Upgrade to JBL Radio
Discussion in 'Gen 2 Prius Audio and Electronics' started by ryanschram, Sep 4, 2007.
  1. ryanschram
    ryanschram New Member
    Is it possible to upgrade the stock radio from no-JBL to the JBL 6disc changer without using the JBL Amp?
    I shorted out my audio outputs on the non-JBL and have found a replacement JBL version for less than what it would cost to replace it under warranty.
    I have a 4-channel amp running with the JL Audio CleanSweep.
  2. Tideland Prius
    16,540
    probably best if you added a CD -Changer and speakers of your choice.
  3. Vagabond
    Vagabond Active Member
    1,198
    Southern California
    <div class='quotetop'>QUOTE(Tideland Prius @ Sep 4 2007, 09:02 PM) [snapback]507143[/snapback]</div>
    That's not his problem. He's not going for better sound quality. He blew up the radio he already has.
    BTW, I think the answer is gonna be Yes.
  4. beboyle
    beboyle Junior Member
    39
    Phoenix
    <div class='quotetop'>QUOTE(ryanschram @ Sep 4 2007, 07:08 PM) [snapback]507071[/snapback]</div>
    The JBL amp includes a lot of the necessary electronics to use the JBL stereo - for example, the volume control on the radio just sends a signal to the amp, it doesn't directly change the output levels from the head unit. When the amp is unplugged all the "Sound" controls on the display are disabled.
  5. Vagabond
    1,198
    Southern California
    <div class='quotetop'>QUOTE(Bruce Boyle @ Sep 5 2007, 04:10 PM) [snapback]507570[/snapback]</div>
    Ugg, I knew there was something to the amp I was forgetting about. My bad.
  6. Tideland Prius
    16,540
    <div class='quotetop'>QUOTE(Vagabond @ Sep 5 2007, 12:51 PM) [snapback]507474[/snapback]</div>
    ohhh oops.
    So he has an amp running JL Audio etc etc and he just wants to know if the JBL radio with the CD Changer will work with his current setup?
  7. Vagabond
    1,198
    Southern California
    <div class='quotetop'>QUOTE(Tideland Prius @ Sep 5 2007, 07:09 PM) [snapback]507709[/snapback]</div>
    That's what it sounds like.
  8. ryanschram
    <div class='quotetop'>QUOTE(Tideland Prius @ Sep 5 2007, 09:09 PM) [snapback]507709[/snapback]</div>
    yes, that is exactly what i'm asking.
  9. beboyle
    39
    Phoenix
    <div class='quotetop'>QUOTE(ryanschram @ Sep 8 2007, 10:39 AM) [snapback]509123[/snapback]</div>
    Sorry, the simple answer is "No". The radio and amp are integrated in the JBL system, and it isn't possible to use either separately.
  10. beboyle
    39
    Phoenix
  11. ryanschram
    <div class='quotetop'>QUOTE(Bruce Boyle @ Sep 11 2007, 09:51 PM) [snapback]511018[/snapback]</div>
    yeah, i figured that out the hard way. Anybody wanna buy a new JBL-type Head Unit?
  12. ryanschram
