Automatic one touch window won't work. How do I fix it???
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dlroth, Jun 9, 2007.
  1. dlroth
    dlroth New Member
    I just picked up my 07 prius minutes ago and didn't check the one touch automatic down on the driver's side because of the tint. Oops. Of course, when I finally checked it, it doesn't work. Anyone know how to flip it on???
  2. alexstarfire
    alexstarfire New Member
    220
    You sure? If you only press it a little bit that the window works like all the others, and the one-touch feature happens if you press it all the way down, or pull it all the way up.
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Lower the window down and continue to hold the button down for 5 seconds after it's all the way down. Then raise the window all the way to the top and continue to hold the button up for 5 seconds once it reaches the top.
    You may need to repeat the process, but I think one cycle does the trick.
  4. AISpence
    AISpence New Member
    32
    Ohio
    <div class='quotetop'>QUOTE(dlroth @ Jun 9 2007, 07:20 PM) [snapback]458876[/snapback]</div>
    -Just a thought...you might want to check to make sure the "window lock" button is not pushed in. My windows weren't responding to me a few days ago and it turned out that I had hit the window lock button by accident. Hope this does the trick for ya! :)
  5. efusco
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(Angelique @ Jun 9 2007, 10:22 PM) [snapback]458981[/snapback]</div>
    I don't think the window lock button affects the driver's side window in my '04...have to check I guess. But the OP is talking about the auto up/down feature, not the function of the window if I read it correctly.
  6. dogfriend
    7,512
    1,190
    Carmichael, CA
    See page 43 in the owner's manual.
    If the dealer didn't initialize the power window, or if the 12v battery was disconnected after initialization, you need to normalize the power window .
