EV Mode Mod Quick Question
Discussion in 'Gen 2 Prius Accessories & Modifications' started by SureValla, Jul 14, 2007.
  1. SureValla
    SureValla Member
    590
    Shelton, CT
    Am I correct to assume that this voids the warranty?
    If so how does Toyota know? and if they can is it just as easy to remove?
    Thanks
  2. diamondlarry
    diamondlarry EPA MPG #'s killer
    559
    Elkhart, IN
    <div class='quotetop'>QUOTE(SureValla @ Jul 14 2007, 07:02 PM) [snapback]478798[/snapback]</div>
    Toyota, or any other manufacturer for that matter, must first prove that any problems were caused directly by an add-on.
  3. SureValla
    SureValla Member
    590
    Shelton, CT
    also is there any reason not install it?
  4. diamondlarry
    559
    Elkhart, IN
    <div class='quotetop'>QUOTE(SureValla @ Jul 14 2007, 08:33 PM) [snapback]478841[/snapback]</div>
    I can't think of any reason to not install it other than the fact that you may have to pay someone to do it for you if you weren't comfortable doing it yourself. Or maybe if you drove 90% or more on the highway it may not be worth the installation. Anyone else?
  5. brick
    brick Active Member
    1,083
    79
    Upstate NY
    I installed the Coastal version and like having it. Its true utility is relatively limited but it does come in handy.
  6. SureValla
    SureValla Member
    590
    Shelton, CT
    I read somewhere that EV mode may damage the battery because its being discharged faster then usual?
    Any thoughts on the truth of this claim?
  7. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(SureValla @ Jul 14 2007, 09:30 PM) [snapback]478897[/snapback]</div>
    Easy answer is "No"...it's not true.
    Long answer is that the car has built in systems that will cancel EV if it's used too agressively or if battery SOC gets too low.
    Alternate answer is 'Yes'. If you were determined to make it ruin your battery then, over a long time, with intentionally abusive use (drive to high SOC, engage EV at low speed and drop the SOC as low as possible, then drive to high SOC, then drop down while in EV again many times daily over a few years of ownership) you would probably shorten the life of the battery. To what degree is probably impossible to determine and is probably not measurable.
    For probably the 100th time....
    The benefits of the EV button are not adequate to justify adding it if you are not prepared to pay non-warranty replacement of your battery or HV ECU or Inverter should they be damaged and that damage is alleged or shown to be due to the EV button. I seriously doubt you or anyone else will ever need to pay such charges and I seriously doubt Toyota will ever try to deny appropriate warranty coverage to someone just b/c they have an EV button installed. But even with perfect use the EV button offers only minor MPG benefits, with imperfect use could reduce MPG, but all in all it's probably a wash for most drivers. It's a fun toy though. I'm one of the first people in the US to install the mod...probably the 2nd or 3rd person to do it. I love my OEM EV button and use it a few times on every commute. I'm not at all worried about warranty issues. But I have the financial where-withall to pay the cost of repairs if there ever is a problem. Not everyone else is.
  8. SureValla
    SureValla Member
    590
    Shelton, CT
    <div class='quotetop'>QUOTE(efusco @ Jul 14 2007, 10:38 PM) [snapback]478901[/snapback]</div>
    I'm having trouble with the voided warranty conundrum. Why is it covered in cars that are sold in Europe but not when you install it yourself in North American cars?
  9. efusco
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(SureValla @ Jul 15 2007, 09:14 AM) [snapback]479060[/snapback]</div>
    There are a number of reasons postulated and hinted at as to why we didn't get it as a standard option in the US. One has to do with emissions, with increased use of the EV button the Cats and emission controls could get too cold to work properly. The longer, esp. California, emissions regulations requiring the HV system to be warranted for 150k miles probably caused them to hesitate so they didn't have to risk possible premature battery death and replacement. The warranties are not as long in the EU.
    But, the bottom line is that it doesn't matter "why"...it just is. You can accept the risk or not...I, personally, think the risk is next to zero, but it isn't "zero" and you have to be willing to accept that if you choose to install the mod.
  10. SureValla
    SureValla Member
    590
    Shelton, CT
    <div class='quotetop'>QUOTE(efusco @ Jul 15 2007, 10:21 AM) [snapback]479065[/snapback]</div>
    interesting. Thanks for the information and help!
