The Prius on gravel with Nokian WR tires
Discussion in 'Gen 2 Prius Main Forum' started by David Beale, Oct 4, 2007.
  1. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    OK, I admit I love to drive on little travelled gravel roads out in the middle of nowhere. But my Prius was really squirrelly on gravel, and I didn't want to get her dusty anyway so I was avoiding those roads.
    Last week I got my Nokian WR tires (stock size 185/65-15R in 88H load/speed range). Inflated to 40/38 PSI. So today I went to visit a friend who happens to live off a gravel road. No longer squirrelly! Amazing difference. I guess that is all that was wrong, just garbage cheap tires (Goodyear Integrities). Do watch out though, the Nokian WR is a real rock storing and throwing tire. Nice deep tread!
    Couple of observations on the tire change. Speedo still reads right on (GPS comparison). When they were mounting the tires I picked up a wheel (the stock one) to inspect the TPMS. I almost threw it in the air it was so light! Nice wheels!
  2. qbee42
    3,079
    <div class='quotetop'>QUOTE(David Beale @ Oct 4 2007, 01:24 AM) [snapback]521032[/snapback]</div>
    I had a terrible time with the OEM tires and gravel. Down in Kentucky, where we rock climb, we had to unload the Prius and make running passes at the driveway to get up. It wasn't much fun. I'll be trying it again in a few weeks, but this time on different tires. I'll post the results.
  3. Tideland Prius
    16,615
    Good to know! Also, bad about the rock bit. I've always had rocks in my tyre treads so having a tyre that holds more rocks will be a pain cause it's either I live with the rocks making noise every time the tyre rotates or I pick them out one by one.
    The stock rims are 14lbs each I believe.
  4. priusFTW
    priusFTW Gen III JBL non Nav
    434
    White Mtns New Hampshire
    I love my set of Nokian WR's and I will buy them again.
