2001-03 Prius 65-70 miles per hour
Discussion in 'Gen 2 Prius Technical Discussion' started by bwilson4web, Sep 13, 2007.
  1. bwilson4web
    16,352
    Hi folks,
    I recorded a trip from Huntsville AL to Knoxville TN using the ICE air flow for fuel consumption and MG2 rpm to calculate speed. Two cruise control speeds were used, 65 miles per hour and 70 miles per hour and the data generated this chart:
    Several things stand out:
    • cruise control variance +/- 2 miles per hour
    • @65 miles per hour, ICE idle (backside of hills) gives +200 MPG
    • @70 miles per hour, ICE idle disappears except below 70 miles per hour
    Early on I found highway milage dropped off around 70 miles per hour and at 75 miles per hour, it was pretty low, 39 MPG. But this data shows the actual boundary is fairly sharp and suggests the mechanism.
    The 2001-03 Prius, model NHW11, has a speed limit on MG1 rpm, 6,500 rpm. With an ICE idle speed of 1,200 rpm, that comes out right at 70 miles per hour. Sure enough, below 70 miles per hour, the ICE can idle with very low fuel flow. At 70 and above, the ICE has to run and burn fuel:
    http://eahart.com/prius/psd/
    The best strategy is to set the cruise control to the highest speed that still allows ICE idle and stays under 70 miles per hour. The optimum cross country, cruise control speed looks to be 68 miles per hour, 110 kph, as anything faster and MPG will take a hit.
    There are a scattering of points up at 500 MPG but they are relatively sparse. I'll continue to look at the data to see if I can figure out what is going on. In the meanwhile, 68 miles per hour is my new, favorite cross country speed.
  2. bwilson4web
    16,352
    Hi folks,
  3. Joekingiam
    Joekingiam Junior Member
    59
    Akron, Ohio
    <div class='quotetop'>QUOTE(bwilson4web @ Sep 13 2007, 07:16 AM) [snapback]511821[/snapback]</div>
    Hi Bob,
    Thanks for the info, I'll try it next month on a trip to Windsor.
    Do you know what the readings are supposed to be from the 02 sensor after the convertor using a voltmeter?
    I have a bad sensor or convertor.
    Joe
  4. bwilson4web
    16,352
    <div class='quotetop'>QUOTE(Joekingiam @ Sep 19 2007, 07:45 AM) [snapback]514743[/snapback]</div>
    I'm looking at pp. DI-81 of the 03 Prius Diagnostics manual, volume 1, and it shows both O(2) sensor voltages. The first one swings .25-.75 V and the second O(2) sensor swings about .6-.7 V. This is under code P0420. BTW, this is after running the vehicle for at least 5 minutes at 89 kph / 55 mph on top of an "idling warm-up."
  5. douglas001001
    douglas001001 smug doug
    222
    Chicago
    I think this is great information, is there a way to get the related rpm/throttle/etc settings for each point?
    What I would think would be a great help for people who want to get an extra 2 or 3 mpg on the highway would be to translate this data into an efficiency chart by mph with the following
    mph across the top with the related engine state for
    1)steady state in flats
    2) hill climbing
    3) hill descending
    4) picking up speed in flats
    If someone wants to turn off cc and work a little bit it would be good information to have numbers to drive to without having to figure out the best spot when driving on unfamiliar terrain and speeds.
  6. SureValla
    SureValla Member
    590
    Shelton, CT
    amazing plot I love when people actually back things up with raw data
    Can you detail a little bit of your setup you have to create that data? (or link me somewhere that does)
  7. bwilson4web
    16,352
    <div class='quotetop'>QUOTE(douglas001001 @ Sep 19 2007, 12:56 PM) [snapback]514857[/snapback]</div>
    Let me describe what I have recorded (it is a huge file) and we can talk:
    GPS - recorded all NEMA text to a file
    Graham Scanner - recorded these fields:
    1) MG1 rpm (also provides torque at same interval)
    2) MG2 rpm (also provides torque at same interval)
    3) throttle airflow sensor grams/sec
    4) MG2 torque (also provides rpm at same interval)
    5) MG1 torque (also provides rpm at same interval)
    6) battery amps
    Using the 'end' times, I combine the following into rows in a massive spreadsheet:
    1) GPS time-stamp
    2) GPS latitude (degrees)
    3) GPS longitude (degrees)
    4) GPS altitude
    5) scanner time stamp #1
    6) MG2 rpm
    7) MG2 torque
    8) scanner time stamp #2
    9) MG1 rpm
    10) MG1 torque
    11) scanner time stamp #3
    12) battery current
    To sync everything, I use the last records from the scanner and GPS recorder so the GPS data correlates with the Graham scanner data. The sampling interval is one second.
    I tend to drive on cruise control as much as possible because it leads to reproducible results. However, there were segments at lower speeds. Certainly, I have no problem with sharing the data other than it is a bit large. The last time I checked, my spreadsheet was 27 MBytes.
    Another alternative is using just the first hour, not all five hours. Would you be interested in a smaller sample? Any idea of the size limits for attached files?
    ps. sample data headers:
    Sat Cnt - count of GPS satellites seend
    Sec - absolute seconds, UTC
    trip sec - relative time to trip duration
    Alt. - GPS reported altitude
    Lo. deg - Longitude in degrees
    La. Deg - Latitude in degrees
    MG2 rpm -
    MG2 Nm
    Sec - time stamp for air flow data
    Air g/s - throttle air grams per second
    Sec - time stamp for following data
    MG1 rpm
    MG1 Nm
    Sec - time stamp for battery current
    Batt A - traction battery amps
    Formula and Constants - handy constants and forumlas
    Time - derived time stamp for following data
    Alt - GPS altitude copied from column
    M/sec - calculated speed based upon MG2 rpm and tire size
    fuel g/sec - actual fuel flow
    MG1 Nm - counter engine torque
  8. echase
    echase New Member
    227
    Bob, I've got no time to actually analize the data, but i've got plenty of web hosting space, if you want me to post it for others to go over.
