Strange message
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dan1520, Oct 21, 2007.
  1. dan1520
    dan1520 Junior Member
    I have a 2005 Prius. I push the start button and when I drop the Joystick into D, The following message comes up. : Caution, Please press P to engage Park. The batteries will not be charged if the transaxle in in neutral" It doesn't do it when the stick is in R, Only gets the message when the stick is pushed to D.
    The indicator next to the speedometer indicates D not the screen still reads as above.
    Any ideas before I bring it to the dealer?
    Thanks
  2. Tideland Prius
    16,145
    Yeah.. check to make sure none of your doors (in particular the driver's door) is not opened.
  3. qbee42
    3,074
    <div class='quotetop'>QUOTE(dan1520 @ Oct 21 2007, 12:51 PM) [snapback]528476[/snapback]</div>
    I don't understand this sentence. Can you clarify?
  4. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    is the little door ajar light in the dashboard on? do the lights stay on when you close the door? if the door is actually closed it could be the door switch.
  5. dan1520
    <div class='quotetop'>QUOTE(Tideland Prius @ Oct 21 2007, 12:00 PM) [snapback]528481[/snapback]</div>
    Tried with the door closed and now ok. I didn't realize it hadf that effect. All ok now. Thanks a Lot!!
