sweet gas
Discussion in 'Gen 2 Prius Fuel Economy' started by pingman, Jul 5, 2007.
  1. pingman
    pingman New Member
    124
    ok so yesterday i went 525 miles on a tank. :D the last block was still not flashing but did not want to chance it .i only had eight bucks on me and that got almost 3 gallons but its still on last block is that normal?
  2. pingman
    pingman New Member
    124
    OK?? wow dont all of you reply at once you might jam the server!!!!!
  3. douglas001001
    douglas001001 smug doug
    222
    Chicago
    <div class='quotetop'>QUOTE(pingman @ Jul 5 2007, 05:57 PM) [snapback]473720[/snapback]</div>
    Try searching on "guess gauge" or "gas gauge" you'll see that no one understands the gas gauge other than if the last pip is flashing that means "GET GAS NOW".
    There is a threshold for amount of gas added before the gauge resets, which it sounds like you were under.
    Enjoy PC!
  4. TonyPSchaefer
    14,816
    2,502
    66
    Far-North Chicagoland
    Hey Pman.
    I was going to respond but was intimidated by your avatar.
    The threshold for auto-reseting the gauge is three gallons. It sounds as though you were right here. Perhaps another half-gallon would have done it. At this point, you will just need to keep mental note of the amount of miles driven since the refill until you completely refill.
  5. pingman
    pingman New Member
    124
    <div class='quotetop'>QUOTE(TonyPSchaefer @ Jul 6 2007, 08:34 AM) [snapback]473940[/snapback]</div>
    thanks guys just wanted to know my prii was OK
