Scan gauge II problems
Discussion in 'Gen 2 Prius Main Forum' started by slair, Sep 17, 2007.
  1. slair
    slair Ubër Senior Member
    404
    Lafayette, IN
    I've searched for topics on this and didnt find anything.
    Ever since I've gotten my SCII, its killed my battery at least 3-4 times in a month. I have it set on Hybrid in the fuel type and I think that might be the culprit. The SCII stayes on even when I turn off the car, because it thinks the engine is just in "hybrid mode". The SCII wont turn off after its 15 min. of inactivity (or however long it is).
    Has anyone else had this same problem with the SCII and changed the fuel type, will that do it?
    Thanks
  2. john1701a
    john1701a Prius Guru
    12,819
    5,304
    58
    <div class='quotetop'>QUOTE(Slair @ Sep 17 2007, 08:02 AM) [snapback]513626[/snapback]</div>
    20 seconds.
    Longer after powering off is clearly an indication of a problem.
  3. brick
    brick Active Member
    1,083
    79
    Upstate NY
    Quirky behavior has been reported in the past, though I believe this is the first time anyone has reported it killing a battery. (How much current does it draw? I'm surprised it's enough.) Some have hypothesized that smart key activity on the CAN wakes up the ScanGauge, which sits there trying to read information. You could try switching out of hybrid mode but then it would be pretty useless since it whould shut off every time the engine shut down.
    Does Ron browse these forums? Has anybody talked to him directly about this?
  4. Tom_06
    Tom_06 Active Member
    609
    142
    Newark, Delaware, USA
    <div class='quotetop'>QUOTE(brick @ Sep 17 2007, 09:55 AM) [snapback]513651[/snapback]</div>
    It draws very little current. Mine likes to turn itself back on periodically. I noticed yesterday afternoon that it was on (car in dark garage). The car started fine this AM after 14+ hours with the scanguage on.
    - Tom
  5. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    I think your battery dieing is something else. SG II doesn't draw enough to kill it, even after several days.
    Changing the fuel type will not fix the problem. The SG II will then not work properly at all.
    You can get the firmware upgraded, but I'd wait until they have the CAN message part finished. They do have a current update that is supposed to fix the quirky turn-on/off problem. Note that mine also "locks up" periodically, usually when the car is off. I have a display with one line of garbage characters, and no response to button presses. Just unplug the RG45, and plug it back in. This is also fixed in the current firmware upgrade, I'm told. The problems are supposedly caused by power "bumps" on the OBDII CAN port, where the SG II gets its' power.
    To get the firmware upgrade, you have to send the unit back to them.
  6. anti-gas
    anti-gas Reduce, Reuse and Conserve
    56
    South Florida
    Agreed on the SG not killing the battery. My son left the rear dome light on once and it stayed lit for just over 30 hours, it didn't kill the battery and that amazed the heck out of me! The car was only a few days old when that happened. Since then, we had a long talk with the 7 year old about touching that dome light! I think that was a bad place to put a dome light, right near a potential child.
