Having trouble seeing while backing up, even with b/u camera?
Discussion in 'Gen 2 Prius Main Forum' started by karen898, Jun 23, 2007.
  1. karen898
    karen898 New Member
    How are you all doing on backing up - can you all see out the rear window okay? Any suggestions? Right now, I'm using the kids as my back-up camera!
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Just try to get used to looking through both rear windows simultaneously....as you get used to it you don't even notice the spoiler splitting them any more.
  3. ystasino
    ystasino Active Member
    793
    Tucson, Arizona
    <div class='quotetop'>QUOTE(kjm @ Jun 23 2007, 05:31 PM) [snapback]466975[/snapback]</div>
    The camera covers a very wide angle. Turning your head left and right then checking out the camera is more than enough.
  4. Stev0
    7,201
    1,074
    Northampton, MA
    2022 Prius Prime
    When I first got my Prius, I *HATED* the view out the rear window. Now I'm used to it and don't notice it anymore. Just back up like you would any other car (although the camera is a godsend when it comes to parallel parking).
  5. gforeman
    gforeman New Member
    83
    I'm a mirror guy. I may peak at the camera to see how far I can get to an object, but usually I'm usung both mirrors.
    Guess that comes from driving a semi many years ago.
  6. PA
    PA Member
    427
    27
    Raleigh, NC
    2019 Prius
    To answer the question, "no".
    I use both mirrors and turning my head when backing up, and supplement with the camera (particularly when backing out of the garage to make sure no-one has run behind the car). It is no more difficult than any other car, and the camera just makes it easier.
