Vent on the little triangle window
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Marvinh, Jul 19, 2007.
  1. Marvinh
    Marvinh Marvin
    190
    NY - Long Island
    The little triangular shaped window in the front A pillar has a vent running along the bottom. However, when I put the front defroster on, I don't feel any air coming from this vent. Does anyone know if this vent is supposed to blow air in defrost mode, or when it is active?
    Thanks - Marvin
  2. Marvinh
    Marvinh Marvin
    190
    NY - Long Island
  3. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    Um, not a clue yet. I can play with it when I get in my car....
  4. richard schumacher
    7,664
    1,046
    United States
    I'll bet it doesn't blow unless it's cold outside.
  5. KMO
    KMO Senior Member
    1,947
    676
    Finland
    2023 Prius Prime
    It certainly works, but the airflow isn't much (and it doesn't need to be). Those triangle vents and the round side window vents both operate at the same time as the windscreen vent.
    According to the New Car Features document, window airflow is slight when FOOT is selected, medium when FOOT/DEFROST is selected, and most when DEFROST is selected. It's shut off when FACE or BILEVEL is selected.
  6. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    It works when "feet only", "feet and windshield", and defrost airflow selections are made. Basically anytime the little round dash vent it working. Page 291 of the manual indicates this, although it doesn't specifically show the vent you speek of. But that's when it works.
  7. acdii
    acdii Active Member
    1,124
    131
    cant seem to get the shipping plastic off the plastic piece, neither can the dealer.
  8. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    <div class='quotetop'>QUOTE(ACD @ Aug 28 2007, 09:48 AM) [snapback]503204[/snapback]</div>
    Easy. You need to pop off the entire triangular plastic cover first though.
    Use a flathead screwdriver or something like that, pry out one edge and bring it upward.
    It's held in via plastic prongs. Very simple to take out and put back in.
    Be careful not to scratch the plastic.
