Green Glare in Windshield
Discussion in 'Gen 2 Prius Main Forum' started by forte88, Oct 26, 2004.
  1. forte88
    forte88 Member
    143
    44
    Socal
    I just picked up my 2005 Prius and love it. My wife has a complaint however, about the Speedometer. The speedometer reflects on the dash making a green line on the dash. The windshield picks this up at night and there is a green line in the center of the windshield from the reflection of the speedometer on the dashboard. (a reflection of a reflection) I seem to be able to ignore it without too much difficulty, but my wife says she keeps wanting to focus on it. This is only a problem at night. Does anybody else have this problem?
  2. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    Use the rheostat to dim the display down to the point that it will not reflect in the windshield.
  3. forte88
    forte88 Member
    143
    44
    Socal
    Haven't found that knob yet? Where is it located? Its only my second day driving it.. :oops:
  4. IsrAmeriPrius
    4,333
    Southern California
    It is a wheel at the bottom of the dashboard to the left of the steering wheel.
    I highly recommend that you read the owner's manual.
  5. betshsu
    betshsu Member
    302
    Washington, DC
    I wonder if this is a gender thing. I hate it when there is any reflection off the windshield, and the green glare bothered me as well, but it doesn't bother my boyfriend (also may be a height difference thing).
    Using the wheel to dim the dash will also dim the MFD, which is way too bright at night if you have Nav (white background). The really cool thing is that the car will remember this setting, so when you turn on the headlights, everything will automatically dim to night mode and brighten up again when you turn off the headlights.
  6. forte88
    forte88 Member
    143
    44
    Socal
    So far I have read the "Prius User Guide" but there was no mention in it about the rheostat knob. My wife says she took in the users manual into the house for some bedside reading, but haven't had time to pick it up and dig in yet. Most of the operations of the car seem to be for the most part self explanatory. Guess with this car the biblical method might not be the best.. "Seek and Ye Shall Find".
  7. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    If you find the MFD too bright it can be dimmed seperatly using the display function
  8. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    Forte, I'm sorry that this is such a crappy picture. I'm at work and don't have access to pictures other than those stored on my computer. In this picture, I have attempted to highlight the general area. If you squint and turn your monitor sideways, you might be able to see the bottom of the rheostat sticking out there from behind the steering wheel.
    It is much easier seen if you stand outside the car on the driver side, open the door, and look at the area of the dashboard behind the steering wheel.
    Good luck.
  9. forte88
    forte88 Member
    143
    44
    Socal
    Thanks to everyone that responded to this question.. and SO QUICK! As a new owner, i'm sure I'll be hanging around here for quite some time. Hopefully I will be able to return the favor someday. :)
  10. Prius Maximus
    Prius Maximus Senior Member
    956
    811
    Northeastern IL
    This green glare has also bothered me. I thought it was a reflection off the dashboard, so I went to put some felt over the offending surface. Lo and behold, there is no reflection off the dash. IT IS A PROJECTION. When you look at the speed readout, you are actually looking at a mirrored reflection. The glare on the windshield is actually the light from the image passing through a glass plate in the dashboard.
    After 21,000 miles, I'm still learning new things about this car.
  11. minkforce1
    ypsilanti
    i just picked up my '08 prius hours ago, and as soon as i got dark i started swearing when i saw the green glare. i'm going to try some of the fixes i saw in another thread, im a little surprised that a detail like this got overlooked when it obviously bothers so many people.
  12. fed123
    fed123 Member
    120
    New Jersey
    2024 Prius Prime
    The knob below left of the steering wheel should allow for you to adjust the glare away as well as light up the CD player and radio,
  13. Stargate Cat
    Stargate Cat New Member
    Raleigh-Durham, NC
    This glare problem was driving me CRAZY! I recently bought my Prius (2007) and my daughter and I drove it from Raleigh, NC to Albany, NY (college visit). We mainly drove after daylight hours and through the night. The green glow was DIRECTLY in my line of sight - - for 10 hours - - each way! And I agree about the dim steering wheel buttons - very inconvenient.
  14. mt2020
    mt2020 Junior Member
    Boston area
    Has any one found a permanent fix for this green glare. Has anyone talk to a dealer and gotten a good answer. Does Toyota know about this, it has to be considered a hazard.
    any new info. helpppp
  15. FBear
    FBear Senior Member
    355
    Maplewood, NJ
    2015 Prius v wagon
    Hey guys there is a rheostat (a little knob or wheel like thing) on the dash board that adjusts the brightness of the display. All that is need is, at night when the all the lights are on, is to fool around with the wheel until the glare is gone but you can still read the instrument display.
  16. qbee42
    3,081
    This is an old problem, and it is related to the design of the Prius. Certainly the dealers and Toyota know about it and factored it into the design of the next generation.
    As for a fix, you have three options:
    1) Change your seating position.
    2) Turn down the brightness of the display.
    3) Place a black cloth on the dash.
  17. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
  18. edthefox5
    edthefox5 Senior Member
    10,096
    4,836
    Clearwater, Florida
    The lights on the dash are super bright in the rheostat detent position.
    If your so blind you cannot see it without it being on full blast you have bigger problems.
    Turning it off detent you cannot see the green in the windshield. And its still really bright.
    The knob is right where it is on most cars. left side of dash. There's very little else next to it.
