First Oil Change
Discussion in 'Gen 2 Prius Main Forum' started by dhoward, Sep 23, 2007.
  1. dhoward
    dhoward Junior Member
    Massachusetts
    Tuesday I am taking my 2007 Prius into the dealer for it's 5000 mile service. Is it the general consensus that I should tell them to put only 3.5 quarts of oil into it?
  2. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hi Dhoward,
    I fill my oil filter with oil, install it, and then put in 3 quarts. Comes out perfect. 1/4 inch below the top mark.
  3. O-Mel-Prius
    O-Mel-Prius Junior Member
    31
    Manchester, MO
    <div class='quotetop'>QUOTE(dhoward @ Sep 23 2007, 11:41 AM) [snapback]516520[/snapback]</div>
    Hello DHoward,
    Melody also from Mass., I just got to 1200 miles on my 2007.
    Is this your first time back to your dealer?
    Did you purchase the car from Ira Toyota in Danvers?
    Since they sell and service Prius shouldn't they know?
    Given that the car been on the market for 10 years?
    Please let us know how the oil change works out.
    Melody
  4. Raider
    Raider New Member
    103
    donee,
    Why not just get a larger capacity oil filter; one that will hold more oil?
  5. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    you should tell them to just put 3 qts. in because that gets it up past the halfway part on the dipstick.
  6. dhoward
    Massachusetts
    Mel.
    Yes this is my first time back to my dealer. I bought my Prius from Ira Toyota in Danvers. Until I started monitoring this forum I never was worried about how much oil you should put in a vehicle. According to many posts on this forum it seems that even dealers put to much oil in the car causing the oil level to be above the full mark on the dip stick. I would have thought dealers should know how much oil it takes but a number of people seem to have had a different result. I thought the consensus was 3.5 quarts vs 3.9 or 4.0 quarts. The responses in this thread seem to be 3 quarts. I have to admit that I find it hard to believe the dealer does not know how much it takes. I think, now, I will just raise the question when I take it in and see what they say. I will let you know my results.
    [/quote]
  7. beboyle
    beboyle Junior Member
    39
    Phoenix
    <div class='quotetop'>QUOTE(dhoward @ Sep 23 2007, 01:08 PM) [snapback]516600[/snapback]</div>
    I just got my first oil change done by the dealer where I bought the Prius, and sure enough the oil level shows over .5" high on the dipstick. This is actually one of the better dealers in the area for service, based on past experience. We started going to them a few years ago because the we were looking for a dealer with a service department that appeared to be competent and relatively honest. I'm dissapointed that they got this wrong.
  8. dhoward
    Massachusetts
    Just out of curiosity has anyone had the correct amount of oil put in by the dealer without saying anything? If so how many quarts did they add?
  9. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    people, the book says 3.9 quarts. if you do not specify otherwise, the guy at the dealership is gonna go by the book because his job depends on it. that does not make him an idiot. if it he puts in more than 3.9, yes, he is an idiot. if you make a request and it is not followed, then it is a customer service issue.
  10. ACORNBLUES
    ACORNBLUES New Member
    87
    <div class='quotetop'>QUOTE(dhoward @ Sep 23 2007, 10:41 AM) [snapback]516520[/snapback]</div>
    I just changed my oil too. After letting the oil drain for 15min, I put in 3.4 qts and that went all the way to the full mark. I would recommend trying 3 qts 1st.
  11. Family Hybrid
    Family Hybrid Junior Member
    87
    I just changed my oil as well. I did the 5K service, which is nothing more than an oil change and a tire rotation, at 4664 miles in preparation for a trip later this week. I switched to Mobil 1. I used almost all 4 quarts (less than a 1/4 of qt. left over) and was dead on the full mark after I ran the engine.
    Nothing to it. Everything is very easy to access, even for those of you doing it in your driveways.
    I will have to comment on the selling dealer one more time, however. <_< When we bought the car they put Nitrogen in the tires for free. However, they only put in 30psi worth of Nitrogen. I thought the car wasn't handling quite right in turns. When I rotated the tires I set the fronts to 42psi and rears to 40psi as per recommendations on this board (factory setting is 35psi F&R). Car handles much better now with very little degradation in ride quality.
    Let's see if the synthetic oil and higher tire pressures improve fuel economy any.
    Quick question: I reset the Maint. Req. light as per the owner's manual. Does this also reset the mileage counter in the MFD (under the Maintenance screen)? I didn't see a way to do it, and that screen still says I have 300 miles remaining before my oil change.
  12. dhoward
    Massachusetts
    How can the manufacturer, Toyota, be so wrong on the amount of oil the Prius requires. The manual says 3.9. People on this board, depending on the thread, say anywhere from 3.0 to 3.5 quarts. That means Toyota is off by as much as 25% on their own vehicle. As Mel said this car is been in production in the US for 7 years so how come no one can fill the oil correctly unless you do it yourself? This has to be the most basic service any car requires. Also, only a fraction of Prius owners read this forum. Most owners have no knowledge of this controversy. So why is this not noted by other automotive magazines or sources like Consumer Reports?
  13. Highly ImPriused
    Highly ImPriused Impressive Member
    250
    Western NY
    When I brought my Prius in for its first oil change at the dealer (done for free), I requested 3.5 qts based on what I had read on this forum. The service guy told me they would do it as long I recognized that is less than what Toyota specifies. They also noted on the receipt that I requested that amount. The level was just below the high mark on the dipstick.
    I just did the second oil change myself over the weekend. I put a total of 3 qts in (including filling the filter first) and that brought the level just about midway between the low and high marks on the dipstick. After letting the engine run a few minutes and checking again, the level remained right there. So I don't see any reason to put in more than 3 qts. In fact, too much can be bad for the engine and result in lower mpg.
    Seems the techs know this a problem but still put in 3.9 because that is what Toyota specificies. I suppose on a completely empty brand new engine with no residual oil whatsoever (you never get it all out), the actual capacity is 3.9 qts but it seems stange to specify that amount for an oil change when anyone who does it recognizes that using that amount would put the level above the high mark.
  14. dhoward
    Massachusetts
    I just got back from the dealer. I showed him the TSB regarding overfill and asked them to add to the service form about not overfilling. They did add it. When the car was finished I checked the oil level and it was perfect. About an 1/8" below the full mark. Overall my 1st experience with the dealer went well. I was going to tell them to add only 3.5 quarts but I wanted to see what they did on their own.
  15. Neicy
    Neicy Member
    834
    Wakefield, MA.
    <div class='quotetop'>QUOTE(dhoward @ Sep 25 2007, 10:02 AM) [snapback]517373[/snapback]</div>
    I'm thrilled to hear that! Was it Ira in Danvers? Please do spread the good news!
    How did your tire pressure do after rotating?
  16. dhoward
    Massachusetts
    Yes, it is Ira Toyota of Danvers. The tire pressure was set to factory specs. That did not surprise me. I will just up it on my own. The oil was my concern.
  17. FloridaWen
    FloridaWen New Member
    573
    Plant City, Florida
    <div class='quotetop'>QUOTE(ACORNBLUES @ Sep 23 2007, 07:49 PM) [snapback]516658[/snapback]</div>
    Sounds like the SAME procedure I did at 4,800 miles. I "primed" my new oil filter and then (once drain plug, new gasket and filter properly installed) I filled with 3 quarts at first, checked oil dipstick, then ended up with a total of 3.4 QTS. (including oil I used in filter) and it brought the oil level on the dipstick to FULL !! Where the heck do they get 3.9 quarts from ???? That would severly overfill the engine, which, F.Y.I. when we purchased the new '07 Prius this past May, I checked the oil dipstick and it was about 1/4" ABOVE full line. I wonder if the factory "overfilled" it or the Dealer "topped-it-off" ?? Also, I have heard MANY on this forum complain the factory (original) oil filter was installed way, way too tight. I used a KD "cap-type" oil filter wrench with standard 3/8" drive socket handle (and 3" extension bar) and I found mine was NOT over-tightened at all. Maybe late "07's were "correct" as they probably got too many complaints about this problem on the early '07's ?? Just my 2 cents !! :D
  18. richard schumacher
    7,666
    1,047
    United States
    I provide my tech with 3 quart bottles of oil and tell him not to top it off. Works beautifully. No fuss, no muss.
    BTW, and it's sad to have to do this, but always, always, always, wait a few minutes and check the oil level yourself before driving away. If it's overfilled more than 1/4 inch or so make them drain it down. And if god forbid they didn't tighten the filter or drain plug, this will become evident before any harm is done. (Be nice to the tech and tell them before they start working on the car that you will do this. And then do it.)
  19. FloridaWen
    573
    Plant City, Florida
    <div class='quotetop'>QUOTE(richard schumacher @ Sep 29 2007, 01:45 PM) [snapback]519094[/snapback]</div>
    I know that for some it is easier to have the DEALER do the oil/filter change, for others it is not allowed at their Condo or Apt. even if they wanted to do it themselves. After being a Service Manager back in 2004 (Chrysler) and seeing all the half-nice person, shortcuts, and just plain sloppiness the High School drop out that was stoned 90% of the time, who was our official Oil Changer person, do on 99% of the vehicles including high end Vettes, Mercedes, BMW's, Chryslers, etc., stripping the drain plug or leaving it loose, never changing the drain plug gasket, NEVER (unless he dropped one and could not find it) dropping NEW Oil Filters and picking them up (dented) and using them........ yep I've seen it all, and more........ I would NEVER have a DEALER perform an oil/filter change on ANY of my vehicles. JUST MY OPINION and "beliefs" and I know that there are MANY Dealers that do superb work, but I, myself was personally "screwed" back at a Volvo Dealer in 1973 in Stratford, CT. on my brand new 1973 144EA who left the "old" oil filter gasket on and put the NEW Oil Filter right over it....... leaked all the way home and lost about TWO quarts of oil over the short 12 mile drive back home to Milford. I FIXED IT MYSELF and then went back to raise Hell. I got NOWHERE trying to calmly explain to the Service manager then raising my voice was the next step. His "crew" of mechanics wanted to beat the crap out of me for being "obnoxious" and didn't believe THEY did such a stupid thing, especially when the problem was "fixed" (by me) so I could drive back there (after adding oil too).
    By the way, that Volvo Dealer went out of business shortly after this incident !!
    Since that day in 1973 I have changed oil/filter/drain plug washer on EVERY VEHICLE I have owned since including my girlfriend's, then my Wife's, and her family if they wanted. Oil/filter change is NOT for everybody as a "do-it-yourself" ......... it's messy and proper disposal of oil and filter is a real pain sometimes, but the PEACE OF MIND that the Oil Filter is torqued (tightened by hand) just right, the drain plug has a new gasket and is tightened properly, and the oil is exactly what I purchased, filled to the exact level that "I" want it to be, is well worth it to me. By the way, presently I am 55 years old and have been doin' this stuff for over 35 YEARS with confidence and a great feeling of self-worthiness !! :D
  20. cubbyg
    cubbyg Junior Member
    57
    Just tell the dealer that if they overfill...... It's free. They hate to loose a penny!!!
    Or better yet do it yourself. Go on ebay and buy an original toyota filter and plug washer. 3 1/2 qts of yur favorite oil 30 minutes later yur done.
    http://stores.ebay.com/TRDparts4u_W0QQsspagenameZL2QQtZkm
