07 Touring Center Caps
Discussion in 'Gen 2 Prius Main Forum' started by aldo, Aug 21, 2007.
  1. aldo
    aldo New Member
    The Alloy wheels under the plastic covers on the 07 Touring are beautiful! There's only one slight problem... they're missing the center caps. These cars do not come from the factory with center caps, but there is a part you can order from any Toyota dealer that fits in those wheels and looks gorgeous.
    Toyota part number is 42603-52030 and they cost around $15 each. I have posted pictures of these center caps for you to see. [attachmentid=10813]
  2. prius2go
    prius2go Member
    312
    nice :D
    but I want black ones and nuts
    My toyota dealer today confirmed that they could cross reference nothing across different models
  3. aldo
    aldo New Member
    <div class='quotetop'>QUOTE(prius2go @ Aug 21 2007, 07:22 PM) [snapback]499998[/snapback]</div>
    I don't know if the TRD center caps, part number PTR18-12003-05, will work but maybe you can do some research. They are black with the TDR logo. www.trdusa.com
  4. doubleg2005
    doubleg2005 Member
    236
    can you post a picture that shows the entire car?
    i'm still on the fence about removing my wheel trims...
  5. aldo
    aldo New Member
    <div class='quotetop'>QUOTE(doubleg2005 @ Aug 22 2007, 10:40 PM) [snapback]500768[/snapback]</div>
    Sure, here is the whole car....
    [attachmentid=10857]
  6. Metro
    Metro Your OEM Q & A Resource
    76
    Cleveland, OH
    Since I have seen this topic come up a couple of times and it seems like there is enough interest I have added these caps to my website. They are $11.00 each. I will keep 4 caps in stock regularly. They are purchased as individuals for those that might have lost 1 so you do not have to purchase a full set. Hopefully this helps some of you out.
  7. RinMI
    RinMI New Member
    132
    SW Michigan
    <div class='quotetop'>QUOTE(Metro @ Aug 24 2007, 10:00 AM) [snapback]501508[/snapback]</div>
    The chrome ones or the black ones. Anyone have pics of the black ones? I have the chrome ones but would be curious to see what the black ones look like since my car is black.
  8. mhawkin1
    mhawkin1 Matt
    102
    Indianapolis
    That's hot. You need to tint your windows.
  9. RinMI
    RinMI New Member
    132
    SW Michigan
    <div class='quotetop'>QUOTE(mhawkin1 @ Aug 24 2007, 01:04 PM) [snapback]501558[/snapback]</div>
    Saving up for it as I type.
  10. Metro
    76
    Cleveland, OH
    <div class='quotetop'>QUOTE(RinMI @ Aug 24 2007, 12:20 PM) [snapback]501521[/snapback]</div>
    What I have right now is the chrome ones. I am in the process of getting one black one in to compare to the chrome ones. Since they are meant for an accessory wheel I am not positive that they are the same size. They are a little harder to come by than the chrome ones so it may take a few days. Once I find out I will post the results. The prices look like they will be reasonable too.
  11. h2photo
    h2photo Member
    432
    Chandler, AZ
    <div class='quotetop'>QUOTE(Metro @ Aug 24 2007, 07:00 AM) [snapback]501508[/snapback]</div>
    Thanks for putting them on your site! I just ordered 4 of them! Kinda sad that I can have them shipped here for less than going to my dealer even with a 10% coupon! Thanks so much, they are hard to find!!
  12. Metro
    76
    Cleveland, OH
    I finally received the black TRD center cap. Bad news, it is not the same size as the chrome ones. The diameter is a bit larger than the chrome ones, so unless anyone has a brilliant idea on how to "make it work" I don't think that I will be selling them.
  13. RinMI
    RinMI New Member
    132
    SW Michigan
    <div class='quotetop'>QUOTE(Metro @ Aug 31 2007, 12:50 PM) [snapback]504962[/snapback]</div>
    Is it the diameter of the emblem itself or is it the diameter of the "shank" portion or both. How much bigger is it than the chrome ones?
  14. wchardin
    wchardin Senior Member
    2,055
    Nashville, TN
    Does anyone know where to buy the regular center touring caps at? I have searched around on here and elsewhere and I cannot find them.
  15. Neicy
    Neicy Member
    834
    Wakefield, MA.
  16. sorka
    sorka Active Member
    1,004
    196
    Merced, CA
    2019 Prius
    Did they change the touring wheels for 2008? I have a few co-workers with 2008 touring #6's here in the Bay Area, and their touring wheels look like these:
  17. wchardin
    2,055
    Nashville, TN
    Nope, they are the same as they have been since the 2007 model year.
  18. sorka
    sorka Active Member
    1,004
    196
    Merced, CA
    2019 Prius
    So then why are the other photos in this thread of touring rims completely different???
  19. sorka
    sorka Active Member
    1,004
    196
    Merced, CA
    2019 Prius
    OK, now I see. After running out and looking at a wheel more closely, the Touring wheels have full on covers. Not used to seeing that on upgraded alloy wheels.
  20. sorka
    sorka Active Member
    1,004
    196
    Merced, CA
    2019 Prius
    Are these aluminum? The rims look just like steel.
