2007 taillight,Back up,indicator bulbs,???
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by eastender43, Jul 26, 2007.
  1. eastender43
    eastender43 Junior Member
    All my bulbs got crunched,I have the new taillight bodies,and went to get bulbs...
    To my surprise,No one lists anything for the 2007 Prius!....!I have searched everywhere online....even the owners manual is vague...
    Does this mean you have to buy new bulbs from a genuine Toyota dealer?
    I commonly see a listing for the 2006,specifying Sylvania 2825 and 7440....but the brake light is listed as LED for the 2007....
    Does anyone know what commonly available bulbs will work in a 2007?
    Thanks very much!....Bob
  2. BE55Roberts
    BE55Roberts New Member
    <div class='quotetop'>QUOTE(eastender43 @ Jul 26 2007, 11:54 AM) [snapback]485506[/snapback]</div>
    I understand that the lights are all LEDs. Hence, you won't find a specific bulb. The LEDs are an array of lights that you'll probably have to go to the dealer to get replaced. And be sure you got the right tail light bodies to go with your 2007 prius.
  3. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    The brake lights are LEDs and probably part of the back light housing assembly. The rear turn signal lamps are 992 (7440A). The tail light is 2825. The Back up light is 7440. Have I missed any?
  4. eastender43
    <div class='quotetop'>QUOTE(Bill Merchant @ Jul 30 2007, 12:57 AM) [snapback]487329[/snapback]</div>
    That is 100% correct Bill,Thanks!...Basically all the ones you can replace are same as the 2006...ie,7440 and 2825.....
    Got both taillight housings replaced easily enough,through the little access doors...Only tricky part is there are wire securing clips on the ends of the taillight studs....remove those, unscrew the 2 10mm nuts,and give a firm YANK to unclip the other 2 friction mounts,and that's it...
    On installation,When tightening the nuts ,only use very minimal torque(!/4 turn beyond handtight) or you can crack your new TL!...
    New baby looks sharp again with those snazzy rear taillights!!!
  5. nerfer
    nerfer A young senior member
    2,505
    233
    28
    Chicagoland, IL, USA, Earth
    Where did you get the taillight bodies? I need one too, and have been looking around a little...
  6. eastender43
    <div class='quotetop'>QUOTE(nerfer @ Aug 2 2007, 11:00 PM) [snapback]489780[/snapback]</div>
    I got one on Ebay for $76 shipped,had a 3/4 crack in the very bottom,not an issue to me....
    Got one from a yard in MN....PAM auto supply..St Cloud.they still have a right one...$140 plus 17 shipping
    Danny on this site offered to get one for $162,plus shipping..
    Hoy-Fox also has a price of $164 for a new one.....
    Some salvage places want more than $165.And one on Ebay went for $174 yesterday...
    Man these things break very easily.....It's a shame they don't sell just the lens,but it is all glued together,obviously....They are pretty though....Good Luck,Bob
  7. jump123
    jump123 New Member
    30
    new york
    I just noticed this morning that the clear plexiglass cover on my tail light assembly is cracked (badly! there's now a hole in it!). do i need to replace the whole assembly or can I just have the top/cover (the clear plexi part) replaced?
