Car died on way home from 30K service!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by pycnanthemum, Jun 14, 2007.
  1. pycnanthemum
    pycnanthemum New Member
    I got my 30K service today on my 2005 Prius and on the way home the car stopped accelerating...on a highway...and then the "Problem!" light came on...and then I only had battery power...and then that ran out and I had to pull over.
    Now I am back at the service place and they are towing my car in. If they didn't have free wireless here I would be scratching someone's eyes out.
    Thanks for letting me vent :).
  2. jdenenberg
    jdenenberg EE Professor
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    <div class='quotetop'>QUOTE(pycnanthemum @ Jun 14 2007, 10:16 AM) [snapback]461498[/snapback]</div>
    let us know the "codes" that were reported and the repair suggested by the dealer. It is probably not a coincidence that the problem occurred as you were driving home after work was done on your car.
    JeffD
  3. pycnanthemum
    It is hard to believe this could have been caused by anything other than the service that was just done, for sure. We have never had a single mechanical problem with this vehicle, even though we had the stall recall (and of course had them fix that) we never had any problems associated with it. We did have damage to the vehicle after an accident but that was over a year ago and it came to this same service place for the repairs.
    I will ask for the codes and repair when they are done, I am sure they will love me even more after that! :)
    <div class='quotetop'>QUOTE(jdenenberg @ Jun 14 2007, 09:58 AM) [snapback]461532[/snapback]</div>
  4. pycnanthemum
    Ok, I am home now and the car is hopefully fixed, here are the details as I remember them:
    The service manager said a piece of leaf somehow entered the hose that brings air to the engine. The fragment made its way up to the air sensor (I forget the exact name for the part) and blocked any air from getting to the engine causing it to shut off. He said this happened when the service guy was changing my air filter, but very strongly stated that this was in no way the fault of the service guy, and that they haven't had something like this happen "for twenty years." They cleaned the hose and replaced the sensor even though they didn't think there was necessarily anything wrong with it, and will get warranty coverage from Toyota for that.
    Of course I was so hosed myself after the whole ordeal that I just took in what he said and made sure the car was ok and drove home...totally blanked about asking for error codes etc.
    I have the piece of leaf - will add photos later. Looks to be an oak leaf, it's dead and brown and about 1cmx2cm.
    I would like to believe what the guy said but part of me (the part that knows nothing about the inner workings of cars) thinks this sounds like exactly what would happen if someone did a shoddy job of replacing the filter and making sure no crud got inside on the wrong side of the new one!
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    I think freak things do happen. I wouldn't blame the tech here either assuming what you're being told is true. I just hope it's not a situation where they actually forgot to put the air filter in and that's what cause the leaf to be allowed in...that WOULD be his fault.
  6. Swanny1172
    Swanny1172 New Member
    666
    I call BS on their explanation. The only sensor in the area that you are talking about is the Mass Air Flow (MAF) sensor, which is used to determine the mass of air entering an electronically fuel-injected engine. However, I have never heard of an MAF failure causing an engine to shut down. Sure, it may cause your CEL to come on, but that is usually about it.
  7. tnthub
    tnthub Member
    519
    Brunswick, Maine
    I find it difficult to me that a leaf made it all the way past the air filter with enough pressure to "seal" the intake to the point of choking off the engine to the point of disabling the vehicle. I have seen enough filty air filters in my life to question the ability of a simple leaf to cause this type of problem.
    Most newer cars have a MAF and it is a highly sensitive device often with a few very fine hairlike strings running across on the inside with resistors on them. If those resistors are screwed up to the point where they are not accurate most engines will run rough but I have never seen one simply quit although i suppose it is possible for that to happen.
    Weird stuff and it sucks to be inconvenienced by such a freak thing.
  8. pycnanthemum
    Mass Air Flow Sensor - that is what the guy was talking about, they replaced it.
    Forgot to put air filter in, that is a very interesting theory...
  9. Swanny1172
    666
    The other thing is that every MAF that I have seen has had some of plastic screen on it on the air filter side to prevent any debris the filter might have missed from damaging the hot wire on the MAF. So, even if the leaf made it to the MAF, I highly doubt that it would have damaged it in any way.
  10. chinalfr2
    chinalfr2 Member
    234
    New England
    BS. This is purely a fault from the tech. I think the Service manager trying to cover his butt and his buddy tech butt.
    Another possible cause is when the tech removed the filter, got a long smoke break with the air filter covered open/exposed and dirts/leaves got in.
    Now you should be more concern that some dirt got suck into the engine and might cause more wear inside the engine. A good oil and oil filter change might be the safer.
  11. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    The MAF in the prius is fairly well protected -- that bit that sticks
    out into the intake throat grabs some intake air and shunts it way
    over into that module on the front where the connector is, and that's
    where the wires are. I looked at trying to proactively clean 'em
    and didn't have anything handy that's *small* enough to get in there
    ... not even a q-tip would fit. So the leaf, if the story is right,
    possibly wedged itself into the MAF intake port and disrupted the
    flow but probably didn't actually get into where the wires are.
    _H*
  12. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    DH had spent quite a bit of time chasing funky codes once due to a chunk of leaf in a MAF sensor after a prius was run through the express lube. so no, this is not bs and it's not anyone's fault other than the wind. unless, of course, they forgot the filter as mentioned.
  13. Swanny1172
    666
    <div class='quotetop'>QUOTE(galaxee @ Jun 14 2007, 11:11 PM) [snapback]462083[/snapback]</div>
    I don't doubt that a leaf could cause an incorrect reading from the MAF sensor and cause the car to throw some codes and turn the CEL on. However, I have never heard of a MAF sensor malfunction causing the ICE to stop running.
  14. galaxee
    9,810
    471
    MD
    i forget the running condition of the thing- i'll have to ask him tomorrow.
  15. pycnanthemum
    Plus it just seems like way, way too big of a coincidence to me that the first time this has ever happened to my car is immediately after I had an air filter change. I live surrounded by oak trees and it's darn windy a lot of the time too.
    How would a properly placed and brand new air filter allow a leaf fragment to pass through to jam in the MAF? Does the air filter not do what I think it does? Why wouldn't crud get sucked into the hose all the time?
    <div class='quotetop'>QUOTE(Swanny1172 @ Jun 14 2007, 10:18 PM) [snapback]462085[/snapback]</div>
  16. galaxee
    9,810
    471
    MD
    in the case DH worked on, the leaf got in there while the filter was being changed. hey, it happens. again, i don't recall how it ran.
    my old '90 buick had a bad maf sensor in it and it sure as hell died on me all the time.
  17. Swanny1172
    666
    The only way a leaf is going to make it to the MAF is when the filter is removed. With the filter in place, the leaf would have to move through the filter to get there, which is physically impossible. However, it is common practice to clean any debris out of the filter housing when you are replacing the filter. The best practice is to do this is with a vacuum, but I have seen it done with compressed air. The problem with compressed air is that it blows the debris everywhere -- including up the intake toward the MAF.
  18. rudiger
    rudiger Active Member
    696
    45
    Cincinnati, OH
    <div class='quotetop'>QUOTE(Swanny1172 @ Jun 15 2007, 06:52 AM) [snapback]462184[/snapback]</div>
    That would be my guess, too. The excuse "a leaf just happened to get up there somehow, but it wasn't the tech's fault" seems quite sketchy.
    Or maybe there was a cyclone going on in the service bay when he was changing the air filter...
  19. richard schumacher
    7,682
    1,063
    United States
    Everybody screws up sometimes. I would not hesitate to go back to that dealer for the next service. If something goes oops there again, then I'd try another dealer.
  20. hobbit
    4,089
    469
    Bahstahn
    Sometimes I pull up the filter element and clean off the bigger
    bits stuck to it by just whacking it against my hand ... but I try
    to stay away from the intake throat while doing that!
    _H*
