The Prius driver's version of hell
Discussion in 'Gen 2 Prius Main Forum' started by abq sfr, Sep 7, 2007.
  1. abq sfr
    abq sfr New Member
    690
    Albuquerque, NM
    Not that any of us would go there, lets toss around a Prius driver's version of hell. Any other ideas for the devil?
    Hell: Endless traffic lights 1/4 mile apart with 70 mph speed limit in between; endless H1s in front and 2 feet from your back bumper; 130 degrees so your AC is sucking up your ICE; you can never go more than 7 mph so never get any brake regen; its ALL uphill; your spouse thinks you're lost; and your kids need to go potty!
  2. benighted
    benighted New Member
    530
    Westport, WA
    <div class='quotetop'>QUOTE(abq sfr @ Sep 7 2007, 06:44 AM) [snapback]508533[/snapback]</div>
    Thats not so bad. Real hell would be having to drive one of those H1's instead of a Prius.
  3. Danny Hamilton
    Danny Hamilton Active Member
    926
    94
    Greater Chicagoland Area
    <div class='quotetop'>QUOTE(abq sfr @ Sep 7 2007, 09:44 AM) [snapback]508533[/snapback]</div>
    If I can't go more than 7 mph, then the 70 mph speed limit doesn't really matter.
    If the lights are 1/4 mile apart, then I should be able to see the next one and perhaps time it a bit so I don't have to use the brakes (especially if nobody is getting much higher than 7 mph anyhow), so I shouldn't really need the regen. (Unless of course the lights change randomly, or worse yet, the lights are set up to time me and make sure I always have to stop. :eek:
    I don't mind the H1 in front of me so much, because I can draft behind him ( at 7 mph? <_< ).
    I just ignore the H1 behind me, heck I'm probably his personal hell :D
    It's the A/C and the uphill that are the real killers.
    I'm assuming the NAV must not be working since the spouse thinks I'm lost, is there a dealer nearby that can fix it? Is the car still within the warrantee time period and miles? I assume not. :huh:
  4. abq sfr
    abq sfr New Member
    690
    Albuquerque, NM
    <div class='quotetop'>QUOTE(benighted @ Sep 7 2007, 09:15 AM) [snapback]508543[/snapback]</div>
    Hard to argue with that one! :D
    <div class='quotetop'>QUOTE(Danny Hamilton @ Sep 7 2007, 09:33 AM) [snapback]508559[/snapback]</div>
    the lanes on either side are going 70 trying to pass you and get between you and the H1 in front. I got package 2 so no Nav. Oh... YOUR Nav has the voice of Rosanne!
  5. PA Prius
    PA Prius Active Member
    762
    251
    SE Pennsylvania
    <div class='quotetop'>QUOTE(abq sfr @ Sep 7 2007, 10:44 AM) [snapback]508533[/snapback]</div>
    Lone Prius on the freeway full of large SUV's, no exit for 100 miles, and a blinking pip.
    PA P
  6. Stev0
    7,201
    1,074
    Northampton, MA
    2022 Prius Prime
    Let's see my typical drive:
    Endless traffic lights 1/4 mile apart (or stop signs): check
    130 degrees so your AC is sucking up your ICE: Not 130, but muggy enough so the AC runs constantly; I'll call this a check.
    ts ALL uphill: Coming back, it's more uphill than not; going there, even though it's a lot of downhill, my engine is still warming up, so it doesn't matter.
    OMG, I live in Hell!
  7. galaxee
    galaxee mostly benevolent
    9,810
    469
    MD
    worst of all would be having to sell the prius...
  8. moxiequz
    moxiequz Weirdo Social Outcast
    2,781
    Bay Area, CA
    Driving in Portland, OR. Of course that really isn't specific to the Prius but having recently gone through that excruciating experience I thought I'd through that out there.
  9. echase
    echase New Member
    227
    The 2017 prius ships with a small cold fusion reactor, and never needs refueling. By government mandate it is only available for drivers of the Hummer H1, as a trade-in.
    Alternate hell: Toyota contracts Microsoft to provide the software that runs the Prius. A government "safety" recall mandates all owners have the new software installed.
    Prius Heaven: Apple partners with toyota for the design of the new prius. It has a high efficiency mode that does automatic P&G, Ultracapacitors, Plug-In mode and solar panels... oh, and because that is not great enough it also has a built-in espresso machine and will give you a manicure when parked. Of course if you want one in the first year it will cost $95,000, and it can only use Exxon fuel.
  10. pottedmeat
    pottedmeat New Member
    17
    <div class='quotetop'>QUOTE(Greenkeeper @ Sep 7 2007, 02:26 PM) [snapback]508663[/snapback]</div>
    Unfortunately for you, Apple/Toyota cuts the price by $20k two months after you've already bought one.
    Fortunately for you, they're offering you a free travel mug as compensation.
  11. brick
    brick Active Member
    1,083
    79
    Upstate NY
    I think having it taken away would qualify as hell for most of us.
