The weight of Prius 16" alloy wheel
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Lim, Sep 10, 2007.
  1. Lim
    Lim Junior Member
    Hong Kong
    Does anyone know the weight of Prius 16" alloy wheel? Thanks.
  2. treehggr
    treehggr New Member
    230
    <div class='quotetop'>QUOTE(Lim @ Sep 10 2007, 03:57 PM) [snapback]510300[/snapback]</div>
    I think the 15's are right around 14lbs so my guess would be about 15-16lbs? As for exact I have no idea. Although I could be completely off. :unsure:
  3. Lim
    Lim Junior Member
    Hong Kong
    <div class='quotetop'>QUOTE(treehggr @ Sep 12 2007, 05:04 AM) [snapback]510801[/snapback]</div>
    I have changed the wheel to Enkei RS+M size 16x7 and the actual weight is 14.55 lbs. I picked up the two wheels by hand in wheel shop and found Enkei is little bit lighter than the stock alloy wheel. So 15-16 lbs is reasonable.
  4. cairo94507
    cairo94507 Active Member
    923
    36
    Auburn, CA, USA
    I don't know what the heck that said. So what is the weight of the 16" wheel? Unless you hand is a scale, I would be skeptical.
  5. cairo94507
    923
    36
    Auburn, CA, USA
  6. Tideland Prius
    16,602
    15s are 6.5kgs so ya about 14lbs.
  7. a priori
    a priori Canonus Curiosus
    3,083
    408
    Chicagoland (West)
    I'm not an engineer (disclaimer!). I suppose the weight of the wheels is important, but wouldn't the weight distribution be valuable information as well? Not being a physicist either (more disclaimer!), I thought the angular momentum would be important for stability and for inertia. Of course, wouldn't this also affect the energy required to start and stop the car?
    OK. Does any of this mean anything in terms of control of the car, general safety and/or mileage?
  8. mkiefer83
    mkiefer83 Junior Member
    45
    Ypsilanti, MI
    I am an engineer who used to work at an automotive tier 1 braking supplier, so hopefully this will make sense (even though, I'm electrical and I'm about to spout off mechanical knowledge)...
    From a fuel economy standpoint, you want a lighter wheel. You want a light wheel because the less the wheel weighs, the less the electric motor and ICE will have to work to get the wheel rolling (lower rolling inertia).
    Lower weight wheels not only will improve but they'll also improve braking from the same standpoint. Your brakes won't have to work as hard to get the mass of the wheel to slow down. I'm not sure about what kind of effect this would have on regenerative braking, but it could mean less wear and tear on your actual brakes. For instance, if you see some guy rolling 24" rims on a big SUV with the tiny stock brakes still on the car... not so smart from a safety standpoint
  9. blamy
    blamy Member
    380
    Central Florida
    More unsprung weight; Bad
    Less unsprung weight; Good
  10. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    From USBSea:
    CE28 ECO DRIVE (Volk Racing Wheels made for Prius)
    15 inch: 4.6kg (10.1 lbs)
    16 inch: 4.9kg (10.8 lbs)
    Toyota OEM Rim
    15 inch 6.5kg (14.3 lbs)
    16 inch 6.9kg (15.2 lbs)
    Tideland Prius likes this.
  11. CalvinL
    CalvinL 2025 Prius Plugin XSE Royal Green PPF
    100
    28
    Long Island, New York
    2025 Prius Plug-in
    XSE
    I will only add that if you want more information on wheel weight versus fuel effeciency to read up a little on "Rotational Mass".
    Do not forget that some wheel designs are not meant for the street especially wheels/rims designed for certain types of racing where it doesn't require a lot of lateral force (sideways).
    -Calvin
