How do you assign voice tags for phone dialing?
Discussion in 'Gen 2 Prius Audio and Electronics' started by rwhoyle, Oct 23, 2007.
  1. rwhoyle
    rwhoyle Member
    227
    Tulsa, Oklahoma
    I have uploaded my phone directory and added important phone numbers to the speed dial page. My question is, how do you add a voice tag to each of the directory phone numbers so you can push the talk button on the steering wheel and state the name tag of the phone number you want to dial?
    I can't find specific instructions in the 2008 Owners Manual. Any help would be greatly appreciated.
  2. surge
    surge New Member
    <div class='quotetop'>QUOTE(Sliderule @ Oct 23 2007, 04:16 PM) [snapback]529403[/snapback]</div>
    Here's info on voice tags for the Lexus which I believe uses the same unit.
    this is from a post on clublexus
    Hi everyone - new to forum and Lexus, but may be able to help here. I also had trouble trying to set up Voice Recognition Tags. Could not find the record option page illustrated in the Nav manual, then discovered that while in the Edit Contact Data segment, in addition to inputing new or editing Name and Number(s), you can also press the Down Arrow (left bottom of page) and it opens up an additional option page which contains the hidden Voice Recognition Option. Manual says nothing about the location of this extra page. Just select the "Voice Rec" button and follow its lead to create your Voice Tag. Hope this helps someone.
  3. rwhoyle
    rwhoyle Member
    227
    Tulsa, Oklahoma
    Thanks Surge, I will try that tonight to see if it works. Does anyone else have any suggestions?
  4. rwhoyle
    rwhoyle Member
    227
    Tulsa, Oklahoma
    <div class='quotetop'>QUOTE(surge @ Oct 23 2007, 03:19 PM) [snapback]529407[/snapback]</div>
    Surge,
    Just tried your suggestion and it worked like a champ!!! Thanks for your help!!! Using the down arrow does indeed bring you to a page with the rec button for assigning the phone voice tags.
    Thanks again,
    Sliderule
  5. Beasley1951
    Beasley1951 New Member
    <div class='quotetop'>QUOTE(surge @ Oct 23 2007, 04:19 PM) [snapback]529407[/snapback]</div>
  6. Beasley1951
    As the LEXUS guy says, when you register a new or old phone book entry you must use the double arrow scroll down icon on the LCD screen (at the bottom left) to get to the next screen that has the voice tag assignment function. You then push record, it prompts you through the rest. Comment: It is clear that whoever wrote the bluetooth software for Toyota Prius forgot the KISS principle (keep it simple stupid). There are no detailed instructions anywhere on programming the bluetooth for voice tags. The customer is left to trial and error to figure it out. Wake up Toyota!!!
    melkisadek likes this.
  7. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    As a general FYI, a lot of the screens have more than one page, which might not be obvious at first. Poke around a bit.
  8. Keri Weeg
    Keri Weeg Junior Member
    Fort Myers Beach, Florida
    I just bought a 2008 Prius and was going crazy trying to figure this out! Thanks, it was easy after I read this post :)
  9. melkisadek
    melkisadek Junior Member
    22
    Saint Louis, MO
  10. melkisadek
    22
    Saint Louis, MO
    I've got a 2007 and have the same problem. The answers here thus far are very helpful to some users, but I'm not one of them unfortunately. Perhaps I'm misunderstanding what you were attempting to do.
    You mentioned working in the speed dial section. I'm been expecting for the "dial by name" to search my
    whole phone book. Does voice command only work in the "speed dial" directory on the 2007?
    Mel
  11. melkisadek
    22
    Saint Louis, MO
  12. melkisadek
    22
    Saint Louis, MO
    OK, you've given me a Hot Clue? You mention RECORD and I've seen that button in meandering through
    the Toyota Prius informational jungle. I seem to recall hitting it and nothing significant (to me) happened.
    What does the next screen say? Do I need to speak into the car microphone (wherever?????).
    I'm assuming it want to listen to my voice - that modern parlance - but then Toyota engineers and
    manual writers can't be up on everything (I suppose)! Or am I supposed to hit the talk button on the
    steering wheel and say a magic phrase (magic because I haven't go a clue of what it would be and if
    I say the wrong thing I wind up feeling soooooo rejected . . . and that's by an inanimate object :0)
    Mel
    (some progress is a good thing, right?)
  13. melkisadek
    22
    Saint Louis, MO
    OK, I haven't gotten that far yet. I need to ask this question. Does Voice Recognition Tagging only work
    on the specific Contacts that are being tagged during entry or editing? I've been assuming it was a generic.
    I keep getting the notice Voice Recognition Tagging is OFF and I was looking for the switch to turn it on
    permanently.
    Mel
