expanding the bladder
Discussion in 'Gen 2 Prius Main Forum' started by douglas001001, Aug 1, 2007.
  1. douglas001001
    douglas001001 smug doug
    222
    Chicago
    I just passed 6000 miles and I haven't been able to get more than 9.3 gallons in when filling up at flashing PIP.
    I pump at the lowest rate that the hands free pumping can be set at. I let it fill until it auto clicks off, then wait 20-30 seconds and pump until one more click off.
    Seeing the ruin the charcoal cannister threads has me hesitant to try and fill more, but I've seen posts of people getting in 10+ gallons in, in their hand mpg calculations.
    Is it safe to try one more fill until click off? Or another method of filling?
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    How do you know it's not full?
    Don't try to do anything. I usually top off for one additional click...depending upon the pump. Some pumps click off way too early and I have to nurse in the remaining 2-3 gallons.
    I've only once gotten 9.6 gallons in my '04 in 63k miles plus. Since I have CAN-View I also know that I have around 12% of my tank remaining when I fill up. And I usually drive around 12-30 miles after the last bar starts flashing.
    For a 10.9 gallon tank that means I have around 1.3 gallons left...so adding 9.6 gallons puts me exactly at the 10.9 gallon mark. There's some hysteresis with the fuel level, even with CAN-View, but I've just accepted that there's some unusable volume of fuel that'll remain in the tank.
    For the '06/'07 they've made some improvements in the fuel guage level so that when that last bar starts flashing you're probably closer to only 1 gallon left in the tank. So it's a good idea not to drive too much further before filling up. If you're not waiting until the last bar flashes you're probably completely topped off even with the 9.x gallons you're getting in.
  3. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    <div class='quotetop'>QUOTE(efusco @ Aug 1 2007, 08:40 AM) [snapback]488605[/snapback]</div>
    But the Prius has an 11.9 gallon tank according to Toyota's US web site.
    I've been able to put close to 11 gallons into the tank without forcing it, and there were still two pip left on the gauge. There was a fillup at about 5000 miles (when the weather had finally warmed up) that the bladder clearly expanded on it's own. The gas pump clicked off, and when I gave it the usual one or two extra clicks it suddenly decided to take an extra gallon and a half without clicking off. It also didn't overfill or make the gurgling sounds that it would if fuel was filling the evap hoses or filler nozzle.
  4. efusco
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(narf @ Aug 1 2007, 10:09 AM) [snapback]488626[/snapback]</div>
    Yup, you're right, slip o' the brain on my part. Kinda ruins my whole arguement doesn't it!
  5. qbee42
    3,082
    <div class='quotetop'>QUOTE(narf @ Aug 1 2007, 11:09 AM) [snapback]488626[/snapback]</div>
    11.9 gallons gross, not net. The usable capacity of the U.S. Prius' gas tank is less, and varies by temperature and vehicle. I've never put more than 10.5 in mine, and that was only when I couldn't find a place to refuel and drove until it scared me silly.
  6. subarutoo
    subarutoo New Member
    1,213
    Chatsworth, CA
    <div class='quotetop'>QUOTE(douglas001001 @ Aug 1 2007, 07:30 AM) [snapback]488601[/snapback]</div>
    What would be the point of expanding the bladder? Just fill the tank, and stop when the pump clicks off. Is that few more drops of fuel that important? Did you ever have another car, and remove the gas tank, and try to pound out a few more gallons out of the regular steel tank? I don't see your problem.
  7. douglas001001
    222
    Chicago
    If I'm getting 9.3 in, immediately filling up after flashing pip and there is 1 gallon left (estimated by Evan) that is 10.3 gallons.
    If there was no bladder it would be 11.9, even if the bladder reduces space 1 gallon that is 10.9 gallons.
    Does that mean my bladder still isn't broken all the way in yet and that I should be able to get it to stretch more?
  8. douglas001001
    222
    Chicago
    <div class='quotetop'>QUOTE(subarutoo @ Aug 1 2007, 02:34 PM) [snapback]488773[/snapback]</div>
    The cost of gas can vary by as much as 40 cents a gallon along my commute so an extra half gallon of capacity could potentially save. Plus the refinery here has unexpected temporary shutdowns from time to time which have seen 40 cent increases over night. An extra day of capacity could get me past that.
    Also, I'm trying to understand how a rubber part which is made to expand, expands to what degree and when. It seems like I'm getting less capacity than others.
  9. alexstarfire
    alexstarfire New Member
    220
    I never understood the bladder myself. I know it's there to prevent gas from evaporating, but why can't they just stick the bladder to the edge of the tank so that it doesn't just magically lose 2 gallons out of it's tank size?
  10. ZA_Andy
    ZA_Andy Member
    219
    VA
    <div class='quotetop'>QUOTE(douglas001001 @ Aug 1 2007, 04:07 PM) [snapback]488796[/snapback]</div>
    It doesn't sound that way to me based on what you've posted, and what I've seen others post, plus my own experience. My maximum refill has been 9.03 gallons.
    The bladder isn't really something you can modify, and it seems to me that since it's possible to get a range of 400-500 miles from a tank of fuel without problem, squeezing a bit extra in doesn't make any sense even if it were possible. Fill it until it clicks off, and drive it until it needs filling. Simple and reliable!
  11. douglas001001
    222
    Chicago
    I meant get it to stretch out as big as it can go by filling techniques, not doing a physical modification in case anyone interpreted it that way.
    alexstarfire, it needs to expand and contract so that there is no air within the tank for gas to evaporate into and then out the cap when opened.
  12. bruceha_2000
    bruceha_2000 Senior Member
    3,057
    302
    Northwest VT
    2018 Prius Prime
    <div class='quotetop'>QUOTE(douglas001001 @ Aug 1 2007, 04:32 PM) [snapback]488824[/snapback]</div>
    There is an ambient temperature component. I imagine that the bladder material is less elastic in sub zero temps than at 80 F. I have put in 10.5 gallons on numerous occasions without 'filling the pipe', no gurgling, no spit-up. When my '04 gets to 1 pip, I can put in about 9.5. It gets to 1 flashing about 1/2 gallon after hitting 1 pip. I KNOW that I have a lot more left in the tank at 1 pip than my wife's '06 which will take 10.5 at 1 pip. I wouldn't push her car after the flash like I can mine.
  13. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    Well, if you really want to stretch the bladder, fill up on a cool morning that you are going to drive for a while. I've calculated that a full tank at underground temps will expand around two litres max. If you fill up to the top of the filler tube you will need to burn off that two litres of fuel before the tank warms up to 40C. Otherwise the expanding fuel will force its' way past the carbon canister into the tank space.
    I don't think you will ruin the tank if you overfill once or twice, especially if you burn off the fuel before it expands too much. I've overfilled twice so far (nossle didn't shut off). What I learned is there is about 2.5 litres in the filler tube, allowing me to go an extra 60 km or so.
    All that being said, what makes you think the bladder will stay stretched? I suspect it will return to its' previous size. Perhaps a better way to proceed is to carry a few gallons of extra fuel (safely) and see how far you can go when the fuel gauge indicates empty. You are probably not using the last gallon or so that you could. From what I've read, there is at least two litres of fuel in the tank you can't pump out, and if you run out, you need at least two gallons before the car can pump the fuel reliably.
    Or better yet, just fill normally and live with what you've got. ;)
  14. TLS
    TLS New Member
    <div class='quotetop'>QUOTE(David Beale @ Aug 1 2007, 02:50 PM) [snapback]488881[/snapback]</div>
    Or fuel up after dark to both maximize the fuel volume and minimize the fuel evaporation from the pump.
