Is 2007 Prius purchased in Oregon OK for California
Discussion in 'Gen 2 Prius Main Forum' started by sloopG, Sep 23, 2007.
  1. sloopG
    sloopG New Member
    40
    I want to buy a used 2007 Prius from an owner in Oregon and register the car in California. I asked her to check the emissions plate but she doesn't understand what I am looking for. Does anyone know if all 2007 Prius sold in Oregon is compliant with California emission rules?
    Though it would be good to check before I have the car shipped to California.
    sloopG
  2. Godiva
    Godiva AmeriKan Citizen
    10,339
    I believe all Prii sold in the U.S. conform to California emissions.
  3. apriusfan
    apriusfan New Member
    6,050
    205
    S.F. Bay Area
    <div class='quotetop'>QUOTE(sloopG @ Sep 23 2007, 07:17 PM) [snapback]516711[/snapback]</div>
    As Godiva posts, the 2007 Prius is a '50 state' (e.g. U.S. Federal plus California) emissions-compliant car. However, there is one advantage to taking delivery of your Prius in California - the California car's emission control system components are covered by a 10 year/150,000 mile warranty. Since these bits are generally the most expensive to repair, you effectively have an extended warranty for no additional cost. If your seller does not know where the emission sticker is located, have her go to the nearest Toyota dealer and ask them to show her. P.S.: It is located on the underside of the front of the hood on the 2007 Touring edition. It is also white in color, has the words Toyota on the upper left portion and Catalyst on the lower right portion of the sticker.
  4. PriuStorm
    PriuStorm Senior Member
    2,239
    149
    Davis, CA
    Hmm... I thought California required any vehicles purchased out of state (whether 50 state or not) to be used, where used is defined as having 7500 miles or more. I know for a fact that a person who bought a new 50-state motorcycle in Florida was unable to register it here in California because of that requirement. If it were me, I would verify for sure that DMV will hold the Prius exempt from this requirement. If miles are greater than 7500 miles, I don't believe there should be a problem, regardless whether the vehicle is 50-state or not.
  5. apriusfan
    6,050
    205
    S.F. Bay Area
    <div class='quotetop'>QUOTE(PriuStorm @ Sep 23 2007, 10:03 PM) [snapback]516756[/snapback]</div>
    Someone is giving you wrong information. The 7,500 mile requirement is for vehicles not meeting the California requirements. See:
    http://www.dmv.ca.gov/pubs/brochures/howto/htvr9.htm
    I purchased my MINI out of state and had it delivered to California. All that was required to register the MINI was a SMOG test and a trip to the local DMV. Once the DMV inspected the car's emission compliance sticker to confirm conformance with California emissions standards and I paid them the taxes and license fees I left the DMV with plates and registration stickers. All told, it was about a 2 hour effort, starting with commencement of the SMOG test.
  6. PriuStorm
    2,239
    149
    Davis, CA
    <div class='quotetop'>QUOTE(apriusfan @ Sep 24 2007, 12:11 AM) [snapback]516761[/snapback]</div>
    Well, that explains that then. ;)
  7. inventor00
    inventor00 Active Member
    1,131
    60
    Phoenix, AZ
    And your vehicle is exempt from a SMOG inspectionin CA:
    http://www.dmv.ca.gov/vr/smogfaq.htm#BM2536
    Does my vehicle qualify for a smog exemption?
    Smog inspections are required unless your vehicle is:
    Hybrid
    1975 year model or older
    Diesel powered
    Electric
    Natural gas powered and has a Gross Vehicle Weight rating of 14,001 lbs. or more.
    Motorcycle
    Trailer
  8. apriusfan
    6,050
    205
    S.F. Bay Area
    <div class='quotetop'>QUOTE(inventor00 @ Sep 24 2007, 05:16 AM) [snapback]516819[/snapback]</div>
    Given that an attempt was allegedly made to register an out-of-state purchased motorcycle and motorcycles seem to be exempt from SMOG tests, I wonder why the motorcycle couldn't be registered? Someone is not telling all.
  9. ricklin
    ricklin New Member
    When I came back to Cali in 1994 if your car was not Cali certified they would ding you like 300 bucks per car. As a "smog impact fee" or some such. I had two non cali cars, ouch 600 bucks on top of all the other outrageous fees.
    I called a couple of wrecking yards, the radiator shrouds (where the cali sticker was then) were in hot demand, seems they were getting a couple of hundred for them, because they only look for the sticker.
    Fast forward a couple of years, Cali had to give all that money back, I got a check back, no interest of course.
    It seems they were asked to prove that the money they were collecting was going toward what it was intended for. Of course they could not, the money went directly to the general fund.
    At that time the cars had to have X miles on them b4 you could register in Cali. One of mine barely made it.
    That's the way I remember it anyway, don't know where things stand now.
