Connecting iPod to the stereo Prius controlling songlist
Discussion in 'Gen 2 Prius Audio and Electronics' started by Eric Nothman, Aug 11, 2007.
  1. Eric Nothman
    Eric Nothman Prius owner
    101
    Washington DC area
    2020 Prius Prime
    Today we installed the VAIS product (SL2) that connects the iPod to the Prius stereo, using the MD (MiniDisk emulation mode), and it works really well! The install was smooth, and the device has a really nice user interface/integration where one controls the iPod through the Prius MFD and/or steering wheel controls.
    The name of the Playlist that is playing is constantly displayed on the Prius MFD, and one can cycle through to see the artist, album, and song name of what is playing as well (one at a time - 29 characters of display), by pushing a button on the Prius MFD touch screen to cycle through these three. The iPod Playlists can be cycled through sequentially, looking at the playlist name as you go. Alternatively the first 12 playlists can be selected by a single touch selection on the MFD where a number is associated with each Playlist. All playlists have a number associated and can be selected by number as well. Once selected (sequentially or random) the name of the playlist is displayed on the MFD. This interface is really quite usable considering they are emulating the Japanese MiniDisk (this is apparently big in Japan but not available in the US).
    The iPod is charged when connected to the stereo through the multi-pin connector. The controls on the Prius steering wheel can move from song to song within a Playlist. If a phone call comes in over bluetooth, then the music cuts out just as it would for the normal AM/FM/CD. The iPod is told to stop playing when the stereo changes to use the FM radio or CD player. If for some reason you want to control the iPod from the iPod, then one can press the scan button on the MFD eight times quickly to place the unit in 'simple mode' to allow that.
    According to the professional stereo installers we used the VAIS user interface is superior to the DICE (competitor unit). In addition, they have seen problems with DICE units whereas they have not seen any problems with the VAIS units. In addition, the VAIS company only makes products for Toyota/Lexus cars and according to the installers they therefor seem to be very tailored to these cars. In comparison, DICE makes products for a much wider set of car manufacturers. These observations were the basis for their recommendation of the VAIS units. The VAIS unit simply plugs into the back of the Prius stereo, and the wiring that comes with it will allow another device (ex. Sirius or XM radio) to be chained behind it.
    Now that I have seen it working on my wife's 2004 (it is nice!), I am intending to purchase another for my 2006 once they have the firmware update that supports the iPhone (VAIS said this should be out within a month or so).
    Best regards,
    Eric
  2. Vagabond
    Vagabond Active Member
    1,198
    Southern California
    Of course, the DICE kit supported the iPhone from day one :eek:
  3. shar1950
    shar1950 Junior Member
    merritt, bc canada
    <div class='quotetop'>QUOTE(Vagabond @ Aug 12 2007, 07:34 PM) [snapback]494446[/snapback]</div>
    So how well will the vais work on the 2007 prius and what is the price differance ? ;)
  4. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(shar1950 @ Aug 13 2007, 11:01 AM) [snapback]494802[/snapback]</div>
    By going to the VAIS site, the unit costs between $224.99 and $299.99 (depending on what you want) vs $159 for the DICE (I got my DICE on a group buy for $135, now it's $143.95 with free shipping).
    Both should work fine for a 2007.
  5. edselpdx
    edselpdx Member
    191
    Portland, OR
    I'm glad to see a review of the VAIS system here. It seems many people (including me) have the DICE system for iPod integration, and fewer have the VAIS. I personally am not going to change the system I have at this point, as it's working for me, but I think folks just checking in to evaluate one vs. the other will appreciate this eval. Just a few observations:
    The DICE system has been blamed for "MFD failures", but in actuality, although some MFD's were replaced (erroneously I think...no one has posted anything I can find that's proved different) by Toyota dealers under warranty; unplugging and replugging the DICE does apparently totally fix the problem, as long as you have the current (as of ?May--Vagabond?) DICE unit. My dealer wanted to replace my MFD under warranty when I thought I had the dreaded MFD failure several months after installing my DICE. I described the problem and they told me it "had to be" a warranty MFD failure. After a search of google/Priuschat, my problem was solved in under 2 minutes by unplugging the DICE unit and replugging. :D
    No damage has been revealed in the > 1 month since this happened as far as I can tell. Apparently ALOT of info is sent through the stereo "head" to and from the MFD... much more than just the audio info. The blip makes it seem that something MAJOR is wrong with the MFD--no MPG or tank info, no climate control, etc. In 4 months of DICE usage, I did have that one failure, but now know how to fix it easily and quickly. Can't guarantee that it fixes all, and it's not ideal to have to do ANYTHING to "fix" your computer system for an audio system, but just make sure your DICE is installed in easy disassembly reach (like near the lower glove box).
    Hope those of you with VAIS continue to have a good track record. I'm not sure which choice I would make right now, but $100 is a big difference in my world.
  6. priussafta
    priussafta New Member
  7. Airgetlam
    Airgetlam Junior Member
    37
    Escondido, CA
    Eric,
    I was fascinated where you spoke about the "chaining" of devices behind the VAIS. I've got a 2005 Prius that I connected the Toyota Solara Sirius unit to the back of the head unit. It has been working fine for a couple of years now, but I've always wanted a solution for my iPod as well.
    Of course, I'd rather not have to buy another Sirius radio that plugs in somewhere else, so the concept of a daisy chain solution sounds perfect. You indicated you got the SL2, but looking at the website for VAIS shows SL2i, SL2x, and SL2s. None of those appear to have a daisy chain ability that I can figure out, based on the wiring images they show. Would you be so kind as to specify which product you got that allows this?
    Thanks for the review!
    Bruce
  8. Eric Nothman
    101
    Washington DC area
    2020 Prius Prime
    <div class='quotetop'>QUOTE(Airgetlam @ Aug 20 2007, 05:58 PM) [snapback]499383[/snapback]</div>
    Bruce,
    I purchased the SoundLinq2 model SL2i. A review of the documentation that came with it indicates the empty plug that provides the ability to daisy chain is labeled as "To the factory wiring harness" and it is pointed out that in some vehicles it is not used (as in my 2004 Prius). To me, it appears to be designed with your application in mind - where Toyota uses that 12 pin connector plug on the back of the radio (as in your case) VAIS appears to have engineered the ability to insert the iPOD. When the SL2i was installed I looked at this SL2i wiring cable closely and it appears to simply pass-through the pins on the back of the radio to another empty plug.
    The installer told me that a Sirius or XM radio can connect in a daisy chain to this plug and he even offered to install such a thing connected there in the future if we would like. He had lots of experience with the VAIS unit and the Prius, and explained that he had done that before, so I think he knew what he was talking about. However, I could not find any description within the document that came with the SL2i as to how such a daisy chained device would share (logically). It appears there is an 'audio/video network' and an addressing scheme for participation, but no other details provide a clue as to how logical sharing is accomplished.
    The document that I referred to above can be found here ==>
    http://www.vaistech.com/manuals/Manual_SL2i.pdf
    See figure under "Connecting SoundLinQ2 to see "To the factory Audio harness" plug - unused on my 2004 Prius.
    I suggest you may consider calling VAIS Technology (720)-733-2348 in Greenwood Village, CO. When I called them with an inquiry on another topic the person I reached was friendly, knowledgeable, and helpful. When I purchased from their website the SL2i came within a few days.
    Best regards,
    Eric
  9. Vagabond
    1,198
    Southern California
    saftaleah, your son didn't install the kit correctly. In iPod mode, no text is supposed to appear. You're not supposed to use it. Your car is too old to support MP3 mode either. Use it in CD mode, which is all 4 DIP switches facing up.
  10. Airgetlam
    37
    Escondido, CA
    Eric,
    Thanks for your quick response. I'll try to call them today, and stop by my local shop to discuss it as well.
    Bruce
  11. mike.s
    mike.s New Member
    25
    <div class='quotetop'>QUOTE(aaf709 @ Aug 13 2007, 03:27 PM) [snapback]494865[/snapback]</div>
    You get what you pay for.
  12. Airgetlam
    37
    Escondido, CA
    Mike S.,
    You seem to be posting in this thread and another at least about how you think that the DICE unit isn't as good as the VAIS, but what I haven't seen are any particular reasons.
    Would you be willing to share your experiences with both, and explain why you feel that the VAIS is a better unit (or "you get what you pay for")?
    I'm making my choice based on the chainability (new word!) of the previous Sirius install that I have, but I'd be interested in the facts that you can share to support your opinion.
    Thanks!
    Bruce
  13. Vagabond
    1,198
    Southern California
    <div class='quotetop'>QUOTE(Airgetlam @ Aug 22 2007, 09:49 AM) [snapback]500349[/snapback]</div>
    He has a Toyota mini-van and had some issues with the behavior. He was convinced that it didn't work with his car at all - all his troubles were actually iPod based. He has a 3rd gen iPod, something DICE says it will not work 100% with.
  14. Airgetlam
    37
    Escondido, CA
    I see. Thanks for your reply, Vagabond, I appreciate it.
    As you seem to be connected with DICE, can you tell me if I have made the wrong assumption about daisy chaining?
    As indicated above, I have the Solara Sirius radio plugged into the back of my head unit. I am hoping to add iPod compatibility without losing any of the current (albeit limited for text) funtionality. Is there a solution from DICE that will acheive that?
    I don't have particularly strong opinions about which company may be better, I'm just looking for a device that will acheive my goals with minimum fuss. :)
    Bruce
  15. Vagabond
    1,198
    Southern California
    <div class='quotetop'>QUOTE(Airgetlam @ Aug 22 2007, 11:42 AM) [snapback]500481[/snapback]</div>
    You have the Sirius module installed so it's controllable from the headunit I assume? You won't have any problems with a DICE kit. Chain away!
  16. Airgetlam
    37
    Escondido, CA
    Indeed I do.
    Thanks!
    Bruce
  17. BobR
    BobR Member
    336
    I have an SLI and SLX connected at the same time. The VAIS products do indeed come with a Y cable so additional devices can be added. Before I bought the SLX I had the Solara XM radio and it also worked with the SLI.
    Bob
  18. Vagabond
    1,198
    Southern California
    <div class='quotetop'>QUOTE(BobR @ Aug 22 2007, 10:37 PM) [snapback]500838[/snapback]</div>
    I gotta ask, why did you buy a SLX when you already had an XM kit in your car?
  19. aaf709
    3,862
    2022 Prius Prime
    Just to add my two cents here; I have a DICE, but I used VAIS instructions to install it. Both have a "Y" connector. One plugs into the radio and one plugs into the unit (VAIS or DICE). The remaining plug is used for the satellite radio.
  20. BobR
    BobR Member
    336
    <div class='quotetop'>QUOTE(Vagabond @ Aug 23 2007, 11:47 AM) [snapback]501002[/snapback]</div>
    The 10 character limitation of the Solara XM drove me crazy. The SLX displays 16 Characters.
    Bob
