Sharkfin Antenna
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Rufio24, Aug 14, 2007.
  1. Rufio24
    Rufio24 Junior Member
    just curious. could someone enlighten me?
  2. nginoza
    nginoza Junior Member
    Hi ,
    I just purchased on through Prius Chat, Seaside Blue, pefect color match. I bought it strcitly for appearance. There is no difference in reception. I still get all the channels I had before.
  3. Tideland Prius
    16,560
    Adv:
    - looks cool (and it actually does look OEM.. not some cheap aftermarket bit)
    Disadv:
    - possible loss of reception
    That's about it.
  4. Rufio24
    mine is seaside pearl, too. i think i might invest in one. they are not too expensive at all.
  5. aaf709
    3,862
    2022 Prius Prime
    Another advantage is that if you have your (small) satellite radio antenna in the back, it's possible to hide it under the Sharkfin.
  6. richard123
    richard123 New Member
    17
    <div class='quotetop'>QUOTE(nginoza @ Aug 14 2007, 12:37 AM) [snapback]495217[/snapback]</div>
    How does it attach, and is there any problem with going through a carwash?
    Richard
  7. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(richard123 @ Aug 14 2007, 09:09 AM) [snapback]495372[/snapback]</div>
    You can take a look at http://www.evnut.com/prius_antenna.htm to see how Darell installed his.
  8. PA Prius
    PA Prius Active Member
    762
    251
    SE Pennsylvania
    We replaced ours after "someone" backed out of the garage when the door was partially closed. It would have cost approximately $200. to replace the original, so we went with the $65. Sharkfin. Going through the car wash is great, you don' t need to remove it like the stock antenna. It also works better with our luggage rack. Downside is that reception is considerably worse.
    PA P
  9. Syclone
    Syclone Member
    540
    <div class='quotetop'>QUOTE(Rufio24 @ Aug 14 2007, 12:10 AM) [snapback]495207[/snapback]</div>
    The "cool" factor trumps all! ++++
    Hides Sat. antenna and cable ++
    AM reception --
    FM reception -
  10. hycamguy07
    hycamguy07 New Member
    2,707
    Central Florida
    I see them on the newer BMWs just tink of it as your coping them.. :rolleyes:
  11. richard123
    17
    <div class='quotetop'>QUOTE(aaf709 @ Aug 14 2007, 12:16 PM) [snapback]495378[/snapback]</div>
    Thank you ver much, that was extremely helpfull.
    Richard
  12. skg
    skg New Member
    How can I test whether my reception will still be acceptable with the sharkfin? I've simply removed the whip antenna and I got horrible reception. Just wondering if that's a reasonable test.
  13. PA Prius
    762
    251
    SE Pennsylvania
    <div class='quotetop'>QUOTE(skg @ Aug 18 2007, 10:57 AM) [snapback]498318[/snapback]</div>
    No, that is not a reasonable test. It will be better than without the whip antenna. Today is a beautiful day for a drive. Take a little trip to Akron, PA and you can compare my Sharkfin with your stock antenna!
    PA P
  14. subarutoo
    subarutoo New Member
    1,213
    Chatsworth, CA
    <div class='quotetop'>QUOTE(skg @ Aug 18 2007, 07:57 AM) [snapback]498318[/snapback]</div>
    I just taped the shark fin on and drove around, to compare with the stock one. I saw no loss of reception in the fringe area N/W of LA that I live, and went ahead with the install. Just screw in the wire, and use some masking tape to temporarily try it, if you have worries. It actually out performs the stock mast type antennas on our other two cars. B)
  15. aaf709
    3,862
    2022 Prius Prime
    My wife suggested that if you're in a Prius club and someone has an sharkfin antenna, ask if you can listen to your stations. While it's similar to what PA Prius suggested, this way you can see what it would be like where you live.
  16. skg
    skg New Member
    Thanks for your advices!! I don't know anyone driving a prius around where I live... (in fact I haven't seen Prius w/ sharkfin around here...) If anyone on this forum is from the New York metro/north Jersey area with a sharkfin, please let me know your reception of the following stations:
    FM100.3
    FM93.9
    AM1010
    Thanks!!
  17. ncc1701mda
    ncc1701mda Junior Member
    22
    Cyclone - How did you route the cable for the satellite antenna? I just got a Sirius radio and am debating the best way to install the antenna... your solution seems ideal!
    Mike
  18. Clubford00
    Clubford00 New Member
    93
    Buffalo Grove, Ill.
    Just for info, I personally would not put my Sirius antenna under the sharkfin. Although it would "clean up" the back nicely, I am on my 3rd antenna and would hate to peel off the Fin to change it out again. Im not sure what antenna's you guys have , but i changed to a sirius ready Kenwood stereo and the kenwood antenna. I dont know if its car washes or what that hurt the first 2. So far the 3rd one has been ok for over a year, (knock on plastic) so maybe the first 2 were just defective. the one i have looks like a small rounded over hockey puck. Id show you but i cant figure out how you guys can post big pictures on here.
  19. BIGGDOGG
    BIGGDOGG New Member
    298
    Morristown,NJ
    This will show you how to instal it.. Darell's Electric Vehicle Page
    Click on the prius hybrid in the bottom left then click on MODS and find the one about the shark fin. He shows all sorts of pictures. I know Darell is on here somewhere but I don't know his PC screen name...
    I am getting one but will wait till it gets warmer so I can install it.
  20. ad78
    ad78 New Member
    120
    Rocky Hill, CT
    after in installed my sharkfin my reception got stronger. this is for real..
    what i did is, don't let the sharkfin touches the black body antenna base
