What's up with the horn??
Discussion in 'Gen 2 Prius Main Forum' started by PriuStorm, Sep 5, 2007.
  1. PriuStorm
    PriuStorm Senior Member
    2,239
    149
    Davis, CA
    Hey everyone in Prius-land... has anyone installed a louder horn. It's not often I honk the horn, but when I do need to, I'd like it to sound like 'beep'. Even my two-wheeled scooter has a louder horn, and frankly, if I sound off this horn behind some monstrous gas guzzling V8 F250 or the like, the driver's just going to swat away the gnat he thinks he heard, if he even hears it over his header pipes and what not.. :)
    To those who've modded, what types of horns and how's the install?
  2. Tom_06
    Tom_06 Active Member
    609
    142
    Newark, Delaware, USA
    <div class='quotetop'>QUOTE(PriuStorm @ Sep 5 2007, 12:02 PM) [snapback]507336[/snapback]</div>
    I replaced mine with the Lexus horns from Sigma. Cost $69 before shipping. Nicest thing is they fit well in the space available and plug right in to the existing wiring. They are only a little louder than the original horns, but sound a whole lot nicer.
    http://sigmaautomotive.com/horns/horns.php
    - Tom
  3. hycamguy07
    hycamguy07 New Member
    2,707
    Central Florida
    Its the cute Beep Beep horn memorable of the air cooled VW beetle. :)
  4. qbee42
    3,077
    I never use a horn, so the OEM one works fine for me. Have you considered one of the very loud air horns?
  5. Spoid
    Spoid New Member
    286
    Maybe it uses less juice. :)
  6. prius62
    prius62 Junior Member
    45
    I upgraded to the PIAA Sports horn one is 400Hz and the other is 500 Hz. I highly recommend. Sound is louder and deeper, kinda like a midsize or larger american car. I would not characterize it as extra loud, but it is a meaningful improvement.
    Install was easy...plug and play as they say. I think I used detailed instructions ....probably from this site.
  7. viking31
    viking31 Member
    515
    22
    West Central Florida
    <div class='quotetop'>QUOTE(qbee42 @ Sep 5 2007, 01:24 PM) [snapback]507381[/snapback]</div>
    You mean like this? ;-).
    Rick
    #4 2006
  8. PriuStorm
    2,239
    149
    Davis, CA
    Yep, Viking... that's exactly what I was thinking of ;)
    Well, almost...
    The PIAA sounds smart if it's that easy to install, and the Sigma too. On my Burgman (scooter) I have a Stebel which is a nice sound, too. Thanks for all the great suggestions.. I will try to find the thread that explains how to install it... that'll be helpful!
  9. patsparks
    10,664
    567
    Adelaide South Australia
    Move to Australia, mine is plenty LOUD!!!
  10. jonjonbear
    jonjonbear New Member
    105
    Bastrop, TX
    <div class='quotetop'>QUOTE(PriuStorm @ Sep 5 2007, 11:02 AM) [snapback]507336[/snapback]</div>
    I had the same problem with my Miata. They make a really cool double air horn that is all built in to one piece. The double horn is built around the compressor motor and it easily replaced the one flat horn behind the bumper of the Miata and is VERY loud. I think it shocks people when they hear this commanding sound out of a tiny car. Pretty cheap too:
    http://www.mmmiata.com/catalogsite/electrical01.php
    Page down to the "bad boy horn"
    I will probably put one on my new Prius when it gets here..
    John
  11. bredekamp
    bredekamp Member
    569
    Somerset West, South Africa
    BEEP BEEP
  12. silversyren
    silversyren New Member
    29
    lay on the horn hard enough and it sounds.. normal instead of being beep beep. ;) If I have to honk, I do it hard, two short blasts.
  13. Katebell1977
    Katebell1977 New Member
    66
    Orange County Calif
    dh wants to put a ferrari one on my ba by
  14. Tom_06
    609
    142
    <div class='quotetop'>QUOTE(PriuStorm @ Sep 5 2007, 06:34 PM) [snapback]507541[/snapback]</div>
    One set of instructions is at http://www.vfaq.net/mods/Horns.html
    I now have the Lexus horns from Sigma. They are true plug and play with exactly the same connectors as the original Prius horns. They are my second set of replacement horns as I first put in a pair of Hella horns. Those needed more fussing with the wiring as the connectors weren't an exact match and you had to run a separate ground wire. I had to replace them after a collision with a deer that left one horn crushed and the second one inoperative (probably the poorly fitting Prius-to-horn connector).
    - Tom
  15. sparkyAZ
    sparkyAZ übergeek
    311
    Mesa, AZ
    I find that it's best not to use the horn while driving (if it can be avoided) since there is a good chance of being shot if you do honk at somebody doing something stupid. :( That being said, there's something to be said for volume. :blink: :D
    Maybe something like this could fit in the hatch:
    [attachmentid=11724]
    Or for something with a little more gusto:
    [attachmentid=11725]
  16. hawaiiguide
    hawaiiguide Junior Member
    35
    Honolulu
    We have the opposite situation. Sometimes we come close to people and vehicles while in the silent mode.
    Because of this they may get startled if we use the horn... which is much too loud in most situations.
    We would like to install a ring, ring bicycle bell under the hood.
    Anyone have any ideas on how to do that?
  17. wazzzup
    wazzzup Junior Member
    I'd like to replace the horns on my Prius but not if I have to rewire and put in a relay. I read that the Prius uses only the horn switch for the horns. Does anyone know if this is true. If there is a relay, is it heavy enough to support a louder horn or would it have to be changed?
  18. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    <div class='quotetop'>QUOTE(hawaiiguide @ Sep 29 2007, 11:24 AM) [snapback]519116[/snapback]</div>
    I'll bet a doorbell could work off the 12v system.
  19. patsparks
    10,664
    567
    Have an auto electrician install the horn with a relay if you really want it louder or you will be limited by the capacity of the wiring and switch. Wiring a relay is easier than changing the horns!
    Just fitting a relay to the original horn would make it louder by boosting the available voltage.
  20. priusrapper
    priusrapper New Member
    Maryland
    I must admit, I love my prius, but I'm embarrassed to use the horn.
