Air Filter
Discussion in 'Gen 2 Prius Main Forum' started by partsdart, Jul 16, 2007.
  1. partsdart
    partsdart New Member
    Has anyone added a K&N air fliter to improve mileage or response?
  2. rubencisneros
    rubencisneros New Member
    Grapevine, TX
    <div class='quotetop'>QUOTE(partsdart @ Jul 15 2007, 11:09 PM) [snapback]479430[/snapback]</div>
    I have and I have not notice any difference.
    Ruben
    chronon likes this.
  3. Gadgetdad
    Gadgetdad New Member
    462
    Modesto, California
    <div class='quotetop'>QUOTE(partsdart @ Jul 15 2007, 09:09 PM) [snapback]479430[/snapback]</div>
    I did too, but also no dramatic results to note. I am considering using the K&N in the winter months and Toyota's stock filter in other months like an earlier post in another thread recommended. That post said K&N is better for moist air, but Toyota's part filters to a smaller particle size. Around here, moist is Nov. to April, but If you live in the East, moist seems most of the time!
    Any body care to comment about K&N?
    chronon and Tbkilb01 like this.
  4. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    OK, here goes. K&N have removed their million mile warranty unless you install their "pre-filter". Make your own conclusions about this re filter effectiveness. I have never had a problem with K&Ns. I don't think they have a "pre-filter" for the Prius.
  5. chronon
    chronon Active Member
    601
    106
    here and there aint be in frozen wasteland no mo..
    sho nuf yest got my k&n knockoff .. man it be so cheap ias a reuseable it about as cheap as a throw -away .. but i dont see much g/s increase .. if i had to say .. it would be less than 1g/s increase or less ..
    the big advantage is reusing it .. like the previous guy said .. larger particles will get through meaning more dirt .. so in a dusty useage area .. that would be disadvantageous .. -- but lik ethe guy said .. the moist air (ie humid place like coastal) -- the water particles will be comeing in better (not that there is much energy in them -- just that they wont bet stopped as bad as on an OEM filter) -- --
    -- the other claim to fame with this knockeff is not having to use an 'oiler kit ' -- k&n sells a degreasing and then regreasing(oiling) spray kit to use on their reuseables every 10k miles or so ..
    -- generally k&n is performance oriented so .. nuthin much perf. about 0 to 60 in 11 seconds so ..
    apply as needed to your givin situation , circumstances and environmental factors ...
