How is the ICE Cupled to the PSD?
Discussion in 'Gen 2 Prius Technical Discussion' started by mamerica, Sep 22, 2007.
  1. mamerica
    mamerica Junior Member
    31
    Minnesota USA
    I have read how the Synergy Drive works with the Engine and Power Splitting Device, how MG1 starts the engine, etc. My question is: How is the Engine attached to the drive? Is there some sort of clutch mechanism? Also, are there any pictures of the components that make up the drive around here?
    Thanks in advance,
    -Marty
  2. bwilson4web
    16,387
    <div class='quotetop'>QUOTE(OutOfHere @ Sep 22 2007, 09:38 PM) [snapback]516391[/snapback]</div>
    Bolted to the ICE flywheel is a torque limiting device that looks like a clutch plate but it is fixed, never open. The plate has some small springs, just like a regular clutch plate, but these help moderate the power pulses. Under high power conditions, the torque limiting device can slip, like a clutch plate, to limit how much torque goes to the PSD.
    From the torque limiting device, the ICE power passes via a shaft that is welded to the PSD, gear carrier. This planetary gear carrier holds the spider gears between the center sun gear and the outer ring gear. The sun gear is connected to MG1 and MG1 provides the counter torque for the engine power. When MG1 has no power applied, it rotates freely and no ICE torque or power is transfered to the ring gear.
    The power from the ring gear passes via a chain to the rest of the gears and to the differential and wheel shafts.
  3. mamerica
    31
    Minnesota USA
    So the ICE is directly coupled to the PSD. So the planet carrier is stationary while the ICE is not running (EV mode)?
    This thing is way cool! I've been into engines since I was a kid. I've tinkered with everything from minibikes and go-karts to Hot-Rod Chevy engines, but this drive is too cool. It is truly ingenious. How long was this in development? It's light years ahead of anything here in the U.S.
  4. justlurkin
    justlurkin Señor Member
    499
    63
    Long Island, NY
    Here's a real neat "PSD simulator" that lets you see the rotational speeds of the various components (sun gear, planetary gears, ring gear, planetary gear carrier, etc.) under various conditions: http://www.wind.sannet.ne.jp/m_matsu/prius...index_i18n.html
    It's great for visualizing what's moving, how fast, and when. Cool stuff. B)
    Yep, the planetary gear carrier remains stationary when the ICE isn't running (so while the planetary gears remain in their respective positions, they still spin in-place to transmit rotation between the ring gear and sun gear). Very ingenious in its elegant simplicity.
    This slideshow at the University of Michigan says it was TRW that developed the PSD concept and Toyota developed its practical application by putting it in a hybrid car: http://www.engin.umd.umich.edu/vi/w4_works.../Miller_W04.pdf
    It is indeed way cool!
  5. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    Is there any sort of "brake" to prevent the ICE or electric motor from turning when they're off? E.g., if you're in stealth mode is the ICE held still?
  6. bwilson4web
    16,387
    <div class='quotetop'>QUOTE(alanh @ Sep 23 2007, 12:54 AM) [snapback]516459[/snapback]</div>
    When the engine is stopped, it looks like there is a brief power pulse to MG1 to de-spin the engine. Testing with "N"-"D"-"N" reveals a slight shudder if the ICE comes to a stop on its own. Once stopped, compression drag is enough to keep the ICE from spinning.
    When considering the possibility of making an EV Prius, one excellent approach is to weld-up the ICE shaft so MG1 and MG2 can be used to power the wheels. For details about one effort:
    http://www.99mpg.com/ProjectCars/evinsight/
  7. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    <div class='quotetop'>QUOTE(bwilson4web @ Sep 23 2007, 08:58 AM) [snapback]516512[/snapback]</div>
    Just to clarify Bobs excellent description, the "brief power pulse" is actually there to stop the ICE in one position only. If it misses, you can feel it retry. I've felt mine try as many as three times (car is still new, so I surmise it's more difficult to get to one position due to engine stiffness).
  8. burns_fisher
    burns_fisher Burns
    60
    NH
    <div class='quotetop'>QUOTE(David Beale @ Sep 23 2007, 12:44 PM) [snapback]516528[/snapback]</div>
    Interesting! Does anyone know WHY it the HSD designers want the ICE stopped in the same position all the time?
