PriusChat's new server - post your bugs here
Discussion in 'Gen 2 Prius Main Forum' started by Danny, May 31, 2007.
  1. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    For some reason my DNS cache still had a 24 hour time-to-live on the
    old A record for priuschat, but once I kicked it the new info
    showed up. Did you shorten the TTLs in advance of migration?
    My only regret would be that you've moved to something under
    Liquidweb's purview -- they have a history of catering to spammers
    or at least letting them do their thing, and have been in my mail-
    server deny file for many months now. This means, until I figure out
    if there's a way to special-case for it, that priuschat won't be
    able to send me mail at home.
    Hopefully the provider's reputation will remain separated from
    priuschat's one, but please keep an eye on things..
    _H*
  2. robincx
    robincx "Fear is the mind killer"
    1,294
    North Boston, NY
    New avatar upload to replace missing one is not working.
    Thanks for the bandwidth!
  3. daniel
    14,487
    1,519
    Spokane, WA
    <div class='quotetop'>QUOTE(Family Hybrid @ May 31 2007, 03:21 PM) [snapback]452854[/snapback]</div>
    Same here.
    "The requested file upload failed because suitable permissions have not been enabled on the 'uploads' directory. Please contact the board administrator and inform them of this error."
  4. Danny
    Danny Admin/Founder
    7,093
    2,120
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    <div class='quotetop'>QUOTE(hobbit @ May 31 2007, 08:14 PM) [snapback]452898[/snapback]</div>
    Hobbit - I wasn't aware of the spammer issues with Liquidweb. We are actually leasing the server through a 3rd party, and they are managing the server for me. I'll make sure they keep an eye on the spamming issue. Hopefully PC's IP address won't hit a blacklist - I had that problem with 1&1 and Verizon, but was able to get PC placed on the whitelist after I appealed. I can give you the direct IP address if you want to add it to your whitelist.
    The avatars & uploads are connected - so once one is working, so will the other.
  5. Neicy
    Neicy Member
    834
    Wakefield, MA.
    Thanks Danny for all your efforts. It's much appreciated. Everyone just needs to be patient as these things take a little time to work out. It's not even 24 hours yet!
  6. hobbit
    4,089
    469
    Bahstahn
    If it's always going to be at 72.52.166.5 and send mail directly from
    there, then that's easy. Hmm. Why don't I try to send myself a test
    msg and see what shows up in the log...
    _H*
  7. h2photo
    h2photo Member
    432
    Chandler, AZ
    wow, for once i didnt get an server busy while logging in! I LOVE PC!
  8. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    <div class='quotetop'>QUOTE(paulccullen @ May 31 2007, 10:00 AM) [snapback]452575[/snapback]</div>
    AAAAahhhhh!!
    Make it go away again!!
  9. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    Ditto on "can't upload a new avitar"
    just reportin' them bugs :D , ya'll !!
  10. jag
    jag Junior Member
    When I go to the Prius store, the text is there but no pictures. I am running a G5 Mac. Does this make a difference? Everything else works well and is much faster. Thank you, jgillas
  11. barbaram
    barbaram Active Member
    912
    70
    Trenton, NJ
    avatars
    some are missing- some are not....
  12. jamarimutt
    jamarimutt New Member
    985
    Happens with Safari and Firefox. :(
  13. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Hadn't been able to view the site for 24 hours. Tried the modem reboot w/o success so I assumed the upgrade was still ongoing. Finally found Kow's solution of using "72.52.166.5 priuschat.com" in the Windows/32/..... file and that fixed the problem on this PC.
  14. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    PC shop link throws the following error in Firefox 2.0.0.4:
    "priuschat.com has sent an incorrect or unexpected message. Error Code: -12263"
    After clicking on the error multiple times the page opens without graphics.
  15. MarinJohn
    MarinJohn Senior Member
    3,945
    304
    New day, new (bug). Spider in the bathtub was so big and hairy that I gave it to the local science teacher to have her class ID it.
  16. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    <div class='quotetop'>QUOTE(jgillas @ May 31 2007, 09:38 PM) [snapback]453061[/snapback]</div>
    I couldn't actually pay for what I wanted... hope it's all still in my shopping cart....
  17. Danny
    Danny Admin/Founder
    7,093
    2,120
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Ok, everybody. The uploads/avatars problem should be fixed.
    We're still having troubles with the PC Shop, so if you want to order anything, please send an email with the products you want to buy to [email protected]. We can send you either a Google Checkout invoice (preferred), or a PayPal invoice via email - please note your preference in your email to the Shop.
  18. dogfriend
    7,512
    1,190
    Carmichael, CA
    Don't know if this is related to the server upgrade or not:
    In my PM control panel, I can see messages in my Inbox, but my Sent Items folder is empty even though I have sent PM's within the last 24 hours. Are the sent messages normally saved to my Sent Items folder? Or do I need to change the setup somehow?
    Thanks
  19. Danny
    Danny Admin/Founder
    7,093
    2,120
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    <div class='quotetop'>QUOTE(dogfriend @ Jun 1 2007, 03:45 PM) [snapback]453452[/snapback]</div>
    It's actually an option you have to check whenver you send a PM - they don't save automatically:
    "Add a copy of this message to my sent items folder"
  20. dogfriend
    7,512
    1,190
    Carmichael, CA
    <div class='quotetop'>QUOTE(Danny @ Jun 1 2007, 01:28 PM) [snapback]453499[/snapback]</div>
    Ok. Thanks. It works differently than the other forum that I'm used to.
