Increasing Storage In A Prius......no trunk!
Discussion in 'Gen 2 Prius Main Forum' started by Prouddad, Aug 27, 2007.
  1. Prouddad
    Prouddad New Member
    The only objection that I have to buying a Prius rather than another hybrid is the lack of safe storage space.
    I know, I know; the Prius has a cargo cover. I mean space where you can place items that a parking attendant can't get to.
    Since the Prius doesn't have a trunk, is there a locking box that I can bolt down in the back of the car in the hatchback area? I've seen these in the storage area of SUV's, so I'm wondering if anything like that's available for the Prius.
    If you've seen such a storage device for the Prius, will you please tell me where I can find it?
    Incidentally--I know that the Prius Touring edition has a hidden storage area beneath the cargo area. Does any manufacturer make a lock for this?
    Thanks!
  2. mgipe
    mgipe New Member
    Both versions of the 2004-07 Prius, Touring and Standard, have a hidden storage area under the rear carpet. It does not lock and I don't know of any aftermarket locks specific to this car. It does have two twist latches to hold the cover down. You might be able to adapt a standard cabinet lock for use here.
  3. TonyPSchaefer
    14,816
    2,502
    66
    Far-North Chicagoland
    There was a thread a while back about someone who installed a lock on their cargo area. They own and shoot multiple firearms and keep them there. If you are truly concerned about absolutely securing something, you could bolt the front of the cargo floor down and lock the back.
    If you haven't seen the cargo area of the Prius, that might not make much sense to you. Perhaps someone can provide a picture.
  4. PA
    PA Member
    427
    27
    Raleigh, NC
    2019 Prius
    <div class='quotetop'>QUOTE(Prouddad @ Aug 27 2007, 06:25 PM) [snapback]502905[/snapback]</div>
    How big a storage area do you need? That would help guide the replies.
  5. Bohous
    Bohous New Member
    316
    Boston-ish
    Even if you have a lockable trunk a parking attendant can still get in. He has the keys, no?
  6. Prouddad
    Prouddad New Member
    <div class='quotetop'>QUOTE(Bohous @ Aug 27 2007, 06:05 PM) [snapback]502956[/snapback]</div>
    Before you give your car to a parking attendant, you do one or both of two steps:
    1. flip a switch, usually in the locking glovebox, that disables the remote trunk opener
    2. give the attendant a "valet key" that works on the car's ignition, but not the glove box and trunk.
    As far as desired safe storage capacity is concerned, the more the better. In reality, I'd be happy to have a place to put a toiletries bag, my laptop, camera and perhaps some other odds and ends that I may pick up at the store, but not going straight home with.
    I'd need something with greater capacity than those lock boxes that fit under your seat.
  7. patsparks
    10,664
    569
    Adelaide South Australia
    I believe the OP is used to a car with a lockable boot (trunk) and leaving a valet key which won't open the boot.
    Locking the hidden compartment under the rear floor isn't secure enough for a gun, guns should be in a steel cabinet not under a plastic cover.
    Would you be able to secure the under floor storage with a python type lock http://www.aje.com.au/featured/python/python.htm across the tie down points in the corners of the luguage space maybe with something over the floor like a sheet of 19mm (3/4") MDF covered in carpet?
    If you did this you could leave the original lid off the under floor space as long as the MDF was bigger than the original cover.
    The under floor storage should meet your needs for secure space.
  8. ibcs
    ibcs New Member
    351
    31
    Englewood , Ohio
    <div class='quotetop'>QUOTE(patsparks @ Aug 27 2007, 09:22 PM) [snapback]502967[/snapback]</div>
    I also thought te Prius could have extra storage under the back seat. When you lift the back seat up there is room inside. The perfect mod would to have a door under the back seat with a lock. You could hide a laptop under the seat with a lock. Hey, Toyota this is a free sugestion for the plug in version I'm ready to buy in 2010.
    ---Kent
  9. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    I think locks could be installed without too much difficulty where the latches are now. What about a locking steel box that would fit within that hidden area?
  10. Prouddad
    Prouddad New Member
    <div class='quotetop'>QUOTE(hyo silver @ Aug 27 2007, 06:50 PM) [snapback]502974[/snapback]</div>
    Yea, some locking steel boxes that could be bolted down would be a satisfactory solution. I'm wondering if there are any aftermarket products for Prius owners who want some of the privacy benefits of a trunk?
    PatsParks, I don't understand your abbreviations. Will you please clarify your message?
  11. patsparks
    10,664
    569
    <div class='quotetop'>QUOTE(patsparks @ Aug 28 2007, 10:52 AM) [snapback]502967[/snapback]</div>
    I have expanded abbreviations. Sorry I keep forgetting these may not be universal.
  12. Doc Willie
    1,717
    144
    Out there, somewhere
    I saw some heavy-duty plastic trunk shaped boxes at the local True Value hardware store. I didn't do the measurements, but something like that might fit right into the cargo wel. These had wheels and a lock.
  13. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    <div class='quotetop'>QUOTE(hyo silver @ Aug 27 2007, 08:50 PM) [snapback]502974[/snapback]</div>
    That would be my recommendation too IF the forward edge of the hatchbox cannot be lifted up while the rearward edge is locked down.
  14. patsparks
    10,664
    569
    <div class='quotetop'>QUOTE(zenMachine @ Aug 29 2007, 12:17 AM) [snapback]503203[/snapback]</div>
    It can't can it? It locks into the floor at the front
  15. zenMachine
    3,355
    300
    <div class='quotetop'>QUOTE(patsparks @ Aug 30 2007, 05:26 AM) [snapback]504217[/snapback]</div>
    Checked it last night. It can't. There are plastic prongs on the forward edge that hook into sockets in the panel above the HV battery. The lid fits so snugly that you can't slide it rearward to lift the prongs out of their sockets.
    I also unscrewed one latch to take a look. Appears it's quite possible to replace that latch with a lock. Just a matter of finding a lock that fits.
    I definitely will look into adding a lock (or two) to my hatchbox. It'll be useful for storing laptops or cameras when needed, but most of the times it'll be to guard my sound gear from unwanted hands.
  16. KTPhil
    KTPhil Active Member
    1,379
    22
    I'd love to add locks to replace the turn-catches there now. They aren't going to be bulletproof, but even the appearance of secure locks is probably enough to discourage pilfering. Is there a Toyota part that fits? Maybe a glovebox lock from an older model, or an armrest compartment lock (another good idea).
  17. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    You buy a hatchback, there's no trunk.
    You buy a station wagon, there's no trunk.
    SUV? no trunk.
    Full-size van? no trunk.
    You want a trunk? buy an elephant :)
    Great ideas for adding locks to the storage compartment, though...
  18. mjhcftuhgg
    mjhcftuhgg New Member
    New York
    So 11 years later, are there solutions to this? This is also one of my concerns about buying a Prius, after my sedan was broken into and I started storing things locked in the trunk. The 2014 model I tried the other day had a separate "secret" compartment under the trunk, but it wasn't locked at all. I wondered if it is held closed when the rear gate is down? But that's not quite as secure as a locked trunk.
  19. lextoy
    lextoy Active Member
    291
    131
    philadelphia
    2018 Prius Prime
    i think you guys are overthinking this. thieves are opportunistic. and random. if you leave a cvs bag on the passenger seat where they can see it, they will break in. they arent usually breaking in when nothing is visible. nor are they searching vehicles for ten minutes checking all the hidden compartments. the odds that YOU are the guy with a laptop hidden under your seat or in a closed compartment are very small. they arent wasting their time if nothing is visible. even under the cargo cover is usually fine. inside the bin under the rear floor? bums are druggies arent that savvy, even more fine. i would be more worried about telegraphing by spending 5 minutes to STOW something in the trunk area or under a seat. that shows you are stashing something valuable. if its that valuable take it with you. i dont leave anything in my car of value, and i dont lock the doors, if they like the change in my open cup holder, they can open the door and take it. the roll of paper towels in my hatch area, they can have them. prius isnt a thief magnet, most owners are lower tax bracket, not exactly leaving a rolex in the glove box while they go into the gym ;) if you are the one guy in a million that has a prius and is carrying loads of valuables for business or whatever, then a big clunky lock box could easily be bolted to the tie down points for minimal cost with minimal modification. but then you got a thief magnet in your hatch area!! and watch those druggies get all mcgyver on your a$$ and nothing will stop them from getting into that box !!
    Kevin_Denver likes this.
  20. egg_salad
    egg_salad Active Member
    545
    426
    Las Vegas, NV
    Trade your Prius in on a Camry hybrid? I kinda don't get it. A person buys a car without a feature for which they have a requirement, and then complains the car doesn't have that feature?
