Battery Vent
Discussion in 'Gen 2 Prius Technical Discussion' started by Rufio24, Aug 28, 2007.
  1. Rufio24
    Rufio24 Junior Member
    I started my car up today and about a minute into my drive I heard a noise coming from my passenger side rear battery vent. At first, I thought i had the window cracked, but I didn't. So I turned my music down and when I still heard it, I got nervous. After a couple more minutes of driving the sound stopped. I don't know if I've overlooked this in the manual or haven't researched enough, but does anyone have any ideas? Is this normal???
  2. skandale
    skandale Member
    101
    Could it be as simple as the fan inside the battery vent?
    Stein
  3. Sufferin' Prius Envy
    3,998
    Just how hot was it in Herndon, VA?
    Was the car parked in the sun with the windows up?
    Had you driven the car earlier - where the traction battery could still have residual heat?
    Did you crank-up the air conditioner when you drove away?
    Any one, or a combination of the above could help explain the traction battery cooling fan coming on and going off within a few minutes . . . but exactly what did this "noise' sound like?
  4. qbee42
    3,080
    People need to be more specific when they post about noises. What sort of noise? Did it sound like a chipmunk, or Jimmy Hoffa locked under your cargo area? We may be good, but we're not clairvoyant.
  5. Rufio24
    <div class='quotetop'>QUOTE(Sufferin' Prius Envy @ Aug 28 2007, 03:06 AM) [snapback]503126[/snapback]</div>
    Not in Herndon right now, this happened in Tennessee and it's about 100 degrees over here at the moment.
    The noise sounded like the AC system except coming from the battery vent. So the fan theory sounds like it would make sense to me. I had just never heard of it switching on before.
    And yes, the car was parked in the sun, and the AC was on as I drove off. But I had driven the car in those circumstances at least 1 million times this summer, but had never heard the noise.
  6. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    The battery vent doesn't turn on very often.. but that was it. it's odd hearing it the first several times. i found it exciting. my passengers didn't hear it. they figured it was outside noise or normal vent noise. I knew it was the fan. If you start the car and climb a hill, it turns on.
  7. rudiger
    rudiger Active Member
    696
    45
    Cincinnati, OH
    <div class='quotetop'>QUOTE(V8Cobrakid @ Aug 28 2007, 12:28 PM) [snapback]503254[/snapback]</div>
    It would be even more exciting if Toyota had made the fan sound like Jimmy Hoffa locked under the cargo area.
  8. mgipe
    mgipe New Member
    <div class='quotetop'>QUOTE(rudiger @ Aug 28 2007, 09:36 AM) [snapback]503259[/snapback]</div>
    Just what would that sound like? I'm not sure I would recognize it if I heard it. :lol:
  9. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    Hmm, it sounds to me like yet another case of....
    ...... please read your owner's manual. :)
  10. qbee42
    3,080
    <div class='quotetop'>QUOTE(mgipe @ Aug 28 2007, 01:40 PM) [snapback]503291[/snapback]</div>
    Said in a muffled voice: "help, let me out, let me out of here; I can't breathe..."
    Paris Hilton locked under the cargo area: " ..." (she stops making noise when you cover her)
