2001 Prius 27800 miles
Discussion in 'Gen 2 Prius Technical Discussion' started by lovenrockets, Oct 24, 2007.
  1. lovenrockets
    lovenrockets New Member
    26
    NSB, FL
    2001 Prius
    I found a 2001 Prius that looks newer than my 2006 car that I baby. It is in showroom, literally showroom condition. The former owner passed away a month ago. I would like to purchase this car *today* for my daughter who will be a new driver.
    I am concerned about the "major" battery. I talked to several engineers that I work with and 3/4 said that the batteries can only last so long.
    Can anyone give me a warm feeling that I am not buying something that would later turn into a maintanance nightmare for a 16 year old girl?
    Thank you for any help you maybe able to provide.
  2. nitewolfgtr
    nitewolfgtr Junior Member
    61
    Owasso, OK
    <div class='quotetop'>QUOTE(lovenrockets @ Oct 24 2007, 10:37 AM) [snapback]529703[/snapback]</div>
    I drive a 2001 Prius with 85000 miles on it and it runs like a champ. I heard that there is a taxi driver in Canada who drove his classic prius to like 250,000 miles before Toyota offered him a new Prius for his old prius to do lab testing on the battery. From what he said, the battery was still in very good condition. You can try to google "Andrew Grant Classic prius" and see if you get anything. Prius is very reliable. And also you still qualify for 8yr/100,000mi hybrid warranty so you can have your local dealer check out all the hybrid components and get it replaced under warranty if need be.
    Check this thread out too...
    http://priuschat.com/index.php?showtopic=11990
  3. lovenrockets
    26
    NSB, FL
    2001 Prius
    <div class='quotetop'>QUOTE(nitewolfgtr @ Oct 24 2007, 12:07 PM) [snapback]529718[/snapback]</div>
    Thank you so much for writing back and for the links. I just felt a little nervous but don't know why. The car looks brand new. The owner was loved it and was very attached to it. I will google Andrew Grant classic.
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    If the price is right with that low of miles I'd go for it. You do run some nominal risk of battery problems eventually, but even so salvage replacements should be around $500 for a 1st gen, but I suspect you'll get many years of good service out of this car.
    90 year old only drove it to church kinda buy huh!!
  5. lovenrockets
    26
    NSB, FL
    2001 Prius
    <div class='quotetop'>QUOTE(efusco @ Oct 24 2007, 12:25 PM) [snapback]529731[/snapback]</div>
    Yes, you are right. I believe he was 85, but his son said he really babied and loved this car. You can really see it and feel it when driving it. I like it so much I want to give her my car and take it for myself. I was just concerned about the battery and knew it didn't make sense that Toyota would put anything of risk on the roads.
  6. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    First check the record to see if the battery reseal TSB was affected and if it was, make sure it is done.
  7. lovenrockets
    26
    NSB, FL
    2001 Prius
    <div class='quotetop'>QUOTE(usbseawolf2000 @ Oct 24 2007, 01:10 PM) [snapback]529756[/snapback]</div>
    Reseal TSB affected? Could you explain what you mean, please?
  8. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    <div class='quotetop'>QUOTE(lovenrockets @ Oct 24 2007, 01:12 PM) [snapback]529760[/snapback]</div>
    I remember a repair to fix a corrosion for the HV battery terminal. I can't find TSB for it now. Maybe it wasn't a Technical Service Bulletin. Classic owner may be able to help you out better. Try priusonline.com or yahoo groups.
  9. tochatihu
    tochatihu Senior Member
    9,852
    3,814
    Kunming Yunnan China
    2001 Prius
    2001- early 2003 HV battery resealing is special service campaign SSC 60G. To be done at no expense with no time or warranty limitation. Your Toyota shop can tell from the VIN if it has been done already on this vehicle.
    There are a few other maintenance items to consider if you purchase it, but they are not costly/difficult. Overall I'd rather see you in an 02 or 03 with side air bags, but most 01s are still on the road giving excellent service.
  10. jk450
    jk450 New Member
    55
    <div class='quotetop'>QUOTE(lovenrockets @ Oct 24 2007, 11:37 AM) [snapback]529703[/snapback]</div>
    In my experience, battery packs in low-mileage per year hybrids have more of a chance (a chance, not a certainty) of failing early. The pack likes to be exercised.
    This car ran less than 5,000 miles per year. If it was garaged rather than left on the street, that's a plus, as ambient temperature variations can also be a contributing factor.
    What do I mean by "failing early"? Oh, 60K to 100K miles or so. But remember, I don't have a crystal ball. No one does. I'd buy it and take the chance. Good luck!
  11. nitewolfgtr
    61
    Owasso, OK
    As far as the any recalls, before I bought my Prius used, I called Toyota and had them look up to see if there was any recalls on it. Apparently mine did not. I can't remember the number but it was some 1-800 number and I'm sure you can google it.
  12. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    Here is the SSC 40G (USA) for your reference:
    [attachmentid=12207]
  13. lovenrockets
    26
    NSB, FL
    2001 Prius
    <div class='quotetop'>QUOTE(vincent1449p @ Oct 25 2007, 03:06 AM) [snapback]530120[/snapback]</div>
    Thank you everyone for your help. I just called the number. The car was involved in this campaign and they stated it was brought in on Aug 1, 2005 and it was completed.
    We drove it last night (in the bad weather) and it handled it quite well. I'm telling you, this Prius is like a brand new car. I feel like this is an excellent car for my daughter and for us to have at our home. The breaks are wonderful!
    Thank you so much
  14. SuperDave
    SuperDave Member
    104
    22
    Anderson, In.
    There was a 2001 on ebay about a week ago that had 357000 miles on it, the buyer said that it went 310000 before the battery was replaced. If it had been closer to me I would have most likely ended up with it.
