Toyota issues safety recall
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Tideland Prius, Sep 26, 2007.
  1. Tideland Prius
    16,604
    WASHINGTON - Toyota Motor Corp. said Wednesday it is recalling optional "all-weather" floor mats in 55,000 Lexus ES 350 and Toyota Camry passenger cars because the mat could interfere with the gas pedal and lead to a crash.
    The National Highway Traffic Safety Administration issued a consumer advisory about the heavy-duty rubber floor mats, noting that if unsecured, the map could move forward and trap the gas pedal, causing the vehicle to accelerate uncontrollably.
    In the Toyota recall, NHTSA urged drivers of other vehicles, including the Avalon and Prius, to check the driver-side floor mats to ensure they were properly installed. NHTSA spokesman Rae Tyson said it was taking the step "because we believe potentially it is a very serious safety issue."
    Toyota spokesman Bill Kwong said the automaker had not received any complaints about the Avalon and Prius. In some cases, he said the floor mats - used to collect rain water, mud and snow - were stacked on top of the original carpet mats and wedged up against the accelerator.
    The vehicle has hooks on the floor that can only secure one mat at a time.
    Toyota has received 22 complaints and learned of six accidents allegedly connected to the issue. Kwong said they did not know of any injuries linked to the mats.
    The Japanese-based automaker plans to notify owners in early October and expects replacement mats to be available at dealerships by late November.
    In a statement, Toyota advised owners to regularly check that their floor mat is properly secured and said "under no circumstances should more than one floor mat ever be used in the driver's seating position."
    Owners can contact Toyota at (888) 270-9371 or (800) 331-4331 and Lexus owners can call (800) 255-3987 for more information.
  2. dogfriend
    7,512
    1,190
    Carmichael, CA
    There is a warning molded into the all weather mat that says not to use them with the original mats in place.
    I thought that was a little overboard, but apparently I was wrong.
  3. AOV
    AOV New Member
    302
    Poughkeepsie, NY
    I have the clear mats from "ExactMats". They have that backing that grips the original mats very well, they do not budge one bit. Yet, for extra protection, they do come with "clear Gator Clips" that fasten to the original mats if you want to use them, but I see no reason for it.
