MFD screen sticking
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by uncool, Jun 19, 2007.
  1. uncool
    uncool New Member
    I have had my 2007 Prius since October. Got about 5500 miles now. Before, I would press the audio or climate button and after a few seconds the screen would go back to the Info screen. NOW, the audio or climate screen stays on until I press another button.
    Why has it changed when I havent changed anything in the car?
    Anyone else have this problem?
  2. mmoncur
    mmoncur New Member
    32
    I don't remember the exact method of getting to it, but there's an option you can turn on/off for that. I think you hit "Info" and then "Settings".
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Yea, it's a user definable setting. I haven't messed with mine for about 3 years so can't remember the exact button sequence either, but it's not difficult to figure out.
  4. Annalog
    Annalog New Member
    <div class='quotetop'>QUOTE(mmoncur @ Jun 20 2007, 04:52 AM) [snapback]465122[/snapback]</div>
    That is correct. "Info", "Screen Setting", and then set "Automatic transition from Audio/Air Conditioner to Navigation / etc." or "Automatic transition from Audio / Air Conditioner to Navigation (if availble), etc."" to ON. The two versions of the text are from the 2007 Owners Manual pages 169-171.
    If you did not change the setting deliberately, it is possible that it changed if you cleaned the display while the car was on. I know I accidentally reset the trip information a couple times before I knew better.
