05 prius driveshaft GONE
Discussion in 'Gen 2 Prius Technical Discussion' started by statultra, Jul 4, 2007.
  1. statultra
    statultra uber-Senior Member
    798
    31
    Edison,NJ
    2001 Prius
    well not really gone, when u drive u hear a loud grinding upon moderate acceleration from the front right wheel, ( where the car got hit ) the slip indicator blinks a lot, any of you think the driveshaft is still good, i have the car sitting on jackstands in the garage, just wondering if wheel alignment issue could cause this ( i havent since it crashed )
    edit : scroll down for pics
  2. Godiva
    Godiva AmeriKan Citizen
    10,339
    The car was hit. It was in an accident? Do you have insurance? This sounds like it needs to go in for repair.
  3. statultra
    798
    31
    Edison,NJ
    2001 Prius
    it was salvage and i repaired it so far it has done 2300 miles no problems, now it wont drive u see the speedo going 1mph-7 and pulsating partial wheel motion.
  4. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    stat, take some pictures. not sounding good.
  5. bigscrb15
    bigscrb15 New Member
    17
    sounds like the cv axle is tore up. not a hard fix, at least on all the other cars i have seen, never tried to replace one on a prius.
  6. statultra
    798
    31
    Edison,NJ
    2001 Prius
    oh yeah, it either slipped out or broke, not sure until i take it apart, its so humid here in fort myers. this explains everything, why i get that jet engine drone, and that LOUD rattle during regnerative braking.
    heres a pic you can see it looked like it wrapped around the boot and decided to go bezerks. The parking mechanism wont engage, and as soon as i started the prius loud grinding from the right side ( which is the picture attached )
    if anything else looks abnormal in the pic please alert me to that, like control arms and stuff becuase im not sure
  7. bigscrb15
    17
    Yea, it is very hot around here, Im a little north of you though. That won't be an expensive repair.
  8. statultra
    798
    31
    Edison,NJ
    2001 Prius
    im going to go take it apart right now i managed to get te boot back to normal so im checking i tout
  9. galaxee
    9,810
    468
    MD
    owww. don't bother taking that apart, you need a driveshaft. the internal joint has let go.
    there's some rust on the subframe member there. probably from the collision. everything else looks ok from what he can see.
  10. 1fixitman
    1fixitman Member
    182
    Augusta, GA
    <div class='quotetop'>QUOTE(statultra @ Jul 4 2007, 05:50 PM) [snapback]473133[/snapback]</div>
    Average CV complete axle with a core replacement is $140. They will probably not accept your core so it may be about$80-100 extra. The shop will charge about $450-500 to complete this repair. I highly recommend you buy a hayne's manual($17) and do it yourself if not stressed for time. Most I see is about 250 without core. You will need to take a better picture of the control arm area and check for cracks on the tranismission/synergy drive. With the tire attached to the prius....jack it up so the tire is off the ground about an inch and grab the tire on the left and right side and shake it left and right and see if there is any play. Do the same for up and down. This is a great indication of the bearing set on that wheel having damage or not. Have the alignment checked after CV axle replacement and adjusted(I am positive it will need it). The alignment will severely affect MPG's if it is out and grind up the tire really bad. Not so experienced people can change a CV axle in about 10 hours. 3 hours or less for experienced mechanics with the proper tools. Good luck. I sympathize with you as I also have a salvage vehicle. 05 Prius as well.
    D Rock
  11. statultra
    798
    31
    Edison,NJ
    2001 Prius
    i opened the boot and a lot of stuff fell out, im gonna replace teh entire driveshaft myself heres pics
  12. bigscrb15
    17
    FYI- When you go to get a replacement, call it a CV Axle, not a driveshaft. The drive shaft is the piece that connects the transmission to the differential.
  13. statultra
    798
    31
    Edison,NJ
    2001 Prius
    i just took out the hub the entire damn thing broke, like the driveshaft assy the cv joint broke, then the driveshaft right before the cv joint, thats why the entire boot was wrapped around, tommorow ill take it out for a final diagnosis.
  14. galaxee
    9,810
    468
    MD
    make sure you've got some WS on hand, you might lose some when when you pull the axle out. get a couple of quarts just in case. the RH side is easier than the LH side, so that's a plus.
  15. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    That "lot of stuff" is what makes the CV work... it needs to all
    ride in a nice clean swill of grease, but I don't have to tell
    you that by now. It would be cool if you could get better lighting
    on the job and take more pix as you reassemble the new parts; I'm
    not entirely clear on how the axles go into the transaxle case and
    interact with the seals and actually stay in [other than happening
    to be just the right length once the knuckle is back in place].
    _H*
  16. NoMoShocks
    1,292
    82
    Camas, WA
    <div class='quotetop'>QUOTE(bigscrb15 @ Jul 4 2007, 07:32 PM) [snapback]473252[/snapback]</div>
    That right, for cars that have differentials. I embarrased myself a few days ago when I called and asked about a major service on my son's Toyota Corola. I asked if it included changing the oil in the differential.
  17. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    I don't understand. Your Corolla has a differential. It's inside the transmission casing, but it's there just the same. It -could- have separate fluid, though I would expect it is the same fluid as the transmission (manual). I would expect it to be separate in an automatic (different fluid requirement).
  18. statultra
    798
    31
    Edison,NJ
    2001 Prius
    ill take more pics as i go along, im searching for a 30 mm to take apart the hub so im stuck till then
  19. KTPhil
    KTPhil Active Member
    1,379
    With your speedo and slip indicator acting up it sounds like the wheel speed sensor is also broken.
  20. statultra
    798
    31
    Edison,NJ
    2001 Prius
    <div class='quotetop'>QUOTE(KTPhil @ Jul 5 2007, 11:24 AM) [snapback]473464[/snapback]</div>
    i thinkthe slip sensor came on because the back wheels were on the ground while the front wasnt ( i had it on jackstands)
