Electronic Owner's Manual
Discussion in 'Gen 2 Prius Main Forum' started by orahm, Jul 8, 2007.
  1. orahm
    orahm New Member
    17
    Maui, HI
    Hi everyone, I was wondering if anyone has the 2005 Owner's Manual in electronic form for me to download or email. I would be thankful. I just got the 2005 Model used and it did not come with the manual. The prius 04, 06, and 07 are probably similar enough.
  2. Tideland Prius
    16,621
    yeah I have an 04 version.
  3. orahm
    orahm New Member
    17
    Maui, HI
    <div class='quotetop'>QUOTE(Tideland Prius @ Jul 8 2007, 11:43 AM) [snapback]475054[/snapback]</div>
    Could you send it per email "[email protected]" or can I download it from somewhere. I would really appreciate it. Is the nav described in it?
  4. Tideland Prius
    16,621
    <div class='quotetop'>QUOTE(orahm @ Jul 8 2007, 08:47 AM) [snapback]475057[/snapback]</div>
    I believe the nav is a separate manual. There is an online guide for the new nav system (and i'm sure 90% of the content is applicable to the old nav system).
    http://www.toyotaiguide.com/ and use the Camry as your vehicle and select the camry hybrid. When it asks if you have a nav system, click yes and once it's loaded, you can browse the nav section. It also has the nav manual in PDF.
