what is the bladder all about?
Discussion in 'Gen 2 Prius Main Forum' started by swfoster2, Oct 12, 2007.
  1. swfoster2
    swfoster2 New Member
    Sorry - I guess I should already know this, but what is the "bladder" and how does it differ from a conventional gas tank? Sounds intriguing.......
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Someone posted this earlier (see attachment).
    Essentially it helps eliminate the evaporative emissions.
  3. swfoster2
    That's really cool- thanks! the pics are great too. This is ust one more thing that makes me like my Prius so much...Do any other cars have this type of fuel tank?
  4. patsparks
    10,664
    567
    Adelaide South Australia
    It's all part of being a super ultra low emission vehicle.
  5. Tideland Prius
    16,621
    <div class='quotetop'>QUOTE(patsparks @ Oct 12 2007, 12:55 AM) [snapback]524479[/snapback]</div>
    Partial zero emission under California regulations... one step below (above?) SULEV.
  6. Ichabod
    Ichabod Artist In Residence
    1,794
    Newton, MA
    Yeah, my window sticker says "AT PZEV" or "Advanced Technology Partial Zero Emissions," which is lower than SULEV, and sounds cooler.
    Thanks for that doc, Evan, I hadn't seen that one!
    Cheminee, here's a thread with some fun pictures of a Prius gas tank being taken apart: http://priuschat.com/index.php?showtopic=31545
  7. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    <div class='quotetop'>QUOTE(cheminee @ Oct 11 2007, 11:30 PM) [snapback]524457[/snapback]</div>
    With the bladder comes the variability in tank capacity.
    It's best to not sweat the "absolute" quantity of fuel in the tank. On my 2006, I know that a half tank takes about 4-6 gallons to fill, which makes sense. I don't bother running down to one or two pips. Nor do I care about trying to achieve a high mileage before refilling---when it's convenient, I fill up. Usually that's at the half-tank time. On the slowest pump setting, I have enough time to wash the windshield.
    And I never try to "stuff" more fuel into the tank. When the pump shuts off, we're done. On a few occasions, a pump just won't cooperate: it keeps shutting off and I have to change pumps. A few times, a pump hasn't shut off automatically.
    When the last pip begins to flash, you don't know how much fuel is left. The remainder can change with temperature. So all you know is to buy fuel now.
  8. swfoster2
    Thanks for the link Ichabod- I never cease to be amazed by what the Prius has inside it...... :blink:
