battery problem!
Discussion in 'Gen 2 Prius Technical Discussion' started by cemax12000, Jul 19, 2007.
  1. cemax12000
    cemax12000 Junior Member
    I have a 2007 Prius with 5000 miles on it. After sitting for 5 days while I was out of town. It was completely dead. Nothing came on, not even the lights. I called the dealer and he aid that they are not meant to sit for more than a couple of days or the computers will run the battery down. He suggested I put it on a trickle charger, as I did, and it seems to be charging fine. Anyone else had this happen or is the dealer just blowing smoke. :angry: :angry: :angry: :angry: :angry:
  2. qbee42
    3,081
    Another stupid dealer. A Prius can sit for weeks without draining the battery, unless something was left on. I always lock the doors just to make sure no doors are ajar. If you are going to leave it for an extended time, you can turn off the SKS by pushing the button under the steering wheel.
  3. Betelgeuse
    Betelgeuse Active Member
    1,460
    24
    New York, NY, USA
    You should be able to leave it for ~2 weeks without doing anything. As Tom says, if you want to be extra careful, you can turn off the SKS, but you probably should only need to do that if you're not going to be driving it for 2+ weeks. My guess is that either you left something on (i.e. one of the inside lights), or you have a bad 12V battery. One of the Prius's (only) achilles' heels is the small 12V battery; this means that it's much more subject to draining by lights, etc. than in conventional cars.
    I've left our '05 for ~2 weeks (leaving the SKS on) with no problems.
  4. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Be aware that there is a secret screen that displays 12V battery voltage on the touchscreen display.
    http://www.trilug.org/~chilcote/ToyotaPriu...s-controls.html
    There are other ways of activating this, but this works. On some thread there is a great 12V battery load check proceedure that you can perform completely in the drivers seat. Someone help....where is it.
  5. 1fixitman
    1fixitman Member
    182
    Augusta, GA
    <div class='quotetop'>QUOTE(FL_Prius_Driver @ Jul 19 2007, 10:01 PM) [snapback]481963[/snapback]</div>
    The car that you provide the info on is a Generation 1 prius. The OP owns a 2007 prius, a generation 2 vehicle. I think your post is helpful but not to the OP. Do you have the info for the gen2?
  6. richard schumacher
    7,666
    1,047
    United States
    It should be able to sit as long as two weeks with no trouble. Most likely the OP left the rear hatch ajar or a light on somewhere, perhaps some time before the five day trip.
  7. craigk
    craigk Member
    139
    Golden Valley, MN
    <div class='quotetop'>QUOTE(D Rock @ Jul 20 2007, 03:13 AM) [snapback]482111[/snapback]</div>
    I found this on the web and it actually worked on my 2007! (It was listed for a 2005)
    To enter diagnostic mode, first place the car in IG-ON mode by pressing the power button twice without pressing the brake. You can also do this while the car is running. Next hold in the Info button while switching the headlights from Off to Parking and back 3 times. Then release the Info button. The display should now enter diagnostic mode.
    When I shut the car off and turned it back on again the screen was in its normal mode.
    I'm not sure what to do with all the information, but I do like seeing the actual voltage on the 12v battery.
  8. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    It works for both Prius generations. It's actually in the tech manuals, so it is only a secret in the sense of not common knowledge.
  9. donee
    donee New Member
    2,956
    198
    Chicagoland
    <div class='quotetop'>QUOTE(richard schumacher @ Jul 20 2007, 11:20 AM) [snapback]482192[/snapback]</div>
    Yea,
    I did that. But luckily I noticed the hatch glow, and went down and investigated. The new cars have quite stiff hatch struts. If you do not give it a good push, it wont close all the way. I always check check the light cluster for the door-ajar symbol now.
  10. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    A double safety-check is to simply lock the car. It won't and complains if a door or the hatch is ajar. And then your car is locked too!
