Ran out of Gas!!
Discussion in 'Gen 2 Prius Main Forum' started by alexilic, Jun 16, 2007.
  1. alexilic
    alexilic Member
    120
    Wauconda, IL
    So, my light started blinking yesterday afternoon. My first fillup last week(just bought the car 06/02/07) was soon after the light started blinking. It took 9.45 gallons. Knowing the tank is 12+ gallons, I figured it had at least a couple of gallons to go and at 45+mpg, you get the point. So, anyways, the tank starts flashing and I thought I'd be safe to go almost another 100 miles. Wellllll was I wrong. Midway thru my morning, I take off at a light, there was a puff type sound, and the power felt really low. A bunch of warning lights came on, and I'm thinking Wth did the porters do to my Prius to screw it up pre delivery. Then I notice no ICE, and tucked my head low figureing it was out of gas.. :unsure: and this after the girlfriend said I was stupid for "pushing it", she's a girl, what does she know.. :lol:
    I panic, but then realize I've got some battery left and maybe it could make it about a mile. The battery dropped really FAST! Couple of blocks and I was in purple, down to my last bar or two. I tried stealthing as much as possible.. Phew, made it to the gas station. Trying to fill it up was a pain in the beggining, it kept shutting the pump off. Finally after a few gallons it started taking it normaly. It took 10.834 gallons.. no more. What happend to the other GALLON +??!! My other vehicles went to almost exact if not over the posted tank size. I was a little disapointed.
    Is this normal?
    Alex
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Technically the tank is 11.9 gallons...not sure where you're 12+ came from.
    You really shouldn't count on more than 10 usable gallons...if you do you're destined to run out of gas due to the variability of the tank volume thanks to the bladder system it uses and the funkiness of different pumps and when they shut off.
    Just b/c you don't get a full 11.9 gallons in doesn't mean there was still gas in the tank. FYI I've never been able to get more than 9.4 gallons in my tank and I have over 60k miles on my '04. The later models seem to be improved, but not a lot.
  3. alexilic
    alexilic Member
    120
    Wauconda, IL
    <div class='quotetop'>QUOTE(efusco @ Jun 16 2007, 10:19 PM) [snapback]463255[/snapback]</div>
    Thanks Efusco. Just read some interesting stuff in the "fuel economy" forum. I should of read it before.. :) I guess I'm the type that needs to learn my leason the hard way.. :lol:
  4. kdmorse
    kdmorse Member
    205
    Germantown, MD
    Look at it this way - now you *know* how much gas is in your tank, exactly. There was none - now you added 10.834 gallons, so there is now 10.834. No excuses for next time :)..
    As others have pointed out, and as you noticed, pumps tend to click off quite a ways before the tank is 'full'. This tends to throw off people's idea of how much gas is left, just as it threw your numbers off. You assumed it clicked off at 12+, it probably clicked off at 10+ or so, and there's your missing gallons.
    The second time, yours clicked off early, and you were able to push it up to 10.8 gallons - probably because your fuel bladder is new and stiff. Mine (a year + old) usually clicks off at 10.5 gallons. And it varies from car to car, pump to pump, bladder to bladder, and by temperature. Many folks force in a gallon or more after the pump clicks off, but it's not wise to push it. Overfilling can be very, very bad for the car.
    When the last pip starts blinking you have (usually) less than a gallon left. You're not gonna make 100 miles on that - to be safe I wouldn't push past 20 (and others would recommend even less). It really is the car's Idiot Light, and it means go get gas, NOW!. Mine tends to start blinking with about 0.85 gallons left, my first few minutes of driving can be 30mpg or so, so I could well be dead 25 miles from the blinking pip.
    And don't make a habit of it. Pushing the hybrid battery down to purple, and below, is really not good for it.
    -Ken
  5. pingman
    pingman New Member
    124
  6. pewd
    pewd Clarinet Dude
    331
    Dallas, Texas
    the way the bladder works, you need to think of the prius fuel tank as being of variable size - not a fixed size like in traditional cars. e;g., every time you fill up the tank size is slightly different.
    when you get down to 2 pips, fill that baby up.
    or wait, and push your luck, giving the GF reason to say something to you ;)
  7. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Alex, welcome to the "Guess Gauge". Thank you for the valuable story. It probably won't deter the "next one".
  8. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    <div class='quotetop'>QUOTE(JimN @ Jun 17 2007, 09:58 PM) [snapback]463737[/snapback]</div>
    There's no guessing if you choose to accept the blink.
    For me, that usually happens around 8.25 gallons. Isn't that per-tank range enough?
  9. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    Obviously, you didn't have over a gallon left.
  10. Frank Hudon
    Frank Hudon Senior Member
    4,147
    wait till winter and it shrinks another gallon.
  11. subarutoo
    subarutoo New Member
    1,213
    Chatsworth, CA
    Girlfriends are almost always right, if not, listen to them anyway.
  12. bobofky
    bobofky Member
    107
    <div class='quotetop'>QUOTE(chitown guzzler @ Jun 16 2007, 10:09 PM) [snapback]463249[/snapback]</div>
    Fuel management is where the Prius differs most from conventional automobiles. The bladder in the fuel tank is designed to keep gasoline fumes from escaping from the gas tank. The capacity of the tank varies considerably depending on the ambient temperature because that affects the flexibility of the bladder. My 2001 Prius has over 90,000 miles and I have found that when the gauge begins to blink I need to head for the nearest station. I usually fill up before that situation occurs, usually when the second to last bar disappears. In the summer time I can drive over 100 miles before the first bar goes away. In the winter time it may disappear at less than 50 miles. The bars are inconsistent too. I consider the tank to hold 10 gallons and when my miles approach 400+ I begin looking for the next good gas station.
    You will adapt as you get more experience with your Prius.
  13. alexstarfire
    alexstarfire New Member
    220
    I got a quick question. Does the 2002 model Prius have a bladder? I was under the impression that all of them do, but after putting in over 11 gallons in my tank a couple of times, only once during the summer, I'm beggining to wonder. I've never gone more than 20 miles on a falshing pip, so it's not like I've been pushing it.
  14. ohershey
    ohershey New Member
    632
    <div class='quotetop'>QUOTE(subarutoo @ Jun 18 2007, 12:16 PM) [snapback]464177[/snapback]</div>
    Right or wrong - if you argue, you lose. Smile, nod, and take your beating like the <strike>dumb***</strike> man that you are....
  15. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    <div class='quotetop'>QUOTE(subarutoo @ Jun 18 2007, 03:16 PM) [snapback]464177[/snapback]</div>
    Reminds me of a plane that crashed in the woods on approach to our local airport years ago. It was a single-engine Cessna piloted by an elderly man with his wife riding shotgun. The cause was determined to be running out of fuel. Miraculously they survived. I imagined the cockpit conversation could have been, as they nosed down into the trees, "I told you we should have gotten gas in Fredericksburg!" :)
  16. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    Unfortunately, a lot of aircraft fuel-exhaustion accidents happen at night. One contributing cause is that many small airport fuel suppliers close at night. This makes it much harder for a pilot to find fuel after dark.
    It's still no excuse for trying to tempt fate. I was taught to only believe the fuel gauges when they said "E." Any other time, you compute fuel burn to be sure.
