Package #2 Vs. Base and why pay the difference.
Discussion in 'Gen 2 Prius Technical Discussion' started by acdii, Sep 17, 2007.
  1. acdii
    acdii Active Member
    1,124
    131
    I purchased a base model, mainly because it was all they had, and it was the last day of 2.9% financing. Lets just say my wife and I liked the car from the start.
    As I was wondering what differences there were between models and why should one pay ~$1500 more for a #2 package, I looked into what you get. From what I see, you get to play a CD full of MP3's. OK, well I think an Ipod and Dice are far less expensive, and the other feature was the smart key. Hmm, so I dont have to press a button to unlock the car, or slide the fob into a slot to start it. OK, $1500 sounds OK for a lazy rich feature, but then it dawned on me why that is one feature I wouldn't want. Being that I am a Security specialist, soon to be professional, I started thinking about ways to protect my car. If stolen, there are plenty of high dollar parts on it that would appeal to thieves, the battery being one of them. Without the key fob, the car wont start, nor can you unlock the doors. The door locks from what I heard are also pretty hard to jimmy. Now with the Smart key, it is based on what I believe is RFID. Someday soon, if not already, someone will hack the RFID systems, and once they know what frequencies that the Prius uses, it wouldn't take them long to figure out a hacking algorithm to use to crack the locks on the Prius, once they have that they have the ignition code too. Then all they need to do is locate a Prius with the Smartkey system, which is easy to spot, just look for the little black square on the door handle or hatch and you found one. Walk up to it with their scanner and run the program, once it locates it, the doors unlock and they can start the car and off they go. At least without that feature, they first have to figure out how to unlock the doors, then have a method of inserting a fob that will match the RFID, which would be much more difficult and noticeable since they have to sit in the car and wait for the program to find the right code. Since there is a certain radius that the devices work in, they can find one in a parking lot and if they can park next to it, the can sit in their car and run the program and listen for the doors to unlock. Once they do that , they know the code, get out of their car, into yours, press the power button and good bye car.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,195
    Nixa, MO
    There is a hack...you only need to be about 10 feet from the car with the right software and a spare hour on your hand to crack the code.
    No car is impossible to steal, but the SKS equipt Prius is one of the most difficult.
    Whether the $1500 is worth it to you or not is purely personal preference...but to me the SKS may be the single best option the car has, it's a smart simple convenience that one day will be the norm for all of us.
  3. MarkMN
    MarkMN New Member
    226
    Downtown Minneapolis
    Hmmm, I don't know why you are thinking so much about it.
    For me, it was simple -- Back-up camera. I usually park (as in 99% of the time) in tight spaces, either in tight parking ramps, parallel parking on the curb, or in parking spaces that back up to small alleys, and the back-up camera is non-negotiable. A few cases of bumping into a parking garage support pole or another car, and the body work (and paint job since the paint would most likely scratch) is expensive enough to make the back-up camera well worth the intial expense. And one bump to a kid in the Target or Lunds (grocery store) parking garage and I wouldn't be able to forgive myself.
    As for the smart key, I think it is a nice feature, but not 1500 dollars nice (and I am not sure of your security concerns are worthy or not?). And the CD player is nice too, but usually on long trips, wife wants quiet so she can sleep, and the ipod is much more used; but CD player does get used.
    Otherwise, the base Prius is nicely equipped!
  4. mamerica
    mamerica Junior Member
    31
    Minnesota USA
    I bought the #2 package because of the stability control. Consumer Reports recommended it.
  5. catgic
    catgic Mastr & Commandr Hybrid Guru
    586
    141
    HTTP 404 Not Found
    HTTP 404 Not Found
  6. judymcfarland
    judymcfarland Queen of Moral Indignation
    578
    Glendale, WI
    That back-up camera is worth the $$$ by itself, especially if your depth perception is not great (like mine). I find the Prius VERY easy to park as I can know that I have room to back closer to the car behind without hitting. That's not to say that the fish-eye view out the back doesn't take getting used to - but I can back in with confidence that I won't hit anything or anyone. (Now if I could only figure out where the front end of the car is. . .) :)
  7. hawaiiguide
    hawaiiguide Junior Member
    35
    Honolulu
    <div class='quotetop'>QUOTE(catgic @ Sep 17 2007, 04:17 PM) [snapback]513899[/snapback]</div>
    Doesn't it also turn the interior lights on when you approach and leave the car?
  8. acdii
    acdii Active Member
    1,124
    131
    Ahh, didnt know it had a backup camera. Personally I havent had issues backing it up, then again I used to drive an 18 wheeler and backing is second nature, never use the center rearview for anything but watching the kids. I guess another way of stating it would be, if you cant find a #2, but just a base, you really aren't losing out.
    BTW what is the difference between the #2 cruise control and the one in mine? Last I checked, there weren't any squirrels to feed, so it must be electronic.
  9. psikot
    psikot New Member
    63
    for me i mostly got #2 because of the ipod jack and the back up camera. i rented a prius before i bought one and the camera is essential. without the camera backing up is difficult to judge how far from an object you are, and parallel parking was close to impossible. due to the back of the car the rear window is only used to see cars that are far away, there is no way to see cars that are close up. by the way small children are impossible to see behind the car without the camera.
