Battery life on '03 Prius?
Discussion in 'Gen 2 Prius Main Forum' started by gene4655, Oct 19, 2007.
  1. gene4655
    gene4655 Junior Member
    51
    My wife drives an '03 Prius. It is nearly five years old now, with only 37,000 miles on it. My question is: how long does the battery usually last (the regular battery, not the big power one up front)? Should I go ahead and replace it now, or wait til it plays out?
  2. brentmeister
    brentmeister New Member
    <div class='quotetop'>QUOTE(gene4655 @ Oct 19 2007, 11:02 AM) [snapback]527764[/snapback]</div>
    You are way past due- I would head down to your local discount club and have it replaced before you guys get stranded someplace. That's my .02...
    Brent
  3. kenmce
    kenmce High Voltage Member
    1,548
    521
    NY
    I think of five years as being a reasonable life expectancy for a 12 volt lead-acid car battery. It will be going dowhill from here.
  4. prim2
    prim2 Junior Member
    64
    Toronto
    It seems to me that five years is about normal in a conventional car, but the 12v battery in a Prius doesn't do any of the engine cranking that it would in a conventional car. Running relays and computers shouldn't be nearly as taxing. I'd have it checked. You may get significantly more life out of it.
    Cheers,
    Geoff
