Crack or Seam in middle of my display
Discussion in 'Gen 2 Prius Main Forum' started by NoMoShocks, Jul 6, 2007.
  1. NoMoShocks
    1,292
    83
    Camas, WA
    I think the heat cracked my long Speedometer Idiot Light panel, but the crack is so straight, it almost looks like they intentionally made it out of two peices. The thing is, I have never noticed this before, and now it seems to really stand out like a sore thumb. If any of you confirm this is not supposed to be there, I guess I'll be making arrangements for a warrantee replacement. Nothing heavier than the accordian style window shade has ever been placed on the dash.
    So tell me, is this a crack, or a seam I never noticed before for some very odd reason?
  2. aaf709
    3,862
    2022 Prius Prime
    It's a seam between two pieces. I have that too in my 2005. It isn't obvious unless the lighting is right.
  3. TonyPSchaefer
    14,816
    2,502
    66
    Far-North Chicagoland
    Yeah, perfectly normal but mine is not nearly as detectable as the picture. Heck, when it was first reported a couple years ago, I had to go out into the garage and look real close to see mine.
  4. Green Hokie
    Green Hokie Member
    189
    Glen Allen, VA
    Same as mine. Pretty sure it's a seam. I was a little disappointed when I first noticed it just a few days after buying the vehicle (back in early March). However, I really don't even see it anymore and doesn't bother me at all now.
  5. NoMoShocks
    1,292
    83
    Camas, WA
    <div class='quotetop'>QUOTE(aaf709 @ Jul 6 2007, 08:26 PM) [snapback]474428[/snapback]</div>
    Mine has become very obvious. No special lighting required any more. I wonder if it was cemented together, and the cement gave way?
  6. Green Hokie
    Green Hokie Member
    189
    Glen Allen, VA
    Mine is not attached or glued together. When I clean around that area, both pieces move independently.
  7. dogfriend
    7,512
    1,191
    Carmichael, CA
    I've always thought that would make a good place to mount a battery charge indicator or a ScanGauge. It would hide the seam and its visible without blocking any warning lights.
  8. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    Maybe it's visible because dust is caught in the gap? I can barely see the seam in mine.
