Open Question on Fuel Dilution
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dmckinstry, Jun 9, 2007.
  1. dmckinstry
    dmckinstry New Member
    1,034
    Cheney, WA (Near Spokane)
    This question is aimed at people like Galaxee, Hobbit, Jayman and Bob Wilson, but there are several of us who would like knowledgeable answers from anyone.
    There are at least a few of us who have had used oil analysis done and discovered fuel dilution in the oil, resulting in decreased viscosity. My sample at 4950 miles (since the previous oil change) was supposedly diluted to the point where the viscosity was down to 10.0.
    It seems unlikely that a bad sampling technique would result in that much dilution. I know Jayman has been an advocate of oil testing and hasn't noticed dilution from his test results.
    Is there a special technique that minimizes getting a false reading on oil dilution?
    Assuming the dilution isn't false, what are the possible causes?
    I know a faulty PCV valve can result in a rich mixture, but would it be enough to cause "severe" dilution over several thousand miles of driving? It the ICE running too cool to evaporate away fuel in the oil?
    I haven't gotten any error codes indicated by CAN-View.
    Does anyone have any ideas?
    Thanks for any feedback.
    Dave M.
  2. John in LB
    John in LB Life is good
    399
    27
    Orange County
    I would suspect the engine not getting hot for long enough time... especially if you are a high MPG seeker. You could do an easy test of this by taking your sample (at around 5,000 miles), then drive the car at freeway speeds for an 1 hour or more. The idea being to make the engine run continuously and to get the oil nice and hot... as well as give any light ends enough time to boil out. Upon completion of the trip, take a second sample. send them both in and compare them.
    If engine temperature is the issue, then you should consider changing your oil more often... It just indicates that your driving style does not give the engine an opportunity to run hot long enough.
  3. dmckinstry
    1,034
    <div class='quotetop'>QUOTE(John in LB @ Jun 9 2007, 11:57 AM) [snapback]458774[/snapback]</div>
    It could be you're right. I will keep that in mind. On the other hand, the miles previous to the last 2 included 5 miles at 55 mph (in cruise control), and a previous 3 or 4 miles on an uphill stretch. Would a 2 mile cool down be enough to let that much dilution occur?
    Now it would be nice if some of the real hypermilers could do an oil sample to see if they have similar results or worse.
    Dave M.
  4. galaxee
    galaxee mostly benevolent
    9,810
    469
    MD
    bad PCV might not necessarily cause a rich mixture, but if the fuel vapor is not actively purged it's going be collected in the oil. so yes, that can contribute to fuel in the oil. ours will be done at 60k and i believe he put that in our "services you need and when" thread.
    the question is how does the fuel get into the crankcase? blow-by. severe blow-by is caused by piston ring wear. but any engine, even a new one, is going to have miniscule amounts of blow-by.
    other failures contribute to how much fuel gets into the oil- spark plugs that don't ignite the fuel, mass airflow sensors that cause the system to run rich, carbon buildup on valves or piston heads. there are a ton of things that can cause incomplete combustion. and the more fuel that's not combusted, the more chance it's getting into the oil.
    now if you honestly think there's a major problem with your engine, a compression test will tell you. this will tell you the condition of your valves and piston rings. you can even determine which of the two is at fault if there's a problem.
    all engines wear as time and mileage goes by- so you need to account for the fact that your rings will wear and allow more blow-by as time passes. this is just a fact of life. seals and gaskets and etc are technically maintenance items. they wear. DH's camry engine (i say engine and not car because the body's dead) came with a 7.5k mi oil change interval but since it has 140k on it, it's been every 3k since the day we bought it.
  5. dmckinstry
    1,034
    <div class='quotetop'>QUOTE(galaxee @ Jun 9 2007, 03:05 PM) [snapback]458864[/snapback]</div>
    Thanks for the feedback.
    If it is something like that, I will probably shorten my oil change interval. That's disappointing though, since my oil changes have always been within 100 miles of 5000 miles, and usually below that.
    If I shorten the change interval, it would be a waste to switch to Mobil 1.
    I'm not sure that I do think there's a problem with the engine, as I've had no performance problems that I can recognize. Also, never any error codes. I do use CAN-View. The mileage is generally close to 50 mpg, and noticeably higher on longer low speed trips, but slightly lower at highway speeds. The oil level at the time of the oil change is seemingly the same as just after the previous change.
    The oil test did indicate a large amount of sodium (204 ppm), but there was only minimal potassium present. And the test didn't indicate any water or antifreeze dilution. I'll have to find out the make of the dealer's oil to see if the sodium is a part of the normal oil.
    How difficult is a compression test on the Prius? On a regular car it's straightforward. If I have it done (or do it myself), it'll be a chance to apply some anti-seize lubricant to the plugs.
    Anyway. Thanks again.
    Dave M.
  6. John in LB
    399
    27
    Orange County
    <div class='quotetop'>QUOTE(dmckinstry @ Jun 9 2007, 12:35 PM) [snapback]458780[/snapback]</div>
    Unless you have a lot of miles (say more than 75,000 miles... and really 100K +), and given your comments about zero oil consumption, I would focus on the engine just not getting hot enough AND not long enough.
    Your comments about going 5 miles at 55 and 3 to 4 miles uphill... tell me as much. I was talking about 60 to 100 miles under load (say doing 65 to 80 MPH)... continuously. That's probably the easiest test you can do.... while enjoying the car too... :)
    John
  7. dmckinstry
    1,034
    <div class='quotetop'>QUOTE(John in LB @ Jun 10 2007, 12:43 PM) [snapback]459232[/snapback]</div>
    OK. This oil will have less than 1000 miles on it at the end of this coming week. I'm traveling to Nevada and California then. I'll stop at a rest stop after 3 or more hours of driving to take a sample. I got this last report as a pdf file via email, so I can access a new report while I'm on the trip. Also, I'll get a better idea of what kind of mileage I can get with my new tires. They aren't advertised as LLR, but they do have a rated pressure of 51 psi, and I'm now running them close to that. Actually, the trip won't have speed limits that let me go 80 mph, but I can probably get away with 75 mph without being pulled over.
    Thanks for the suggestion.
    Dave M.
  8. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(dmckinstry @ Jun 9 2007, 07:58 PM) [snapback]458892[/snapback]</div>
    Dave
    I did post a reply to the other thread about fuel dilution, and can only repeat that the sodium is almost certainly from the dealer oil. See if you can get a virgin sample off them, wishing you luck with that too.
    If you recall, my dealer oil had very high sodium too
    I take the sample at my hobby farm after driving 140 km, so in theory any moisture or fuel in there should have disappeared. But any excess moisture or fuel should also cause permanent viscosity loss. I believe you PM'd me awhile back stating your UOA had indicated substantial viscosity loss.
    What I will do this week is take a sample of the Mobil 1 0W-30 with around 7,000 km on it, with the motor cold and the Prius not having highway driving in quite a while. I'm now curious if this is a widespread Prius issue.
    Though if this was an issue, a lot of Prius cars in the EU with their normal 12 month/10,000 mile interval would have had problems by now.
    j
  9. Winston
    Winston Member
    614
    SF Bay Area, California
    Moving your car into your garage right before taking a sample is another way to ensure you get excess fuel in your oil.
    I have heard of some people having better luck with aftermarket air filters, in order to reduce fuel dilution. This is especially true for Honda engines. Fram makes good air filters.
  10. jayman
    13,439
    641
    Winnipeg Manitoba
    Before driving off to work this morning, I pulled a sample. The Prius has been sitting for over a week, and had been used for short city drives before that. Actually most of the Prius driving since I got my FJ Cruiser in March has been city only. I now use the FJ to drive out to the hobby farm.
    So if there is fuel dilution, I should have it by now.
