that light braking means light pad braking too which may also evoke the same motion. But if you brake normally, then the pads should already be in full contact with the pads if they're working as you've described).
  14. jalynn2
    Downingtown, PA
    Thanks for all the info on the electric motor noise. I'll just ignore it now.
    Joe
  15. IsrAmeriPrius
    4,333
    Southern California
    Sorry, you are still wrong.
  16. Frank Hudon
    Frank Hudon Senior Member
    4,147
    if you download the NCF manual from the Toyota site and read up on the braking system in the Prius you will see that the design uses what is called a stroke simulator and the purpose of it is to allow for a small amount of brake pedal depression without applying pressure to the hydraulic part of the brake system and allows for a rheostat that is connected via the CAN to tell the computer to use regeneration via the MG's to slow the car. When you press thru the stroke simulator you activate the hydraulic portion of the brake system. This is quit easily viewed if you have CAN-view or another device that will read the brake pressure along with the regen current.
  17. Mr.Vanvandenburg
    1,358
    586
    2020 Prius Prime
    Yes this device is described in the training manual link someone posted p.5-10. Just what is the amount of stroke during zero hydraulic pressure? So far I have only seen agreement to what I first said, there is braking through both sources when stopping, according to need from each. They call it cooperative braking in the manual posted above. A normal car also has a small pedal dead spot or "play" from rest. It would have to be this way to avoid pads constantly touching rotors. MG2 doesn't have pads so can start working immediately fom zero.
    It is very hard to believe the friction brakes only work at 9 mph and below, which is what is being said, and I believe I was questioning in the first place. The MG2 only works on the front axle, (someone must agree with that) so when hitting the brakes, at say 60 mph, there would only be front wheel braking. That would be the pits. The EBD would also have no function until below 9mph as the back brakes are dead till then, according to these beliefs. That is a waste of EBD technology and not likely. It makes no sense whatsoever to me. I have had enough arguing about it.
    This site needs to upgrade it's server. :(
  18. Frank Hudon
    4,147
    the total travel of the stroke simulator is about 20% of the brake padal travel. Once thru it your into hydraulic braking. Till then you can get about 55 Amps of regen which is about 45% of the total available with further brake pedal travel. If you don't exced the limit of the stroke simulator you don't have any hydraulic pressure and if you don't need more braking than that amout of regen produces you won't have the pads on the rotors till 9 miles an hour. You can actually feel the brake take over just by using light pressure and watching the speedo and when you go thru 9 you'll feel the hydraulic brakes take over.
  19. Tideland Prius
    16,611
    <div class='quotetop'>QUOTE(Mr.Vanvandenburg @ May 29 2007, 02:04 PM) [snapback]451668[/snapback]</div>
    Well, there's still the rare chance that you need to brake harder or perhaps there are people that don't give a damn about regen and brake hard anyway. It won't be wasted on those people's vehicles.
    Yeah, it does need an upgrade :(
  20. bmwquickspeed
    bmwquickspeed New Member
    Scottsdale
    If you regen for the first 20% of the brake pedal why would you need engine braking when you are going down a steep decline?
    You would not be using friction brakes to keep your speed down and would be taking advantage of regen braking going down the decline.
