No 2-way radios?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by JoeyJoeJoShabadoo Jr, Sep 29, 2007.
  1. JoeyJoeJoShabadoo Jr
    48
    New Jersey
    In my '08 manual it says not to use 2-way radios in the vehicle as it could interfere with radio frequencies of the car. I take long drives on interstates and have always used a CB radio to communicate with truckers for bear sightings. Has anyone installed a cb radio and has it affected the car? I'd really like to know if i can install mine. I also figure that if i did install it and it did mess something up, shouldnt that still be covered in my warranty. How would toyota know if i had a cb in the car or if i just passed a truck with a massive transmitter/reciver?
  2. vuapplepudding
    vuapplepudding New Member
    75
    Nebraska
    I've used a "portable" 5 watt CB in my 2006 Prius. That means that the antenna was inside the cabin of the PRIUS. No problems that I know of.
    Also used the GRMS/FRS portable radios. No problems to report.
  3. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    There are several posts on POL where HAM operators installed radios in the Prius with no interference problems.
  4. qbee42
    3,079
    It's just a CYA statement in case you use a radio and it causes problems.
  5. subarutoo
    subarutoo New Member
    1,213
    Chatsworth, CA
    I've seen several city agency Prius with large whip antennae attached, so somebody must be making them work. I've seen them on Honda Civic Hybrid official city service cars, too.
  6. tochatihu
    tochatihu Senior Member
    9,797
    3,772
    Kunming Yunnan China
    2001 Prius
    Prius emits a lot of RF noise, especially below "CB" frequencies. If you transmit with 100 watts or less, there is little chance of irritating the car.
