Oil overfill
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by PR, Nov 15, 2004.
  1. PR
    PR New Member
    Two weeks and 300 miles ago I got a new Prius (05, BC).
    Yesterday I checked the oil level, and I found that it is
    overfilled by approx. 0.5in (1.27cm). Unfortunately, the
    dealer I bought the car from is a bit too far away (100 miles)
    to drive there and get the extra oil drained for free.
    This morning I went to the local Toyota dealer and I was told that
    the price for draining the extra oil will be only $0.75 cheaper
    compared to complete oil change ($32).
    This price seems a bit too high for just draining sth. like 0.4qt so I just
    made an appointment for tomorrow morning and left.
    I was wondering whether shall I:
    (a) Don't worry about the 0.5in overfill and keep driving the car.
    (B) Bite the bullet and do complete oil change with the local dealer.
    © Do something else.
    Yes, I know that draining the extra oil is very trivial for those of
    you who change the oil by yourself, but doing it by myself is
    an option I don't want to consider for now.
    I know it will take me lots of time to find the right place to do it, and then
    I will make lots of mess :D
    Unless you tell me that I can cleanly remove the extra oil from the top
    by using some tiny plastic tube...
    Thanks,
    PR
    P.S. Love the car!
  2. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    Call the dealer where you purchased the car and speak to someone with authority.
    The selling dealer should pay the dealer nearer your home to perform the correction.
  3. jchu
    jchu New Member
    1,063
    Nampa, ID
    Worry about it, overfill can cause frothing leading to decreased lubrication.
    Get them to fix the problem ( at no charge ) as it was their mistake
    In the future if you are having someone else changing the oil bring your own oil 3 to 3.5 quarts; that way they can't overfill it.
    This seems to be a perennial problem as there are numerous other older threads on PC about this.
  4. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    It is possible to drain it through the fill tube, but you would need the proper size hose and a pump of some sort. Inboard boat engines (at least sail boats) are generally drained the way since the drain plug is not accessable.
  5. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    How to reduce the oil level via the dip stick:
    1) insert dip stick entirely into tube.
    2) remove dip stick.
    3) if oil too high, goto 4; else, goto 10.
    4) wipe oil from dipstick.
    5) goto 1.
    10) end.
  6. jchu
    jchu New Member
    1,063
    Nampa, ID
    Tony,
    With half an inch over the full line, the Priapus method PR is gonna take a lo...o...ong time. :lol: :p
  7. bruceha_2000
    3,054
    302
    Northwest VT
    2018 Prius Prime
    Tony does seem to have some ideas that are not as practical as one might like. ;-)
  8. TonyPSchaefer
    14,816
    2,501
    66
    Sorry y'all. I was just in a fiesty mood. :-D
    And now that I think of it, as the overall oil level drops, the amount of oil removed with each wipe diminishes.
  9. PR
    PR New Member
    <div class='quotetop'>QUOTE(TonyPSchaefer\";p=\"50675)</div>
    Believe it or not, yesterday I considered for a moment a similar algorithm
    after I failed to find a tiny tube in the local auto-parts
    store. Until I made the back-on-the envelope calculation
    that I have to "pull" approx. half a quart/liter of oil.
    Well, in my algorhthm I didn't use "goto", but this didn't
    change the execution time :)
    Anyway, thanks for the suggestions. Tomorrow morning
    I am going change the oil with the local dealer to avoid
    developing any potential problems.
    PR
  10. jchu
    jchu New Member
    1,063
    Nampa, ID
    If you mean the local Toyota dealer that doesn't preclude and overfill. Be sure to check
  11. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    ive taken oil out of the filler tube before with a turkey baster and plastic tubing.
    have also done it with tranny fluid which wasnt nearly as easy to do. for some reason, it was much tougher to snake the tubing down far enough to draw anything.
    there are also siphon hand pumps for a few bucks that work. you will most likely have to reduce the diameter of the tubing for it to go all the way but standard aquarium tubing i found is more than small enough.
  12. Gurmail
    Gurmail Member
    247
    Oakland, CA
    In my Prius, bought nearly 4 months ago, now at 3550 miles(approx.), the oil is also about .5 inches higher than the high mark. The dealer I purchased from is also far away( 300 miles). After reading the posts/opinions here and the manual which warns about damage to the hybrid system in case of overfill, I too was worried. However, I decided that there would be some logical tolerance for error. Toyota would (hopefully) put the high mark a little lower than the point that would lead to actual damage as many people are likely to overfill it by a little bit. Hence I have decided to wait till the first oil change-around 5000 miles to rectify the problem. The car does seem to vibrate a bit while in electric mode, ie it is not totally smooth, the steering vibrates as if the engine were running. I hope it is not related to the oil. Having waited so long, I paln to just wait a bit more now. I haven't driven much in the last month and probably won't drive much for another month( wife busy at the university) , so I'll probably have to wait 2-3 months before the oil change :roll:
  13. john1701a
    john1701a Prius Guru
    12,820
    5,305
    58
    1/2 inch beyond the full mark is overfill, which bad for the engine.
    There's simply no excuse for missing the middle, between "add" and "overfill", so greatly. That's whole quart more than they needed to add. Remember, 3.9 quarts is the maximum. More than that is beyond the full mark. In other words, too much.
  14. bruceha_2000
    3,054
    302
    Northwest VT
    2018 Prius Prime
    <div class='quotetop'>QUOTE(Gurmail\";p=\"51019)</div>
    Half an inch?!?!? I'd worry about that, it is WAY more than just a little over. You'll note from John's picture that the entire 1 quart range is 1 5/8". Use Dave's turkey baster or even Tony's dip-wipe-dip method if necessary, but do something.
    I don't think there would be a connection between oil overfill and vibration when running in Stealth, the engine isn't on.
  15. AngelFish
    AngelFish New Member
    119
    SoCal
    What we have done to our cars when our dealer overfilled was draining through the dipstick tube. It takes a while, but there are instructions on this site (somewhere) on how to drain out the extra.
  16. richard schumacher
    7,664
    1,046
    United States
    I wonder whether Japanese and Americans simply have different mindsets about this? Americans seem to think that an engine is happiest when the oil is right up to the FULL mark, and that there must be some ill-defined margin for error beyond both ends of the ADD-FULL range. But the way the Prius oil system is set up, exactly three quarts, a nice round convenient amount, is halfway between the ADD and FULL marks. I infer that all of the safety margin is between that point and the ADD and FULL marks, and so there is *no* safety margin beyond the ADD and FULL marks. (Do Americans want to keep their bellies full all the trime, and are Japanese comfortable being a little hungry part of the time?) Under that interpretation you see exactly what the safe limits are, with no guessing about how careless the people adding the oil or checking it at the low end are allowed to be.
    I'd say, snarl at the dealer who screwed up and have him pay for having it drained down or changed at your earliest convenience. If he resists, call Toyota and complain. They should be sympathetic and helpful because the dealer's error may set them up for the cost of an expensive warranty repair.
  17. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    I always thought it was good to keep the oil at the full mark especially in the small 4 cylinder engines mainly to help keep some of the heat away. Since they hold such a small amount of oil anyway I always believed that even running them a half a quart low would help the heat buildup more than it should in the oil.
  18. bruceha_2000
    3,054
    302
    Northwest VT
    2018 Prius Prime
    Pure conjecture, but as the ICE will burn a little bit of oil even when new, starting at full probably guarantees you won't be below the fill mark before the next scheduled oil change. Probably more important as the engine gets higher miles on it and burns more dues to normal wear. Richard's analogy - eat to full at dinner and you'll have room for more food in the morning. But you won't die if you don't eat for a few days. :)
  19. Gurmail
    Gurmail Member
    247
    Oakland, CA
    I agree bruceha. I also thought (hoped) that the level may drop a bit with time but, alas, it hasn't. Upon reflection, the oil is more like 1/4 of an inch over, not .5. Hpefully less harmful.
  20. john1701a
    12,820
    5,305
    58
    With the 59,827 miles I drove in my 2001 Prius, the oil-level only dropped 1/16" over the course of each 7,500 mile interval. The need to be at full is nothing but old-school advice with no merit to Prius care.
    The recommended 1/4" below full provides a substantial buffer, so large that you'd have to lose so much oil that you'd notice a puddle growing on garage floor or a build-up of soot near the tailpipe. The engine simply won't leak like that.
    And of course, we have already proven that going from 3/8" above full to 1/4" below will improve your MPG.
