oil change and rotate tires today
Discussion in 'Gen 2 Prius Main Forum' started by priussoris, Sep 14, 2007.
  1. priussoris
    priussoris New Member
    1,005
    I have had my oil and tires rotated at the dealer in the past, today I did this myself, man how easy was that , well the oil change anyway.
    Rotating the tires sucked, had to use the spare while doing the rotate since the floor jack I used has a large seat that there was no room to place a jack stand so out comes the BUTT UGLY yellow spare.
    Could they have used an uglier color or what.
    found I have a sidewall cut from driving in rocks at the lake:( while resetting tire pressures.
    Other than using the spare to aide in the rotation of tires, all went well. also I know it is not overfilled.
    May never take the car to the dealer again for oil and filter /tires Well except for in the winter time. :D
  2. derkraut
    derkraut Member
    299
    28
    SAN
    <div class='quotetop'>QUOTE(priussoris @ Sep 14 2007, 12:44 PM) [snapback]512644[/snapback]</div>
    Congratulations Craig. You can now sleep tonight--knowing that your "friendly" dealer hasn't fleeced you from some of your hard-earned cash. :)
  3. JimboK
    JimboK One owner, low mileage
    2,817
    189
    49
    Chesterfield, VA
    <div class='quotetop'>QUOTE(priussoris @ Sep 14 2007, 03:44 PM) [snapback]512644[/snapback]</div>
    Doubtful!
  4. Neicy
    Neicy Member
    834
    Wakefield, MA.
    :lol: OMG Do they put that side down in the storage area or is the entire rim that color? That's embarassing..... Oh! That's so you don't drive on it too long, right?
  5. conv65
    conv65 New Member
    Jefferson City MO
    Craig
    How big was the seat on your jack? I am about ready for my first oil change but was concerned about rotating the tires as to how the jack stands would fit. My dealer as you know is the same as yours. Did you have any trouble with them overfilling the oil?
    Jim
  6. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    <div class='quotetop'>QUOTE(jcon @ Sep 14 2007, 07:53 PM) [snapback]512789[/snapback]</div>
    When I rotate mine I use my floor jack and the scissor jack and use 2 jacks so I can raise up both the front and rear at the same time, remember to bust all the lugs before raising, I then remove the wheels and do the swap. Just remember that when the car is on jacks not to let anyone get in the car. It should only take about 15 minutes.
  7. Blegate
    Blegate Prius Gen III 2013
    132
    Vancouver, WA
  8. redrockprius
    redrockprius redrockprius
    167
    30
    Murray, UT
    I had my tires rotated for the first time yesterday. I went to the tire retailer located closest to my home. When making the appointment on the phone, they quoted $12 for the rotation. This retailer sells several brands of tires and is not directly affiliated with any particular manufacturer. When they finished the job they surprised me by telling me that they do not charge for rotating Goodyear tires (one of the brands they handle) so long as they are either original equipment or had been purchased from them. They emphasized that they would not extend that "courtesy" for tires purchased online.
    [For anyone who lives in southwest Utah, the retailer is Dixieland Tires.]
  9. Spoid
    Spoid New Member
    286
    <div class='quotetop'>QUOTE(RedRockPrius @ Sep 15 2007, 09:10 AM) [snapback]513016[/snapback]</div>
    Wow, sounds like they are really trying to earn customers.
  10. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    It's a good opportunity to not only view the butt-ugliness of the
    donut in all its glory for yourself, but to also check its pressure
    and condition and sweep the random detritus out of the bottom of
    the spare tire well. And maybe even put a little mileage on the
    car's emergency jack if you use that for the tire swapping.
    Raising one whole side of the car only helps with rotation if you're
    doing a pure front-to-back, mandatory if you own the directional
    Hydroedges. That doesn't work for the traditional cross-front-
    straight-back pattern recommended for other cars sometimes, but
    the Prius manual suggests keeping wheels on the same side anyways.
    _H*
  11. JimboK
    2,817
    189
    49
    Chesterfield, VA
    <div class='quotetop'>QUOTE(Neicy @ Sep 14 2007, 06:30 PM) [snapback]512748[/snapback]</div>
    I wondered the same when I had to dig mine out. As though Toyota figures the American motoring public must be motivated more by appearance than safety. Of course they could be right. ;)
    It's just the outside (i.e., downside in the well) painted Ugly Yellow. That's why I never knew it until I had a flat.
  12. marvmmarv
    marvmmarv New Member
    Arizona
    The owner's manual shows spots to lift each end with a floor jack. I haven't tried the Prius yet (it's new) but with other cars, I lift an end and then throw jack stands under the jacking points on the sides. Then lift the other end. Not too high, barely high enough to remove the wheels, so you don't have to lift them too high to replace them.
    I remove the drain plug first and then switch the wheels. Gives the oil a nice long time to drain and cool before I go back and button everything up.
    Has anyone tried the designated lift points?
    Marv
  13. msirach
    msirach Member
    321
    Southern Illinois
    I have two inexpensive floor jacks. One is a larger jack and the other is a cheap lightweight one from Walmart. It is very light and it takes just a few minutes to jack one side up and swap the tires.
  14. priussoris
    1,005
  15. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    <div class='quotetop'>QUOTE(priussoris @ Sep 16 2007, 09:11 AM) [snapback]513272[/snapback]</div>
    The manual shows a cross over pattern for the tire rotation.
  16. patsparks
    10,664
    567
    Adelaide South Australia
    Crossing over gives a more even wear but front to back is good if you use directional tyres.
