Toyota Hybrid Supra participates 24 hour race in Japan
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by ken1784, Jul 15, 2007.
  1. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    I'd really like to see some stats. Were they able to run with a pit stop less than the other teams? Did they use less gas? Was acceleration out of the corners better. Was brake temp/wear reduced due to regen braking?
    And, most importantly, did they have an EV button!!
  2. wvkrug
    wvkrug New Member
    <div class='quotetop'>QUOTE(efusco @ Jul 16 2007, 08:38 AM) [snapback]479535[/snapback]</div>
    Probably had an EV button, plug-in recharge, and unlimited character display for the Sirius.
  3. statultra
    statultra uber-Senior Member
    796
    30
    Edison,NJ
    2001 Prius
    considering the fact that this car is a hybrid i could only imagine the amount of gas saved during deceleration
  4. dbermanmd
    dbermanmd New Member
    8,553
    manhattan
    <div class='quotetop'>QUOTE(usbseawolf2000 @ Jul 15 2007, 10:39 AM) [snapback]479069[/snapback]</div>
    I pre-ordered a 2009 Supra at my local Toyota dealership last year. I would be more than happy with something like this.
    I hope its a plug-in too :)
  5. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    408 hp Volta powertain in it? More questions than answers. :D
    Edit: NM, this Supra has V8. Volta had V6.
  6. Godiva
    Godiva AmeriKan Citizen
    10,339
    So I gather you race for a specific amount of time and whoever has the most laps wins?
    I would think a hybrid would easily win since it would have less pitstops for gas.
    I would like to see a comparison of pitstops and of mileage.
  7. ken1784
    ken1784 SuperMID designer
    2,940
    1,365
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(efusco @ Jul 16 2007, 09:38 PM) [snapback]479535[/snapback]</div>
    Hi Evan,
    Thank you for the racing stats update during I was out.
    http://www2.neweb.ne.jp/wd/tms/tokachi/index.html
    They saw 10% improvement on the fuel economy and brake pads wore a half than expected.
    http://www.sard.co.jp/race_r/r2007/news/20070715.html
    I thought the Supra is a parallel hybrid, but they said they did EV only pit-start, then the engine fired later for further accelerating.
    Ken@Japan
  8. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    wow. cool
    [using a wii]
  9. efusco
    19,891
    1,192
    Nixa, MO
    <div class='quotetop'>QUOTE(ken1784 @ Jul 17 2007, 12:34 AM) [snapback]480082[/snapback]</div>
    That's amazing...10% increase in FE is huge in a race like that....imagine one team getting 10% better FE in a NASCAR race (granted the oval isn't going to have the slowing/acceleration pattern of the course the Supra won on), but that's just a tremendous improvement in a race like that.
  10. usbseawolf2000
    14,487
    2,997
    Fort Lee, NJ
    10% better fuel economy and 20 laps lead? Awesome!
  11. alexstarfire
    alexstarfire New Member
    220
    <div class='quotetop'>QUOTE(ken1784 @ Jul 17 2007, 01:34 AM) [snapback]480082[/snapback]</div>
    Too bad I can't read Japanese.
  12. ken1784
    2,940
    1,365
    67
    Yokohama, JAPAN
  13. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    Capacitors? Interesting. Are they significantly lighter than batteries? Can you tell us more about them?
  14. usbseawolf2000
    14,487
    2,997
    Fort Lee, NJ
    <div class='quotetop'>QUOTE(ken1784 @ Jul 17 2007, 11:22 PM) [snapback]480686[/snapback]</div>
    Wow. This hybrid is a completely new animal. The 150 kW electric motor is mounted at the rear axle. The electric motor is not slapped next to the engine like in Honda IMA. It seems the 150kW electric motor is behind the transmission. Gas Engine -> Transmission -> 150kW motor -> Rear Wheels. IMA set up is like Gas Engine + 15kW motor -> Transmission -> Front Wheels.
    Front two wheels also have in-wheel motors. This setup basically make the Supra HV-R four wheel drive electric car! All four wheels can be powered purely by electric power alone. In this racing set up, they are powered by the capacitor pack for a short distance. This explains the EV mode usage reported earlier.
