Prius Tire Rotation
Discussion in 'Gen 2 Prius Main Forum' started by 2Touring, Jul 22, 2007.
  1. 2Touring
    2Touring New Member
    It's time for me to perform my first tire rotation on my Prius. I found it odd that the recommended pattern is front to back, same side, but I guess that's what they deem best.
    My issue is being able to jack up the car on the one side so that both tires are in the air. I am not sure that the front jack point which is the one I would use for a single lifting point would be capable of that.
    It does appear that if I use the rear jack point to lift there, then there looks to be enough "frame rail" immediately behind the lift point to place a jack stand. I would then move to the front lift point with the floor jack.
    Has anyone done this with their Prius?
    My huge beef is that while looking for the jack points and studying the layout, I found that the driver's side rear had already been deformed by improper lifting, and that was ONLY done by the selling dealership. That might actually be another part of a puzzle regarding my car, since it also had a scuff on the front valance panel, driver's side, and there is a 'rattle' that occurs primarily when the left front wheel hits a bump. So this might be yet another clue. I'll be sure to point out the bent metal when I finally do bring it in for the rattle.
    Anyway, since the jack points are nothing more than a double notched strip of metal, does anyone also know of some sort of adapter that might be used with a floor jack so that the lift point is not bent, as was done at the dealership?
    Any pointers on lifting the car at home for tire rotation would be greatly appreciated. I hate bringing a vehicle to a dealer or garage for any work, and my new vehicle is prime examale why.
  2. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    I did mine 3 weeks ago with 2 scissor jacks on the same side. I'm not thrilled how it went and may do it differently next time...vehicle was just the slightest bit wobbly and wanted to lean back (should have used wheel chocks on the other side). I may use 2 trolley jacks next time. An alternative is to use the spare temporarily so you only need to raise one end at a time.
  3. 2Touring
    2Touring New Member
    <div class='quotetop'>QUOTE(lenjack @ Jul 22 2007, 09:48 PM) [snapback]483353[/snapback]</div>
    I gave thought to using the spare, and might do that. I have not looked at the factory jack yet to see how it interfaces with the lifting points in order to avoid the bending damage done by the dealer. That's why I'm thinking I might get some sort of adapter to go between my floor jack and the body.
    Did you bend any of the metal using the scissors jacks?
  4. lenjack
    804
    114
    Pennsylvania USA
    Did not bend.
  5. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    I normally rotate my tires when I change the oil. I loosen the lugs on both left side wheels and then use a floor jack to jack the left front first (to force more oil out of the pan) and place a jack stand near the jacking point. While the oil is draining I jack the left rear and rotate the left side. After adding the new oil, I do the same on the other side. I have never bent any of the metal at or near the jacking point.
  6. 2Touring
    2Touring New Member
    <div class='quotetop'>QUOTE(seasalsa @ Jul 22 2007, 10:40 PM) [snapback]483389[/snapback]</div>
    That's kind of what I'm thinking of doing, with a jack stand. But there did not seem to be enough rail length in the front to place a jack stand while the floor jack was under there as well. But your approach is the one I'll try.
    As for the bent metal, boy is it bent....One can only imagine what they did to accomplish that.
    I had a Fiat many years ago (actually, still have a Spider) that I purchased at...yikes, while typing this just realized that I purchased it used at the original location of the same Toyota dealer where I bought the Prius..anyway, when they performed the state inspection on it, one of their resident moron mechanics lifted it in the rear by the trailing arms. What a dumb location. I guess they were accustomed to Detroit iron where the skinny arms were solid steel. On the Fiat, they were hollow. Both were severely bent, and they said they could straighten them. Of course, they could not be safely repaired.
    One can only imagine how many suspension problems arise from improper lifting of cars in garages.
  7. alexstarfire
    alexstarfire New Member
    220
    Well, I know from experience that if you just put the jack in between the two jack points on either side, in the middle, that it'll be just fine to lift the whole side up. Just make sure you are on level ground, else the jack might slip and cause some massive damage.
  8. joefrompa
    joefrompa New Member
    I'm a new member, but a car enthusiast. Make sure you are torqueing your lug nuts when you are done. I am not sure of the spec on the Prius (if it is different) but standard cars are typically between 80-90 lb/ft.
    Joe
  9. brick
    brick Active Member
    1,083
    79
    Upstate NY
    The torque spec is 103Nm per the manual. I agree that using a torque wrench is a very good idea, and especially pays off next time you need to rotate the tires or change a flat. Under-torque is dangerous, over-torquing can make it a royal PITA to break the lugs loose.
    (I just rotated my tires a couple hours ago with the spare and OEM scissor jack. Laborious but effective if that's all you have to work with.)
  10. lenjack
    804
    114
    Pennsylvania USA
    76 foot pounds. Are you sure you can jack up the whole side with a single jack midway between the jack points? Has anyone else done this?
  11. 2Touring
    2Touring New Member
    <div class='quotetop'>QUOTE(lenjack @ Jul 23 2007, 07:54 PM) [snapback]483832[/snapback]</div>
    I know you could with a Fiat 124 wagon...it had a single middle jack point....very nice
    I did get a reply to my questions at Edmunds from a guy who said he has a copy of the Prius shop manual which does in fact talk about rubber inserts to go between the body and jack. I had pictured something like that as well. He also said it describes 6 jack points. I wonder where the other two are
  12. captross
    captross Junior Member
    North East upstate NY
    Recently went to the dealer for a oil and filter change and a tire rotation. Before leaving my home, I marked the left and right front tires with a marker.
    I was curious as to whether they rotated the tires front to rear or in the X pattern. I got the bill indicating the oil, filter and rotation were completed. But when I check my car, the LF and RF markings were still on the respective front tires. Tire rotation was not done. There would have been no other way to check this since the difference in the front and rear tire wear patterns were hard to see. The service manager grudgling sent it back into the shop and the tires were rotated properly. But the tire pressures were not reset for the rear tires now being in front and the front tires now being in the rear. After a while you just give up, take care of it your self, and go somewhere next time.
    Ross
  13. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    Cpt Ross that is an excellent idea about marking the tires to check later. I will start doing that myself!
  14. captross
    I cannot take credit for the idea of marking the tires. I had read it somewhere in this forum a while back.
    Ross
  15. RhythmDoctor
    RhythmDoctor Member
    135
    Swarthmore, PA
    Check your manual - it shows the other two jack points. My manual shows one in front that will lift the whole front of the car (I've never looked for it), and one in back center near the spare tire well that lifts the whole back of the car.
    I have used the central jack point in back to remove both rear tires when installing rear mud flaps. DO NOT use a scissor jack for this. My scissor jack's screw seized, and the torque needed to get it unseized nearly turned over the jack. I ended up having to jack up even higher by the two side rear jack points to release the weight on the center jack point.
  16. RhythmDoctor
    RhythmDoctor Member
    135
    Swarthmore, PA
    I thought that radial tires should be done front-to-rear only, because the tires "break in" to their spin direction and reversing the spin can wear them faster. Is this a "wives tale"? Or has the design and construction of radial tires changed to allow X-pattern rotation?
  17. RhythmDoctor
    RhythmDoctor Member
    135
    Swarthmore, PA
    OK, so I did some checking and the mid-rear jack point is a metal post immediately in front of the wheel well. That's the one I referenced in my message above. The base of the post is flat, so that it will accommodate a jack with a traditional "pan" lifter.
    As for bending the sheet metal on the side jack points, please note that the scissor jack that Toyota supplies with the Prius has a deep U-shaped notch in it that eliminates contact with the vertical sheet metal rail. All contact occurs with horizontal sheet metal immediately adjacent to the vertical rail. However, when I jacked up my Prius previously, I used a Toyota Camry jack that had a similar U-shaped bracket, but it was not deep enough to prevent contact with the rail, so all the stress went to the rail. However, it did not seem to cause any damage for me. But in the future I would recommend ONLY using the Prius jack (or Toyota-approved adapter) with the side jack points. If you have a router, you may be able to make your own adapter from a wood block.
    If I decide to do my own tire rotations, I have planned on jacking up the two rear tires via the mid-rear jack point, placing jack stands near the rear side jack points, then jacking up each of the front tires individually. Can anyone suggest the best place to place the jack stands? They do not have a U-notch, so putting all the stress on the vertical rail would seem to be a poor idea.
  18. Adee
    Adee New Member
    I can recommend using the jack and jack stand pads from protech. I have used these when lifting our cars for a while, including our Prius with no damage what so ever. They are a very firm, but soft plastic material that conforms to the under side of the car, distributing the weight very evenly over a much larger area than the jack or jack stand would normally provide. They are also very grippy, which combined with the grove in the jack pad head, makes things very stable when lifting.
    Protech
  19. richard schumacher
    7,664
    1,046
    United States
    You don't have to rotate the tires periodically. You can extract maximum life from them with minimum bother by letting the front two wear out, moving the rear two to the front, and putting a new pair on the rear. This also means that the two better tires will always be at the rear, which is safer.
  20. Tchou
    Tchou Member
    161
    Those are in fact the attaching points of the car to the boat when they are transported from Japan to location...
    If the car is rigid enough, using the front jack point should be all that you need to lift the entire side... most of the weight is in the front part so the center of gravity is more to the front than in the middle...
    I know The battery is quite heavy but still, the engine + motor + transmission should weight more...
