Emergency Brake Assist
Discussion in 'Gen 2 Prius Main Forum' started by PriusOwner004, Oct 5, 2007.
  1. PriusOwner004
    PriusOwner004 New Member
    191
    I was on the freeway doing the 65 limit and the guy in front of me slammed on the brakes and so did I. What I noticed was the applied pressure on the brakes was a lot more than what I've intended, but in fact that was a good thing! So brake assist not only works, but there is a reason for it. Computers do think faster than humans. I don't think I would have hit the car in front even without brake assist, but in a real emergency situation they can save a life, I now have no doubt! Well done Toyota!
    Anyone else had already experienced "brake assist?"
  2. ACORNBLUES
    ACORNBLUES New Member
    87
    I appreciated the feature too. It lasts a bit after I lifted my foot. Fortunately I read the manual and did not freak out.
    <div class='quotetop'>QUOTE(PriusOwner004 @ Oct 5 2007, 07:56 PM) [snapback]522021[/snapback]</div>
  3. qbee42
    3,079
    <div class='quotetop'>QUOTE(PriusOwner004 @ Oct 5 2007, 08:56 PM) [snapback]522021[/snapback]</div>
    Yes, I've had it happen a couple of times with all of the deer and other wildlife frequenting our roads. The Prius stops right now!
  4. tochatihu
    tochatihu Senior Member
    9,744
    3,761
    Kunming Yunnan China
    2001 Prius
    According to earlier reports, Prius notices if you move your foot from the accel to brake pedal very quickly. It interprets this as a request for maximum possible deceleration, and pumps fluid accordingly. You already noticed the result!
    Good thing you were not being tail-gated.
  5. Tideland Prius
    16,539
    good to hear it works well!
  6. patsparks
    10,664
    567
    Adelaide South Australia
    And because the car has ABS you can steer the Prius around if you don't have room to stop in time.
    Good to see there was no exchange of paint.
  7. brick
    brick Active Member
    1,083
    79
    Upstate NY
    I'm a huge fan of brake assist! I've activated it twice, maybe three times and was glad to have it.
  8. galaxee
    galaxee mostly benevolent
    9,810
    470
    MD
    twice, the second time 2 days ago when someone veered into the offramp lane from a dead stop. i was going 55, they had to be doing 10. i stomped on the brake as soon as they looked like they were gonna swerve over due to the speed differential. i would have otherwise plowed into the back of that car.
    i'm glad i have the all weather mats, because the cottage cheese container exploded all over the place when it hit the floor...
  9. partipilo
    partipilo Weirdo
    76
    West Palm Beach FL
    Yesterday I had to do a panic stop for the first time. I was really surprised to experience how quick and responsive it was. No delay at all, very fast deceleration. Well done.
  10. Dr Ed
    Dr Ed New Member
    188
    I had to stop abruptly from a high speed and found that my Pri wanted to swerve. I had to apply forceful muscle tension to the steering wheel to correct it and keep it from swerving to the other side after I got it straight. Street was dry, did not skid, and I have Comfortreads. I expected the Prius to perform better than that.
  11. mjms2b
    mjms2b MJ Green
    349
    Socal
    I've done this myself, I recall a cat in the road, being the nice guy i am i had to slam on the brakes, actually the car slammed almost to a hault, but i only meant to slow. I was a bit bothered by it at first, now I'm thinking its' a good thing.
  12. PriusOwner004
    191
    <div class='quotetop'>QUOTE(Dr Ed @ Oct 8 2007, 10:00 PM) [snapback]522940[/snapback]</div>
    This don' sound right. There must be a problem with your car. I'd tell your mechanic about it.
  13. qbee42
    3,079
    <div class='quotetop'>QUOTE(Dr Ed @ Oct 8 2007, 11:00 PM) [snapback]522940[/snapback]</div>
    You should have bought a VSC package.
  14. partipilo
    partipilo Weirdo
    76
    West Palm Beach FL
    <div class='quotetop'>QUOTE(qbee42 @ Oct 9 2007, 09:09 AM) [snapback]523060[/snapback]</div>
    Pkg #3 should have VSC. Pretty sure? I agree with previous poster that you should see your dealership and have that corrected. Something is mechanically incorrect.
  15. hill
    8,784
    Some of us are fans of hypermiling now & then. 65mph? Why, that's just CRAZY talk. :D
    Our crowd find the low speed route to get to and fro. They don't find as many oportunities to be anywhere close behind the 65mph crowd . . . although we have been known to be a little too close to the 55mph trucks over there in the slow lane :p
