a foggy question
Discussion in 'Gen 2 Prius Main Forum' started by avischwartz, Sep 2, 2007.
  1. avischwartz
    avischwartz Junior Member
    36
    It is taking a long time to defog the front window, but then I never had to put in the degrees in Celsius before. Anybody have a suggestion of the best settings to defog the front window in the shortest amount of time?
  2. Rest
    Rest Active Member
    1,210
    CA
    Of course make sure the vent is set so it is full force to the front windshield and use the A/C with whatever temp you want. The A/C will take the moisture out and thus clear the window faster.
  3. Prius 07
    Prius 07 Member
    715
    Toronto, Canada
    <div class='quotetop'>QUOTE(avi1 @ Sep 2 2007, 12:24 AM) [snapback]505688[/snapback]</div>
    Pending on the relative humidity outside vs the cabin you may want to open the window a little. This will save on the AC use. If that doesn't work use the AC as previously suggested.
    Were you able to change your display to C from F (you had a previus post on this)???
    Gabe
  4. patsparks
    10,664
    569
    Adelaide South Australia
    I just press the front window demist button on the steering wheel, works a treat!
  5. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    I love the way you word things in Australia. Makes me want to visit there soon. I'd love to rent a Prius and tour Australia, too bad I hate to fly, maybe one day i'll get up the nerve or just get good and drunk before I get on the plane Ha Ha
  6. dogfriend
    7,512
    1,191
    Carmichael, CA
    <div class='quotetop'>QUOTE(paprius4030 @ Sep 2 2007, 09:14 AM) [snapback]505866[/snapback]</div>
    The comedian Lewis Black has a routine about this, giving his reflections on flying 19 hours from NY to New Zealand. Its pretty funny.
    My GF and I flew from SF to New Zealand in 2004. It was a 12 hr flight. That's about 9 hours longer than I ever want to be on a plane in one sitting. If we ever do it again, we will get one of the planes where the seat folds down into a bed. Expensive but necessary.
  7. qbee42
    3,081
    <div class='quotetop'>QUOTE(patsparks @ Sep 2 2007, 10:52 AM) [snapback]505822[/snapback]</div>
    It also helps to have the A/C compressor enabled on the Air Conditioning screen.
  8. avischwartz
    36
    <div class='quotetop'>QUOTE(Prius 07 @ Sep 2 2007, 06:53 AM) [snapback]505772[/snapback]</div>
    Sorry Gabe, no one seems to have the answer. Avi
    <div class='quotetop'>QUOTE(Rest @ Sep 2 2007, 06:12 AM) [snapback]505765[/snapback]</div>
    Do you guys use the recycled inside air or the outside air?
    <div class='quotetop'>QUOTE(dogfriend @ Sep 2 2007, 11:49 AM) [snapback]505881[/snapback]</div>
    It is 11 hours from Tel Aviv to Newark ( when I come back to the States to visit family ) , and don't get me started on how long the direct flight to LA is.
  9. AussieOwner
    AussieOwner Active Member
    1,091
    67
    Sydney, Australia
    <div class='quotetop'>QUOTE(avi1 @ Sep 3 2007, 02:17 PM) [snapback]506154[/snapback]</div>
    My first experience with fogged windscreen was on my test drive. A cold, wet afternoon - I had driven the car a little and then handed over to the wife to give her some exposure to it (after all, had to get her approval for the expense). Hopped back into the car and fogged windscreen. Where is the button to hit the demister? The salesman had not told us about that. :huh: Found the button on the steering wheel, hit it and was very impressed with the speed the screen cleared. As far as I can remember, the A/C setting was on outside air, but considering that the key to it all is that you need to remove the water vapour, then recycled would be better, as the A/C is then really drying out the air that has already had some moisture removed.
    Don't get me started on hours on a plane - I do 3 or 4 round the world trips per year, all in "cattle" class. :( London/Sydney - 23 hours with one stopover and London/Tokyo or London/Hong Kong - 14 hours are the worst. But even a local flight (or what I consider local) Sydney/Hong Kong is a mere 10 hours. Anything less is a "walk in the park". :rolleyes:
  10. avischwartz
    36
    <div class='quotetop'>QUOTE(AussieOwner @ Sep 3 2007, 02:01 AM) [snapback]506208[/snapback]</div>
    You must really rack up the F.F. miles!
  11. rwhoyle
    rwhoyle Member
    227
    Tulsa, Oklahoma
    <div class='quotetop'>QUOTE(avi1 @ Sep 1 2007, 11:24 PM) [snapback]505688[/snapback]</div>
    Turn on the A/C and set the air temp to between 65 and 68 degrees F. The cooler air is dehydrated and will eliminate the inside fogging very quickly as the cool air absorbs the water vapor off the window.
