Transmission Locked In Park
Discussion in 'Gen 2 Prius Technical Discussion' started by larry jones, Jul 30, 2007.
  1. larry jones
    larry jones Junior Member
    two questions; 1, 04 prius stuck in park! jumped but to no avail. need to move it to my garage so i can work on it! has anyone removed the park lock selinoid from under the car? 2, 01prius; what batt. could i use without using the factory type? i mod. my conectors and installed a lawn type batt. ant it has worked for several mo.s. do not feel it is going to last though!!! thanks, larryjo2
  2. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
  3. larry jones
    <div class='quotetop'>QUOTE(FL_Prius_Driver @ Jul 30 2007, 05:54 PM) [snapback]487687[/snapback]</div>
  4. larry jones
    this site is a bit difficult for me to operate. i am not much on computers and can get mixed up very easy. thank you for your help and good advise. i bought this car on the internet with front end dmg. and not running. 1/2 of the relays in the fuse box were missing. i borrowed some from a friend and jumped the car but to no avail. i need to get it home where all my tools and equipment are so that i can start to trouble shoot it. do you know anyone that has disconnected the park mechinisum from the transmission? i am sure i can find it when i get under the car, but any advanced info might help. thanks again, larry
  5. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    If you successfully jumped the car and got the dash to light up,
    then it's likely you can shift it to Neutral. But you need to then
    pull the PCON MTR relay *before* letting it power down again, or it
    goes right back into park. So try that first; it's a heck of a lot
    easier than going after the parking actuator which is buried deep
    on the backside of the transaxle and very close to other things.
    _H*
  6. 1fixitman
    1fixitman Member
    182
    Augusta, GA
    <div class='quotetop'>QUOTE(larryjo2 @ Aug 3 2007, 08:09 PM) [snapback]490228[/snapback]</div>
    If you don't mind telling us....How much did you pay for the vehicle and how many miles are on it????
    http://www.elearnaid.com/12vobaforpr2.html
    [/quote]
    The elearnaid battery and kit is for generation 1 prius only. In generation 2 prius the terminal positions are swapped and this kit will not work for what we need in 04-07. Just clarifying this for all. I called elearn and they do not plan on getting a kit together for gen 2 as it is too complicated for the average person to do without screwing up something. FYI
  7. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    <div class='quotetop'>QUOTE(D Rock @ Aug 4 2007, 09:11 PM) [snapback]490689[/snapback]</div>
    Thanks for the correction.
  8. larry jones
    i have about $7,500 in the car and it needs about 2,000 in repairs. miles are about 50,000. thanks for your help on the questions i have about this car.
