Most Obscure Prius Facts (Way out there)
Discussion in 'Gen 2 Prius Main Forum' started by 200Volts, Nov 20, 2006.
  1. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    <div class='quotetop'>QUOTE(orionll @ Oct 15 2007, 12:53 AM) [snapback]525752[/snapback]</div>
    Exactly. I wish the Current bar was placed on the left (closest to the driver) and the other bars progress rightward from there. Seems like that would be, from the perspective of a left-side driver, the most intuitive.
  2. ChrisHenry
    ChrisHenry New Member
    SoCal
    Man, I just lost most of Sunday reading this thread top to bottom. Some fun stuff. Thanks to everyone for posting.
    Data Daedalus likes this.
  3. 100 mph
    100 mph Junior Member
    40
    <div class='quotetop'>QUOTE(qbee42 @ Nov 21 2006, 11:57 AM) [snapback]352617[/snapback]</div>
    Yes, I stumbled onto it when I had to open the hatch after the car battery died (left the Smart key function on for a week).
  4. patsparks
    10,664
    567
    Adelaide South Australia
    <div class='quotetop'>QUOTE(Tideland Prius @ Oct 11 2007, 05:52 AM) [snapback]523790[/snapback]</div>
    Like I said, it's local lingo here and in Kiwiland and isn't intended to offend at all. The word is used in the name of a lot of Australian businesses (Look here http://www.google.com.au/search?hl=en&...=cr%3DcountryAU ) and I doubt any of them intend to offend especially when they do business in Japan. I recall conversations at Adelaide Jap Dismantlers http://www.adelaidejap.com.au/ about the guys going to Japan to gather parts, I can't see them having a name that upsets their suppliers.
    Sorry about the off topic post.
  5. patsparks
    10,664
    567
    <div class='quotetop'>QUOTE(zenMachine @ Oct 15 2007, 03:09 PM) [snapback]525748[/snapback]</div>
    When you read you read from left to right, after half an hour of driving you have a half hour history of the car's average fuel consumption from left to right, the way you read. An ociliscope has a trace that moves from left to right so the oldest data is on the left and you read the data from left to right.
    I wish the consumption button was on the bottom right of the MFD on right hand drive models.
  6. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    This is for 06 and up.
    EDIT: The "Outside Temp" moves around if you switch from the Energy or Consumption screen to the Air Conditioning screen. Sloppy UI designer!
  7. Stev0
    7,201
    1,074
    Northampton, MA
    2022 Prius Prime
    Just discovered this this evening: The "Auto" button on the driver's door stays lit even with lights cranked down as far as possible.
  8. dogfriend
    7,512
    1,190
    Carmichael, CA
    <div class='quotetop'>QUOTE(usbseawolf2000 @ Oct 18 2007, 09:06 AM) [snapback]527348[/snapback]</div>
    I think the worst UI problem with the MFD is that the "I agree" button for the Nav is located in exactly the same position as the "Reset" button for the Average MPG. I have accidentally reset the average twice when I didn't intend to.
    Also, the whole "I agree" screen is just ridiculous anyway.
  9. patsparks
    10,664
    567
    Once you have agreed once why should you need to agree again? (Listening Toyota?) :mellow:
    I have a fact that I don't think has been posted before. :D
    11 slabs of beer in cans will easily fit in the rear load space of a Prius with the blind closed, a further 3 slabs will fit under the floor and there is still room for some stubbie holders and a barbeque meat pack to take to that BYO barbeque. B)
    If Australian sales people knew this fact they would sell more Priuses in Australia. :lol: (I know you say Prii but I say Priuses)
  10. geodosch
    geodosch Member
    182
    27
    New Jersey, USA
    2013 Prius Plug-in
    <div class='quotetop'>QUOTE(zenMachine @ Oct 15 2007, 01:39 AM) [snapback]525748[/snapback]</div>
    The chart is read from left to right, which is how one would normally produce such a graph, reading earliest to latest.
    As for why the new bars always appear at the right, it just keeps things more consistent: a new bar is displayed, and everything shifts left to make room, regardless of whether it's the first bar or the nth bar.
  11. patsparks
    10,664
    567
    <div class='quotetop'>QUOTE(patsparks @ Oct 18 2007, 11:58 PM) [snapback]527290[/snapback]</div>
    Who would have thunk it?
  12. PriusRos
    PriusRos A Fairly Senior Member - 2016 Prius Owner
    1,973
    218
    Rockville, MD
    <div class='quotetop'>QUOTE(GeoDosch @ Oct 22 2007, 07:29 AM) [snapback]528735[/snapback]</div>
    I had never found this confusing as I was reading from left to right. But the other day I noticed for the first time that the numbers 0-5-10-15-20-25-30 read from right to left. I understand why it's done this way, but it's not the same as a regular bar graph, where the 0 usually starts on the left.
  13. Tideland Prius
    16,587
    <div class='quotetop'>QUOTE(patsparks @ Oct 22 2007, 01:43 AM) [snapback]528712[/snapback]</div>
    The latest DVD version (7.1) does away with the I Agree button. You just see the disclaimer for a few seconds then it goes away automatically.
  14. geodosch
    geodosch Member
    182
    27
    New Jersey, USA
    2013 Prius Plug-in
    <div class='quotetop'>QUOTE(PriusRos @ Oct 22 2007, 10:06 AM) [snapback]528796[/snapback]</div>
    Since the minutes shown are times past, they are actually negative numbers (-5, -10, -15, etc.) indicating minutes ago. So the numbers from left-to-right really are shown in increasing value, as on most graphs.
    inframan likes this.
  15. Doc Willie
    1,717
    144
    Out there, somewhere
    Obscure fact no. ###:
    The tire changing jack works much better if you do not bother with the zig-zag rod with a hook on the end to turn it. The tire iron/lug wrench will fit into the cranking hole of the jack and turn much easier than the gizmo.
    You can save weight by getting rid of the other thingie.
  16. PriusRos
    1,973
    218
    Rockville, MD
    <div class='quotetop'>QUOTE(GeoDosch @ Oct 25 2007, 11:06 AM) [snapback]530254[/snapback]</div>
    Yes, I kind of figured that. It's still weird to see the 0 on the right though and it does take some thinking through to understand what it's actually showing. I think I see now why Zenmachine asked the question to begin with. If the most recent bar is on the left (closest to the driver), and the 0 is also on the left, it might be more intuitive.
  17. Tideland Prius
    16,587
    On a regular car, turning the headlight stalk to the first click (parking lights) or to the second click (full headlights) turn on the interior lighting (dim the cluster, illuminate the radio/climate buttons etc etc).
    Nothing unusual right?
    However, on the Prius, only the POWER button, the hazard lights button and the keyslot light illuminate. The radio and MFD hard button lights are off! They don't come on until the car is in READY.
  18. The Tramp
    The Tramp Italian Prius Expert
    375
    51
    Turin, Italy
    2020 Prius PHV
    <div class='quotetop'>QUOTE(fphinney @ Dec 3 2006, 09:25 AM) [snapback]356892[/snapback]</div>
    This does not work on my EU Prius.
    If i open the door the window will not go up anymore.
    In fact, if I power down the car and then close the windows, when and if the passenger opens the door my windows stops. I have to power on the car to close the window fully.
  19. CaptainMatt
    CaptainMatt Junior Member
    Washington, MO
    2018 Prius Prime
    <div class='quotetop'>QUOTE(Tideland Prius @ Oct 22 2007, 12:14 PM) [snapback]528872[/snapback]</div>
    2 follow up questions about your post: Can the new version (7.1) be purchased and used to upgrade existing systems? And, is doing away with the I Agree button the only enhancement (you probably know what I'm getting at, i.e., over-riding the nav system to let you operate the other functions while the car is moving)?
    Thanks.
  20. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(The Tramp @ Oct 25 2007, 02:59 PM) [snapback]530457[/snapback]</div>
    It is exactly the same in my U.S. specifications car.
